Hi guys need help with patching my bios....I m running hackintosh on my ASUSX 99 AII with E52696 V3.
In order to ugrade to Big Sur I need an MSR 0xE2 Unlock And Native NVRAM Patched bios which I found here already.
The only thing missing is to unlock that bios for all core turbo ,but when i load the bios into mmtool and remove the F2 cpu patch then save my bios and rename it to X99A2.
I insert the usb into qflash port and the light is solid blue ,means it doesn't start .
I will upload the bios maybe someone can help with it or to tell me what I'm missing and how should I proceed forward https://we.tl/t-07cF9Ul0Qv
Thanks for the help highly appreciated!!!!
drive.google.com
Thank you very much for the info and the file I will report back if it worked!!!When modding the ASUS BIOS, the AMI Aptio capsule header must be removed.
AMI Aptio capsule does not allow modify BIOS. (Such as mmtool, AMIBCP)
So you must be extract BIOS region first(with UEFITool) and modded whatever you want and them compressed back into the *.CAP
Try this BIOS
Use USB BIOS Flashback
X99A2.CAP
drive.google.com
MSR Unlock + Native NVRAM + Removed 306F2 mCode + Turbo Unlock via S3TurboTool DXE
*IMPORTANT* I AM NOT RESPONSABLE IN ANYWAY IF THIS DAMAGES YOUR MOTHERBOARD
Here is the mod
*IMPORTANT* [Win-Raid Forum] How to flash a modded AMI UEFI BIOS : https://www.win-raid.com/t455f16-Guide-How-to-flash-a-modded-AMI-UEFI-BIOS.html
- Check Guide for ASUS mainboards "B. Methods for ASUS mainboards without USB Flashback support, Using the AMI tool AFUWIN "
306F2 mCode removed + Disabled C6 State(in IntelRCSetup) + S3TurboTool DXE (-50/-50/-50) EFI Driver inject.
If System hang in Boot screen, You must be disabled C6 State in BIOS
Z10PE-D8-WS-ASUS-4101.CAP : Original
Z10PE-D8-WS-ASUS-4101.rom : Modded
Z10PE-D8 WS BIOS : https://drive.google.com/file/d/1fhsn5LkJiyZbw9ibqc_h0AxhNbP7Qt4Y/
there is a 4301 BIOS for this mobo.. https://dlcdnets.asus.com/pub/ASUS/mb/Socket2011-R3/Z10PE-D8_WS/BIOS/Z10PE-D8-WS-ASUS-4301.zip any chance you could whip up a new one? Thanks!
Here is the mod
Z10PE-D8-WS-ASUS-4301.CAP : Original
Z10PE-D8-WS-ASUS-4301.rom : Modded
Z10PE-D8 WS BIOS : https://drive.google.com/file/d/1YbKaBE2V7PLjYJ5oeoN2IFQMBBi8l_ck/
Hello,
Does anybody can confirm if the xeon hack still works in windows 11 ?
Thanks
any performance benefits of W11 vs W10 LTSC'21?If you modded BIOS via DXE or PEI driver and remove 306F2 mCode, the answer is YES.
I already using Windows 11 these systems with Modded TB Unlock BIOS.
E5-2678v3 + HUANANZHI X99-F8
E5-2640v3 + MSI X99-S04 (ES of X99A-SLI)
E5-2620v3 + MACHINIST X99Z-V102
E5-2630Lv3 + HUANANZHI X99-TF
Thanks Scan.. Q, do you run a Xeon v3 system?There is no difference in performance to the extent that it can be felt.
| I do have a throttling issue(35x multiplier 51c max temp), its not power limited at all, I have c1,c1e, c3 enabled and 36x multiplier if I disable c1 it locks the multiplier max to x35, EDP current limit stays active anyone know why??? E5 2699 V3 on Asus X99-a. if anyone has a bios mod for these e5 v3 cpu's I would appreciate a download. or can you look at my bios file I have disabled HT and have the same issue Injected driver file v3_payne_90_50 I still hit a 24542 score on CPU performance test |
save quote edit Quote reply |
You have to remove the CPU microcodes for the turbo unlock and if you injected undervoltage driver it will not show it in bios but you can use hwinfo etc. to verify the voltage offsetsso I just enabled the memory timings and overclocking menus on my Z10PE-D8.. had this system for three years and never tried this.. so far I've bumped the mem timings down one notch and the results are looking good
update: none of the cpu voltage offsets work in the bios.. does the s3turbo patch lock the MSR values? or maybe it just overrides the BIOS values on post. I'm wondering if I can do away with the all core turbo patch since the bios has all the options needed, maybe I'd still have to remove the mCode?
I still hit a 24542 score on CPU performance testsave quote edit
Quote
reply
drive.google.com
I tried my older bios with just the microcode removed and the bios overclocking features ratio overrides and undervolting don't have any effect.. I think it was intended just for the "xtreme" cpu's, it doesn't do the unlock for the v3s. Although overclock menu does add some extra "pll" options to make bclk overclocking more successful along with the memory timings menu that lets you lower your timings to get max potential from the lower clocked 2133 memYou have to remove the CPU microcodes for the turbo unlock and if you injected undervoltage driver it will not show it in bios but you can use hwinfo etc. to verify the voltage offsets
Quote
reply
35x all core "non-avx2?"on a 2699 is good, I only get 32x on my 2696sOk well if its all or 35x multiplier then i will just stick to what i have setup. it will run 36x in games etc and only drops the multiplier on heavy usage.
