What controls Turbo Core in Xeons?
Page 126 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
xeon_power
Hi everyone,
I just got a X99-A Godlike Gaming Carbon and a Xeon E5-2697v3. I've been reading through the thread and saw there was a modded bios for X99-A Godlike Gaming but that download link is no longer valid also the carbon is a little different motherboard than regular gaming. I'm not sure it would work with that BIOS.
I was told that the E5-2697v3 overclocks better than E5-2698 due to higher TDP. I might be looking into getting the E5-2698v3 or even the E5-2699v3 to test them as well.
Planning to run them in Linux but have no idea how to mod the BIOS. The latest BIOS available on MSI for Godlike and Godlike Carbon below but don't believe they're working cross motherboards. Any help would be very much appreciated.
x99a-godlike-gaming
Version 7883v1A1 (Beta version)
Release Date 2019-06-25
Version 7883v19
Release Date 2018-06-21
x99a-godlike-gaming-carbon
Version 7883v281(Beta version)
Version 7883v27
Release Date 2018-06-19
Shmee
8,313
3,177
I would not flash a BIOS intended for a different motherboard. That said, as mentioned, you could use a modded BIOS for your motherboard. I am not sure how to do this, but I would ask around. GL!
Scan409
27
22
41
Hi everyone,
x99a-godlike-gaming
Version 7883v19
Version 7883v27
I AM NOT RESPONSABLE IN ANYWAY IF THIS DAMAGES YOUR MOTHERBOARD
Here is the mod.
Use M-FLASH in BIOS
Undervolt and All Core Turbo Unlock via S3TurboTool (-50/-50/-50) + 306F2 mCode removed + Disabled C6 State(in IntelRCSetup)
X99A GODLIKE GAMING :
https://drive.google.com/file/d/1oUN84aef7CFu4cu-EOYXfop6ANfg8pfB/
X99A GODLIKE GAMING CARBON : https://drive.google.com/file/d/1GIkwuZ-HVIZwgGiMpgd5gGKCaWkjdqQG/
If System hang in Boot screen, You must be disabled C6 State in BIOS
xeon_power
Here is the mod.
Use M-FLASH in BIOS
Thank you very much!
xeon_power
Is it possible that there's a hidden ECC Memory support in this BIOS? I can't get it to post with ECC, but non-ECC works fine. I see alot of other X99A boards that support ECC.
Seimari
Hello,
I have Asus X99 Deluxe with water cooled (EKWB Monoblock, cpu + vrm) Xeon E5-2699 v3 and I did the unlock with guides from Craft Computing and Tech YES City YouTube videos.
My bios is latest version 4104 and I installed V3.EFI with USB stick, then in Windows 10 cpu_mcupDate (GenuineIntel.dll thing).
When I run Cinebench R15, HWiNFO64 says ratio x28-29 and when I run CPU-Z CPU stress, I get ratio x30 (7262 cpu multi thread result).
Am I hitting TDP limit? Should max turbo be higher?
I had CPU Core Voltage Offset -0.086 but now -0.090.
Today I made two new bios files (versions 3701 and 4101) with v3_payne_90_50.ffs file and of course 06F2 removal + C3 & C6 disabled.
I'll try later those new bioses without V3.efi usb stick injection and without Windows 10 cpu_mcupDate thing.
Edit (2 days later):
I tried 3701 bios without ffs injection, then uefi injected v3x4-0.10b-i306f2-rc9_90_70_50.efi.
Now I get all core 33x 101MHz CPU-Z stress and Cinebench R15. (CPU Core Voltage Offset -0.086)
2 disabled cores = 34x 101Mhz
Seimari
@Scan409 Could you make S3TurboTool bios for Asus X99 Deluxe + E5-2699v3 (water cooled with monoblock), please?
I would like to try that also because Miyconst said: "S3TurboTool is overall better than the payne drivers"
Scan409
27
22
41
Here is the mod.
Use USB BIOS Flashback
Reactions: Seimari
MOF
118
33
101
It is very interesting to see this topic still active after many years. Even a developers (Dufus, payne, me.. ) who were here at the beginning of this operation no longer use those cpus.
Other hand this mod keeps the prices second-hand absurdly high. Thats not ok.
Please go buy Ryzen.
Reactions: Scan409
JazzMan22
Hello,
Asus x99 A-II
E5-2678 v3
Kingston 256gb m.2 nvme
Corsair 16gb 2400mhz
GTX 1060 3gb
I followed two different tutorials but failed.
I didn't get any errors.
In the end, when I stress my cores I can't get over 2.499ghz.
Which means I failed somewhere.
The issue is I don't know where.
Tried @Suge Knight 's, @tech YES City
If anyone can recommend something different I would highly appreciate it.
I don't know what other information to post, please tell me and I will promptly.
Thank you.
UPDATE
Enabled Haswell-E SFR Adjust
Diasabled Enhanced Intel SpeedStep Technology
104.0 BCLK 3.42Ghz stable.
It works now.
shpitz461
Hi guys, I'm very late to the party but considering building a dual v3's system.
What are the differences between 2699v3 and 2696v3? which one would yield better unlocked results?
Is an Asus Z10PE-D16 WS a good choice for motherboard?
EDIT: What would be a good 140mm water cooler for them?
Thanks!
daan9999
Hi does anyone have a modded bios for Z10PE-D16-WS which works? I have searched the thread before but all the links are dead and the people who posted them are non responsive.
I succesfully modded my z10pa-d8. so i can give that one a try aswell.
Peaches182
14
Hi punks ! I recently update to W11 and since that moment my CPU doens't goes over coefficient 28, instead of 36, even in with single core test/bench.
Anyone else facing the same issue ? by the way I have an X99M extrem4, is it possible to mod/hack the latest bios available for this mainboard ? I am currently using an old P3.20 version. The last one is the P3.50.
Could anybody hear hack it for me ? would be so kind :)
supermanz
Anyone got a bio's mod For a MSI x99s Gaming 9 ACK , browsed alot of pages so far can only locate msi x99 carbon which is'nt any use.
Link for latest Bio's :-
default_user
Hello,
Can someone link pages for Asus Z10PE-D8 WS mod steps/tutorial/anything (especially all core turbo unlock), because all older links stopped working and I can't find trusted documents over the internet :(
Thank You so much!
supermanz
Msi x99s gaming 9 ack motherboard with 2696 v3 xeon cpu looking turbo unlock bio's. if anyone has one available.
Reporting as my xeon 2696 v3 arrived today but still cant seem to mod this bios tried following techyescitys posting but getting confused following the guide on the fpteditor patch area , saving as bin, when in msi mflash cant locate bios afterwards
Scan409
27
22
41
Hi guys!
I would be grateful for help in modifying BIOS for GA-X99-UD4 v1.0
I am using Xeon 2640 v3.
Thanks.
Link to the latest Bios https://download.gigabyte.com/FileList/BIOS/mb_bios_ga-x99-ud4_f24c.zip
*IMPORTANT* I AM NOT RESPONSABLE IN ANYWAY IF THIS DAMAGES YOUR MOTHERBOARD
Here is the mod
MUST USE efiflash 0.65_mod or 0.80_mod * in DOS * (DO NOT USE efiflash in mb_bios_ga-x99-ud4_f24c(rev 1.0).zip)
In DOS,
type efiflash.exe X99UD4.24c
How to make Bootable FreeDOS USB :
Rufus : https://rufus.ie/en_IE.html
GIGABYTE GA-X99-UD4 rev 1.0 : https://drive.google.com/file/d/1idOaO0JAuJn6J7oxSGn7rFtzfPVY0T7Z/
efiflash 0.65 mod : https://drive.google.com/file/d/1jLAeWdsvIOPx5HCQvjIGb9vfPReKyLRl/
efiflash 0.80 mod : https://drive.google.com/file/d/1fQizIvfRjGbAnsN-HCZZ-iC-DyCEqZA8/
Scan409
27
22
41
Here is the mod
Use Instant Flash in BIOS
ASRock X99M Extreme4(P3.50)
: https://drive.google.com/file/d/1bEu26nvHUEtA9XUOIW22Dk5k104Jhvhj/
Scan409
27
22
41
Here is the mod.
Use M-FLASH in BIOS
X99S GAMING 9 ACK :
https://drive.google.com/file/d/17OfXrY_tftMYIwlyhSG96nXSZzTE4i3_/
Scan409
27
22
41
Hello,
Thank You so much!
Here is the mod
*IMPORTANT* [Win-Raid Forum] How to flash a modded AMI UEFI BIOS : https://www.win-raid.com/t455f16-Guide-How-to-flash-a-modded-AMI-UEFI-BIOS.html
- Check Guide for ASUS mainboards "B. Methods for ASUS mainboards without USB Flashback support, Using the AMI tool AFUWIN "
306F2 mCode removed + Disabled C6 State(in IntelRCSetup) + S3TurboTool DXE (-50/-50/-50) EFI Driver inject.
Z10PE-D8-WS-ASUS-4101.CAP : Original
Z10PE-D8-WS-ASUS-4101.rom : Modded
Z10PE-D8 WS BIOS : https://drive.google.com/file/d/1fhsn5LkJiyZbw9ibqc_h0AxhNbP7Qt4Y/
Reactions: Flash Gordon
stiggity
19
4
51
Hello!
Just turbo unlocked asus z10pc-d8/sas, using efi manual install, and i dumped/removed microcode/flashed my board. It's working well, but im only seeing 3.24GHz on 2x e5-2698v3. Got an email from Kostiantyn, linking me to the s3turbotool, but each time i launch the .exe the tool stops responding. Anybody feel like putting a package together for this combo? Much appreciated, thanks in advance.
Scan409
27
22
41
Hello!
attach your DUMPED BIOS on this thread.
stiggity
19
4
51
the site won;t allow me to attach either a .rom or .bin? is there an _allowed_ extension??? Please let me know.
