- Mar 3, 2017
- 1,779
- 6,798
- 136
A form factor or a standard ?CAMM is a form factor. Why does it have numbered variants??
We didn't have SO-DIMM1, SO-DIMM2, SO-DIMM3 right?
Seems it's an unfinished design and accumulating quick redesigns/enhancements until it is set in stone.Why does it have numbered variants??
CAMM is a proprietary standard developed by Dell.CAMM is a form factor. Why does it have numbered variants??
The first CAMM was developed by Dell, maybe not to confuse it, the standard module by JEDEC is CAMM2Seems it's an unfinished design and accumulating quick redesigns/enhancements until it is set in stone.
Pretty sure that AM3+ was designed to account for the less than great power budget of Bulldozer+ compared to K10.Well adroc said AM5+ so maybe it will just be a minor modification like AM3+ was.
3 minutes faster than ICAMM is a proprietary standard developed by Dell.
CAMM2 is a JEDEC standard based on CAMM that anyone can implement - sort of like switching up from AMD/DICE's Mantle to the Khronos Vulkan API standard for low level graphics programming which was directly based on Mantle with input from the hardware and software industries.
All things require a sacrifice.I'll only be enjoying LPDDR if the latency isn't awful.
Well it sucks.Why is the added latency of LPDDR a problem for PC enthusiasts?
These things don't run video games.Apple Silicon Macs use LPDDR with no issue.
Gaming... One of the reasons why X3D is so successfulWhy is the added latency of LPDDR a problem for PC enthusiasts?
I suppose it has to do with the different design paradigms. Intel/AMD CPUs are designed to run at higher clock speeds, and are hence more latency sensitive.
Adroc, you think Strix Halo will eventually support 256-bit LPDDR6?LPCAMM2/3 yes.
No.Adroc, you think Strix Halo will eventually support 256-bit LPDDR6?
Gaming... One of the reasons why X3D is so successful![]()
Imagine the size of it on N3. (not saying anything, just that the die would be super small.)Zen 2 is also quite small. If it provides enough CPU capability to exploit the GPU segment, then why change?
Not only that, but it could potentially go on the back side of the motherboard and that would save a ton of space. PCs gonna get smaller, yo!Yeah, that's the point.
You screw it in and a-ha! it works.
the platform is fixed in place.Hoho, we shall see...
It still heats up and needs cooling. So no you don't.Not only that, but it could potentially go on the back side of the motherboard and that would save a ton of space
Case manufacturers are already accounting for this in new and future designs. Shoot. some manufacturers are already including extra space for backside power connectors.the platform is fixed in place.
Nothing to see.
It's just a smaller, neater form-factor for client memory.
(frankly, DIMMs kinda suck a fat one in general)
It depends entirely on your use case.Why is the added latency of LPDDR a problem for PC enthusiasts?
Can't do that, you're ATX-limited.Case manufacturers are already accounting for this in new and future designs
That's not dissipating any real heat.some manufacturers are already including extra space for backside power connectors.
The usecase for DIY DT PC is gaming.It depends entirely on your use case.
Given what backside is slang for in Britain I cannot help but visualise that 😂🤣😆Shoot. some manufacturers are already including extra space for backside power connectors
I wonder if Dell went to the trouble of developing a full ATX replacement if some standards body would take it up like JEDEC did for CAMM.Can't do that, you're ATX-limited.
Because you're not a gamer??And this is why I am not PCMR-guy.
I prefer something like easy to plug rectangular modules. Everything covered with a plastic shroud to protect the internal electronics and having microchannel spaces in the plastic for airflow. Make it so easy that a five year old can assemble their own PC.Seems like a modern overhaul of overall PC system design is long overdue.
Maybe all his gaming needs are met by Candy Crush...Because you're not a gamer??
