Page 520 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
H433x0n
1,224
1,606
@poke01 That graph tells us LNC is able to occasionally hit 5.1Ghz within 15W, but does not prove the core can sustain 5.1Ghz @ 15W.
It's a mobile part, it's very difficult to get a core to sustain it's fmax without dips.
The overall point should be that ComputerBase data shows that in CB R24 1T it achieves a higher score while also drawing less power than Strix.
Reactions: SiliconFly
H433x0n
1,224
1,606
That looks like an average of about 4.8GHz, with about 5 split second blips to 5.1GHz. Certainly not 5.1Ghz@15W my dude.
Why is there a big hang up on the frequency? The score is 12% higher while using 15-20% less power.
Reactions: OneEng2
Josh128
1,510
2,262
Why is there a big hang up on the frequency? The score is 12% higher while using less power 15-20% less power.
Theres no big hangup, its just not accurate to say its drawing 15W @ 5.1GHz. The score is indeed 12% higher, in R24. But its also 7% lower in R23 and 23% lower in R20.
H433x0n
1,224
1,606
Is there data available for frequency and power draw in the R23 and R20 benchmarks? That seems like pretty wild swings in performance.
Josh128
1,510
2,262
Actually, where are you seeing +12% in R24 for 258V? Im not seeing that. Im seeing +8% for 258V against the most thermally limited HX 370 (Zenbook S16), +11% for 288V.
Josh128
1,510
2,262
ComputerBase, they tested the 288V. They got a score of 127 for LNL and got a score of 112 for Strix.
111-112 is only when Strix is thermally limited as seen on the Zenbook S16 When not, its more like 116. So if you are going to take the highest LNL score available, you need to compare to the highest Strix score available. Heres a 116 run below.
Wolverine2349
526
180
86
Arrow Lake would be a better disappointment than degrading Raptor Lakes :)
At least users won't have to worry anymore. TSMC doesn't have a history of bad process issues. Yet.
As long as it trades blows or slightly ahead of welll tuned Raptor Lake across all gaming.
If it is a regression in gaming that would be very bad.
But on par with RPL and 7800X3D in gaming (if/when games become more Core heavy it will age better than 8 core 7800X3D) and using much less power, its fine.
All indications seem to be it will be slightly ahead of RPL in gaming and on par with 7800X3D/9800X3D but not beat them which means its a good get as more cores that are high performing on one node more future proof for future GPU upgrades,
What do you think?
H433x0n
1,224
1,606
It's not cherry picking, I chose ComputerBase since that’s the only review outlet with this quality of data on frequency and power usage. It's also what everybody was talking about in this thread. If we said that 116 is the median Strix score, that doesn't change the overall point.
9949asd
139
Yea, 112 or 116 doesn’t matter at all, if 288v can run 5.1ghz all time the r24 st will be 135 already. It’s not even the same level.
Abwx
11,997
4,954
An exemple of race to idling and a good exemple of actual efficency in MT.
In the graph below the CPU that get the job done the faster is the more efficient assuming that it s at same power, here it is the 370 by far, but the 155H is not less efficent than the 258V, because the excess power it use at the start of the run is about equal to the power used in excess by the 258V because of its longer rendering time.
It will be that way for whatever could heavily load the chip, not only it will consume as much but it will also do less work/joule, against a 30-35W limited H155 it would be less efficient overall in this test, as 75% more cores, with SMT for 6C, cant be compensated by a better process even with substancialy higher IPC for both e and P cores.
Reactions: ikjadoon
ikjadoon
241
519
What does this update do and does it effect other tests like CB 2024?
That's a good question. ASUS only claimed Cinebench R23; Semi Accurate just mentioned Cinebench generically. I wish I knew more, as it is a little interesting.
Reactions: 511
OneEng2
976
1,186
I agree but the lead will be totally workload dependent now instead of outright domination
customer have to be very picky now when choosing between Intel and AMD cause they will need to understand geometry of their workloads even more cause GNR has Memory Bandwidth advantage AMD doesn't have Multiplexer DIMM AMD will have superior Per core performance
We will se on 10 October but i can comfortably say AMD will not get easy wins anymore goes to show how important Fabrication Process is lol
Agree; however, in the case of the laptop and desktop market, Intel's new architecture will need to do more than pull even with AMD as Intel has a higher cost to produce each chip than does AMD.
Of course, in the all important server market, things are looking better for Intel, but still looks dicey to me:
Processor core:
Intel: Redwood Cove 128
AMD: Zen 5c 192
Process Node:
Intel: Intel 3
AMD: TSMC N3P
I agree, it no longer looks like a complete "blow out" by AMD; however ......
AMD has more cores.
AMD has a higher IPC core (Not sure on this one I admit, but I did see a detailed article of RC vs Zen 4 ... and it wasn't painting a pretty picture)
AMD is on a better process node (higher density, lower power, etc)
Now, I'm not entirely sure what all of this will mean when the real world testing starts, but it looks to me like AMD Turin might reasonably exceed the performance of Granite Rapids by a good deal considering the efficiency difference between the two overall (both CPU arch and process arch).
511
5,364
4,773
Processor core:
AMD: Zen 5c 192
Process Node:
Intel: Intel 3
AMD: TSMC N3P
It's N4P N3P won't be out until next year N3E for 5C iirc
AMD has more cores.
You are wrong on the process this time Intel 3 is not a joke of process it's the RWC that sucks like Intel P core design Sierra Forest is pretty efficient and good for it's Market
AMD MOAR cores Turin dense 192C/384Tvs 288C/T core SRF
For P core the core counts are matched i am expecting 40% uplift compared to Genoa for AMD
This will not be the case everywhere this time we have to wait 15 days for it 🤣
DavidC1
2,124
3,255
Lunarlake looks pretty good.
I'm reading the loss in ST performance under battery is immature software issues.
SKT's efficiency at very low power is impressive. Big improvement over Crestmont in MTL.
Interestingly it's only showing 16% gain over Crestmont, but the efficiency gain is quite substantial.
I have a feeling it'll get 30% as it seems the subtests it's weak in is where Crestmont LP is weak in.
AMD has more cores.
It's 128 vs 128, since the regular Turin is 128 cores at 500W, same as Granite Rapids.
Also they aren't using the same RWC core on GNR.
DavidC1
2,124
3,255
Lunarlake: https://www.laptopmag.com/laptops/w...s-with-an-astounding-18-hours-of-battery-life
Versus competing chips:
LaptopBattery life (web surfing hh:mm)UL Procyon Office Productivity Battery LIfe
Dell XPS 13 9345 (Snapdragon X Elite)19:01Not tested
Dell XPS 13 9350 (Intel Core Ultra 7 258V)18:3423:38
Apple MacBook Pro 14 M317:16Not tested
Why I wouldn't get an OLED display:
Dell XPS 13 9350 OLED (Intel Core Ultra 7 258V)08:4012:48
Versus other Lunarlake device:
Asus Zenbook S 14 (Intel Core Ultra 7 258V)13:5116:21
Abwx
11,997
4,954
The 128C Xeon has a 11.8% advantage at 39% more power than a 96C Zen 4, that put things in perspective, at same 500W power the 96C Epyc would outmatch the 128C Xeon.
With 33% more cores the Zen 5 based Epyc will have 1.33 x 1.16 = 54% higher throughput than the 96C Genoa if TDP is increased to 500W up from the curent 360W,
and enough to outmatch the Xeon by 35% at same power or eventualy have the same perfs but then at 0.5x the power.
And there s the dense version that wil add 18% perf/wat on top of the numbers above, that is to ay that Intel wil stil be late by a full, if not two, gens.
He better use a more recent version of GCC because his numbers for Zen 4 and 5 do not make sense at all, per clock his Zen 5 score is lower than the one of a Zen 4 and his Zen 4 is just slightly better than a Zen 2, but the score of the 155H for sure is not underestimated...
