Page 519 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Khato
1,362
450
The point is that in the real world, Intel software doesn’t make up such a large portion of used software
This is an important point all too often ignored in server CPU discussions in particular. General benchmark suites like those run by Phoronix are only going to be applicable to some server use cases. Servethehome does a bit better in that respect, but still doesn't provide a complete picture.
My guess is that it's safe to say that AMD is going to retain a lead on whatever HPC/float compute workloads which remain in the CPU realm. AMD will potentially remain a better choice for general purpose high ST performance servers as well, but not the clear lead they once had. Meanwhile Intel will be the processor of choice in any scenario where their accelerators come into play or where there's cause to disable SMT.
FlameTail
4,384
2,762
Can you compare A720, X4, Apple P and E with this new Skymont score?
Sure, but it will take some time to assemble the data, and it will have to come from multiple sources.
Meanwhile, here's Notebookcheck's efficiency data;
Lunar Lake is big improvement over Meteor Lake, but still a quite behind Qualcomm/Apple in single-core efficiency; bit closer in multi-core.
511
5,368
4,774
This is valid for everything
can't believe i am saying this The current thing is AI which require good SW/HW Intel will dominate due to their software in that and AMD will loose to it even Zen5
I agree but the lead will be totally workload dependent now instead of outright domination
customer have to be very picky now when choosing between Intel and AMD cause they will need to understand geometry of their workloads even more cause GNR has Memory Bandwidth advantage AMD doesn't have Multiplexer DIMM AMD will have superior Per core performance
We will se on 10 October but i can comfortably say AMD will not get easy wins anymore goes to show how important Fabrication Process is lol
Abwx
11,997
4,954
Those numbers are meaningless because that s the whole laptop power measured at the main, for CPU efficency they did more accurate measurements, at least for MT.
And no real iprovement vs MTL at 28W, only in the 15-20W range, and against
the 10C/20T 365 that s just a lost cause at whatever power.
  • Screenshot 2024-09-24 at 19-21-02 Intel Lunar Lake CPU analysis - The Core Ultra 7 258V's mult...png
cebri1
373
405
The embarassing part is it made it to launch and NAMD is one of the popular HPC benchmark
How do you know is an issue with the firmware and not with the software stack? Have you tested it yourself?
hemedans
303
176
Well thanx, but I meant skymont, not LNC
Huang has Skymont data but I couldn't understand all of it. From this article
Reactions: Tlh97 and FlameTail
AMDK11
494
435
The measurements reveal data not disclosed by Intel:
Re-Order Buffer / Retire Queue:
LionCove(ArrowLake) - 576
LionCove(LunarLake) - 557
RaptorCove - 512
Zen5 - 446
Skymont - 411
Gracemont - 253
Scalar Register File:
LionCove(LunarLake) - 268
Skymont(LunarLake) - 250
RaptorCove - 242
Zen5 - 198
Gracemont - 193
Scalar Load Queue:
Zen5 - 202
RaptorCove - 192
LionCove(LunarLake) - 184
Skymont - 114
Gracemont - 80
Scalar Store Queue:
LionCove(LunarLake) - 120
RaptorCove - 112
Zen5 - 104
Skymont - 56
Gracemont - 48
256-bit Vector Register File:
Zen5 - 392
LionCove(LunarLake) - 379
RaptorCove - 307
Skymont - 131
Gracemont - 94
Scalar Add Scheduler:
LionCove(LunarLake) - 107
RaptorCove - 97
Zen5 - 86
128-bit Vector Add Scheduler:
Zen5 - 163
LionCove(LunarLake) - 158
RaptorCove - 101
I have a feeling that LunarLake received a stripped down variant of LionCove.
poke01
4,788
6,111
CB23 1T tests, after SemiAccurate's claims (confirmed by ASUS to KitGuru)
Seems to be smaller than ASUS predicted. Perhaps some mitigation? The update itself also failed to update a few times, but finally went through:
CB23 1T score on the 258V
1859 (before the "bad" Windows update)
1819 (after the "bad" Windows Update)
What does this update do and does it effect other tests like CB 2024?
KompuKare
1,235
1,607
If Microsoft hadn't pushed for this useless copilot nonsense, LNL could have reallocated the huge amount of die area eaten up by the NPU to support another 4-8 Skymont cores. LNL as a 4+12 or 6+8 configuration with the same die area minus the NPU could have been pretty great.
But surely the exact same thing can be said about SnapDragon X and Strix too since both also invest huge areas in the NPU which would have been better invested in CPU or GPU cores or cache etc.
However, Microsoft seems to be calling the shots while the other dance!
Reactions: Tlh97
controlflow
198
348
For sure, I think the entire PC ecosystem would be better off if the die space was re-allocated into more CPU cores or larger iGPUs.
I could certainly be wrong but so far I'm very skeptical in Microsoft's ability to come up with truly compelling AI use cases that run on the NPU. A lot of their use cases so far still require an internet connection and they will still police what the user can and cannot do on their own NPU. The whole thing just seems like a way for Microsoft to save on costs by pushing processing onto the users.
The Hardcard
346
442
It didn’t have to be either/or. Why wouldn’t they just make 2 tiers? Were the LNL team on a short leash? I’m not seeing any technical or market reasons why there couldn’t be a larger die version.
