Page 306 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
deasd
606
1,038
This might not be enough to determine the release but I guess it's enough to be a news and it's better than no news.
https://videocardz.com/newz/amd-submits-zen5-patches-in-time-for-gcc-14-1-stable-release
AMD has just submitted necessary patches for the Zen5 microarchitecture to be supported by the next stable version of GNU Compiler Collection (GCC).
Phoronix reports that AMD Zen5 parches for GCC 14 have been merged, just in time for the upcoming stable release. This means that AMD Zen5 CPU enablement has been added well before any EPYC or Ryzen product has been released featuring this new architecture.
The actual patch is not the full support for Zen5, rather, it uses replicated Zen4 code, as pointed out by the patch details. However, this being added now means that AMD can later fill in the missing details and while initial support is already present in the stable GCC library.
Markfw
May 16, 2002
27,375
16,217
I can see that happening, but I sure don't have to like it.
Me either. I have a laptop that I take when I travel, but its crap on games, and other things, and I hate the keyboard. I use it for what it was intended. I use my home computers for DC work, games and serious browsing.(30 tabs) I would never be able to do ANY of that on a laptop. (effectively) As in games, I would have to connect a 30 inch external monitor, e keyboard and a mouse. And the CPU / video card could not touch a 4080 ot a 4090.
soresu
4,228
3,713
Airflow would be a problem for most tower cases. This could be made but would never (IMO) be made a standard.
If the gfx card was mounted parallel to the mobo with the HSF assembly on the reverse side it would be very achievable I think.
Though I think it would be more problematic from a point of view of cable routing, as many people route cables under the mobo out of sight.
Especially as mobo makers seem to be leaning in that direction these days with these mobos with connectors on the reverse side of the mobo.
soresu
4,228
3,713
At this rate it seems pretty likely that we will have some announcements in time for Computex, even if availability doesn't come till later.
soresu
4,228
3,713
On the other hand there's nothing stopping Threadripper from changing its current form to something else to pick up the slack.
Right now there are 2 different versions of Threadripper that both serve a very high end (high price) market, and that doesn't really make much sense.
It seems more sensible to keep a lower end enthusiast platform for people that want and can afford something a bit meatier than laptop fare, but don't want and/or can't afford current TR SKUs.
Reactions: Tlh97 and Timmah!
Glo.
5,930
4,991
Is that why we are supposedly getting notebook chips for desktop in the future? :p
Mac Mini, Mac Studio-esque.
DIY will get either Mini-PCs, AIOs, laptops, and for DIY i believe we will get, up to Core i5/Ryzen 5/7 soldered to motherboard CPUs/APUs, depending on what they will want to achieve. Above that - its still DIY, standard DIY.
moinmoin
5,248
8,463
Client using mobile instead server dies doesn't mean it will be soldered. It will still be socketed and unlocked as usual, and 99% of the audience won't know nor notice the difference.
Reactions: Tlh97 and soresu
Timmah!
1,572
935
Notebook CPUs in ATX formfactor PCs is not a new concept. It rather has been the standard for many years now.
But thats not really the "default" solution or better said, what people have in mind when they think ATX, is it?. Adroc says that ATX is not going anywhere, cause the market is adverse to change, and at the same time desktop CPUs are being thing of past - if thats not a massive change right there, i dont know what is.
Timmah!
1,572
935
So if i want to have actual proper machine, that i can fit in 2x 4090s, i would be out of luck?
Glo.
5,930
4,991
Have you read my post? :)
If you will want a machine that will fit 2x 4090s in them - you will get something that is ABOVE core i5/Ryzen 5/7. That will be standard DIY. But - you will pay much higher price for it, since desktop DIY is dying.
Glo.
5,930
4,991
Client using mobile designs may very much mean mobile packages.
And I am fine with that.
Joe NYC
4,042
5,591
Not so long ago, ARL was to be 30-40% in ST over RPL, which may be roughly on par in ST with Zen 4.
Zen 5 was to be 10-15% faster over Zen 4.
In other words, ARL 20-25% faster than Zen 5, beating Zen 5 X3D also.
Fast forward and now, ARL ~= Zen 5
Let's see what next month brings to MLID:
soresu
4,228
3,713
And yet there is still change.
Sorry for the offtopic.
It isn't clear how much clearance those power connectors have, and how much the wires are having to bend to fit the back cover on 😟
If they are going to make this the new standard then the cavity beneath the mobo mounting plate needs to be deep enough that there is no question about safety and bending connectors.
