CrazyIvan007
- Dec 22, 2004
- 3
- 0
- 0
Hi - thank you for your answer!
The PCB is red!
The weird is, that i have this blocks not if i have to original BIOS running, but even if i have 16 pixel pipes enabled i got them. But it happens first when Win XP shows the Login Screen (some times there are no blocks, first after loading the Desktop). Will try to remove all old Device Drivers and install the 4.12.
If that doesn't work, it might not be stable at XT PE speeds so you should try a lower clocked BIOS? What colour is the video card PCB?
The PCB is red!
