Page 518 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Abwx
11,997
4,954
5,373
4,781
33% more cores and 25% higher power for a mere 11.8% better perf than a 2 years old CPU, quite a "win", if you set those 96C Epyc at the same 500W they would be on par, so if a 96C Zen 4 match Intel s 128C at same power i let you imagine what will happen soon with the Zen 5 based Epyc.
He didn't have power draw numbers lol from RAPL which he usually does but anyway it will still be better than 64C vs 96C from 2 years ago won't be a bloodbath it will be closer i still expect them to loose by 15-20% outside of their libraries
GTracing
478
1,114
Quick comparison of the gaming performance of Lunar Lake vs Meteor lake vs Strix Point. The second two are older reviews, so they likely score higher now. Power consumption is different between models as well. In Cyberpunk FHD ultra they consume 33.1W average, 40.7W average, and 49.2W average respectively. For ram they have 32GB LPDDR5x-8533, 32 GB LPDDR5x-7467, and 32 GB LPDDR5x-7500 respectively.
Overall good showing from Lunar Lake. Lunar lake pulls ahead of Meteor lake at higher graphics settings, but at lower settings it seems to have regressed in perf/watt in a couple games. I'm guessing the drivers need work.
Abwx
11,997
4,954
There s a page about this subject here :
Anyway based on these number we can infer that Zen 5 128C Epyc wil be largely ahead due to core count parity and also a slightly better process, add the augmented IPC and you get the picture
Reactions: lightmanek
511
5,373
4,781
There is no process advantage tbf this time Intel 3 is more or less on par with what Turin has there will not be largely this time the per core performance will be higher we will see in 16 days anyway
naukkis
1,030
854
ikjadoon
241
519
CB23 1T tests, after SemiAccurate's claims (confirmed by ASUS to KitGuru)
Seems to be smaller than ASUS predicted. Perhaps some mitigation? The update itself also failed to update a few times, but finally went through:
CB23 1T score on the 258V
1859 (before the "bad" Windows update)
1819 (after the "bad" Windows Update)
Khato
1,362
450
Performance at lower settings is primarily a function of the lower power consumption limiting the CPU performance side. Could potentially be improved by modifying the power allocation between CPU and GPU, but maybe not meaningfully.
ikjadoon
241
519
ASUS Zenbook S 14 OLEDs power modes confirm, again, power profiles allow OEMs to exceed Intel's PL1.
Whisper - 12W PL1
Balanced - 17W PL1
Performance - 24W PL1
Full Speed - 28W PL1
CPU Package power:
~3W to ~10W while browsing & text editing
~3W while Netflix
However, their 258V GB6.2 1T score is quite low: performance mode 1T is 2422.
GTracing
478
1,114
I don't think that's the problem here. GTA 5 and X-Plane 11 are the only two games out of the 11 where this is happening, and X-Plane 11 is the only game where Lunar Lake loses to Meteor Lake at high or ultra settings.
fastandfurious6
914
1,043
yes, Turin = KO for Intel serverspace
Reactions: Tarkin77
Hitman928
6,753
12,492
5,373
4,781
Looks really good, though I will point out that a significant number of those tests are on Intel software. Will be interesting to see how well AMD can punch back with Turin. Definitely the most competitive it's been in quite a while though.
Only openVino but OpenVino is what fugaku supercomputer uses which is an ARM CPU they ported openVINO to Arm CPU embree is multi architecture Intel's SW Stack is something amd is unable to match even when intel was in trouble AMD may have better HW but Intel's software support is superior in industry there is no double also the funniest slide Intel-Xeon-6-Granite-Rapids-AP-Launch-NVIDIA-Head-Nodes.jpg
Hitman928
6,753
12,492
Only openVino but OpenVino is what fugaku supercomputer uses which is an ARM CPU they ported openVINO to Arm CPU embree is multi architecture Intel's SW Stack is something amd is unable to match even when intel was in trouble AMD may have better HW but Intel's software support is superior in industry there is no double also the funniest slide View attachment 108155
OpenVINO, OSPRay, Embree, OpenVKL, and Open Image Denoise are all Intel software.
511
5,373
4,781
They are not vendor locked to Intel and we use them in Blender/V ray corona and we know how they behave they are all open source I don't see the point outside of the use of AMX even for rigging purpose it's not CUDA 🤣
Hitman928
6,753
12,492
Of course they are not vendor locked, otherwise we wouldn’t have results on non-Intel CPUs. The point is that in the real world, Intel software doesn’t make up such a large portion of used software and of course Intel is going to optimize their own software for their own products. Just because it is open source, doesn’t mean equal optimizations for all architectures, especially with the “stock” software.
