The Green Bean
- Jul 27, 2003
- 6,506
- 7
- 81
Originally posted by: hatim
There is a risk though![]()
Which is a better choice? Gigabyte or powercooler?
Originally posted by: MegaWorks
If the Radeon as both the yellow CD IN connector and the 1.6ns Samsung ram.
I have a (built by) Ati Radeon X800 Pro with no video in, but it does have the yellow CD IN and the 1.6ns ram. Also the rage theater chip is present. If it has 1.6ns ram and the yelllow CD IN does that mean the pipelines are just disabled or do i have to look to see if they are laser cut. All help is greatly appreciated.
Are you sure that you card is not a VIVO X800 Pro?
Originally posted by: alteredNate
Do I need to re-install the drivers or something?
It doesn't say VIVO on the box or on the card. There is only s-video out, dvi, and standard 15 pin connections on the card. The yellow cd connector and the 1.6ns ram are there though. I don't think i'll risk it unless I can be sure. Thanks for the quick response MegaWorks.
Originally posted by: Alaxan
I stumbled upon this forum via google and I have to say thanks to you guys. I have had Saphire ATI X800 Pro for a little over a month now and had no idea it was so simple to unlock its potential up to an XT PE. Could not be happier with this mod.
Scored a 5598 on 3dMark05 after the install was finished up. I was peaking around 3900 or so before. ATITool is a must for doing this mod from my perspective. The fan control settings are likely saving the card right now at a stable 65 deg C while I am gaming and during the 3dMark05 testing.
Thanks for the great info guys. I will definately be around here more often!
Originally posted by: Azsen
Yup, a necessary requirement, but not mentioned in the guides. After reinstall you should see the 16 pipelines.![]()
Well, thanks for the help all the same, and if anyone has any other suggestions I'm all ears!
Also, is the catalyst control panel version much better? when it worked for about 5 seconds it seemed totally different than the simpler one... is there really more stuff?
Originally posted by: CaMSpoon
ah well getting a x800 pro this friday but it isnt the vivo. Still im only getting it for 150 dollersSHING SHING
Anyway, thanks again for the help!![]()
Wanted to add in real quick. I know it has been said a number of times, but do make sure you clock about 20 under if you do not have additioanl cooling. At least on the Sapphire cards. Mine heats up FAST at default XT PE Speeds. Will be installing VGA waterblock in the next weeks to come for certain!
Great feeling when you get it going aye?![]()
Originally posted by: superpandapower
Do we really need ram heatsinks on these modded vivos? Even the retail XT PE doesn't have them. Currently my BBA X800 Pro VIVO has been running for 3 months as a full fledged XI PE. I keep checking the card, but the memory doesn't heat up much. Highest temps are 63 deg C on a hot day with 3-4 hours of d3. Do people still recomend an ATI Silencer 4? Thanks all.
