- Jan 26, 2004
- 3,819
- 1
- 0
Thanks MegaWorks for "helping people void their warranties since January 2004" Haha, no but seriously you rock.
Originally posted by: alteredNate
WOW. OK, problem fixed. Sheesh I'm an idiot. I was following instructions from the techpowerup site, however I forgot that I was using the integrated flashrom floppy creator linked to from the original post of this thread. So of course that wasn't the *modded* version. I switched it, re-flashed, and voila! 16 pipes. I need to READ more carefully! heh heh. it's all those feelings of excitement mixed with "I'm doing something bad" and "I'm getting something much better than what I paid for" and "holy $#|+ what if I fry my card!!!"
SWEET! :thumbsup:
Anyway, thanks again for the help!![]()
Originally posted by: Alaxan
My Sapphire card does not have ramsinks on it and it is running fine at 501.75/526.50. I will be installing either a vga waterblock though or possibly the thermaltake vga cooler kit soon. using ATITool you can increase the fan speeds on the chip itself and it keeps things a bit cooler as well.
Get the Silencer 4 instead of the Thermaltake VGA cooler.
Cool I will look into that. Until then I am curious if possibly adding on some Arctic Silver thermal paste may help? Is it worth my time? Or should I just wait until I can get the silencer?
Get everything first then do the installation.
The fan on my Sapphire card is dying? Ok here is the deal. Since I ran the mod to the card the fan has been workin govertime a good bit. ATITool took over for a short while in the fan control to keep the temps down as well as could be, but low and behold I opened up Generals to play for a short while and the system locked out on me. (This was only turned on for about 2-3minutes. I have run full tests repeatedly with 3DMark05 to ensure stability for three hours or so, before this incident) As the game came up I heard a ticking sound gradually getting faster from the Case. I thought maybe with all of the moving around a wire may be hitting a fan somewhere. No dice the fan on the Sapphire card is making the noise once it is ramped up.
I underclocked the system back down to a Pro chip and same thing as the fan runs up it begins ticking. I feel as though I have triggered a timed bomb that is ready to go off in here. I am going to be getting a VGA cooler tomorrow and I know the Silencer4 was recommended by Mega here, but I am curious why that over something (gawdy yes) but seemingly effective enough like the TT Giant III? Is it basically a noise issue or do they really compare head to head in a cooling aspect.
*note* the biggest reason I am questioning, is because the TT inclused heatsinks for the ram on front and back and has the dual heatpipes as well, opposed to what appears to me to be a more basic GPU cooling solution?
***edtied*** ok I have come to discover this is not the video fan. Whew.... now I have NO idea what this noise is. It sounds like a thin wire rubbing against a fan or a fan hitting an edge, but I have stopped each fan individually and the noise is still present.. more searching for now, but it was not the Sapphire fan!
Originally posted by: w00t
will this work with the new x800pro pci-e?
Originally posted by: Belg
I just got a Sapphire Radeon Atlantis x800 pro vivo but it has 2.0ns memory on it. Must I flash it with the x800 pro bios with 16 pipelines or can I flash it to an XT PE and set the speed to 500/500 or 520/520 or something? What can I do and what's best?
Thx in advance
Originally posted by: kef7Also, above the UPC is written: "Radeon X800 Pro 256mb V/VO/D"
What does the "V/VO/D" stand for?
(I have an unopened BBA X800 that I'll probably return unless I can verify it with a high degree of certainty that it will mod to a PE)
Azsen
Thanks, but I'm really trying to determine if it has the yellow connector and 1.6memory without having to open the box.
Originally posted by: CrazyIvan007I had before a GeForce, didn't removed their driver, installed ATITool, patched the Card and installed the latest ATI Drivers.
