- Mar 3, 2017
- 1,779
- 6,798
- 136
Well I can guess the headlines at the usual news outlets in the next 24 hours...LPCAMM2/3 yes.
You can just like but strix-halo when it launches elmaoBring Unified Memory for PCs
Will they give us 256GB config?You can just like but strix-halo when it launches elmao
That requires 32Gb ICs so not for a few more years.Will they give us 256GB config?
This would get rid of the VRAM issue. No more 12GB or 16GB worries.
And finally we can train/run massive ML/AI models on our laps!This would get rid of the VRAM issue. No more 12GB or 16GB worries.
Bring LPCAMM and make it unified.
Does this mean after DRR5 we see LPCAMM on desktop?LPCAMM2/3 yes.
are you insaneAnd finally we can train/run massive ML/AI models on our laps!
Yea.Does this mean after DRR5 we see LPCAMM on desktop?
You can bolt it on the same socket too.So after LGA1851 and AM5 we see LPDRR6/7 on desktop? If so, finally!
So on-package RAM is coming to AM5 with Zen 6?You can bolt it on the same socket too.
Call it AM5+ or w/ever.
It's not on-package and dunno.So on-package RAM is coming to AM5 with Zen 6?
AM6 you mean?So on-package RAM is coming to AM5 with Zen 6?
Well adroc said AM5+ so maybe it will just be a minor modification like AM3+ was.AM6 you mean?
What does LPCAMM3 bring over LPCAMM2?LPCAMM2/3 yes.
Well yeah, but you're not dealing with DIMM insertion loss here either.doesn't LPDDR requires shorter traces between CPU and memory?
But the LPCAMM slots will need to be relatively close to the CPU? (or at least closer than regaular DIMMs)Well yeah, but you're not dealing with DIMM insertion loss here either.
Yeah, that's the point.But the LPCAMM slots will need to be relatively close to the CPU? (or at least closer than regaular DIMMs)
I'll only be enjoying LPDDR if the latency isn't awful.Because it's a server memory and you'll be enjoying LPDDR instead.
Care to substantiate somewhat ?LPDDR best.
LPCAMM2 is based on dual-channel LPDDR5X.What does LPCAMM3 bring over LPCAMM2?
CAMM is a form factor. Why does it have numbered variants??LPCAMM2 is based on dual-channel LPDDR5X.
LPCAMM3 should base on upcoming dual-channel LPDDR6 as well....
