Well man how the heck did you pull that off what other settings that's awesome my score drops with -50uv never mind you running duals still good stuff though
you don't think it's a little low?Well man how the heck did you pull that off what other settings that's awesome my score drops with -50uv never mind you running duals still good stuff though
I managed to install Monterey but it freezes daily may I ask you for another favor please ? I have this already nvram patched bios (on Google drive) it only needs to remove the F2 cpu microcode without adding in anything else.When modding the ASUS BIOS, the AMI Aptio capsule header must be removed.
AMI Aptio capsule does not allow modify BIOS. (Such as mmtool, AMIBCP)
So you must be extract BIOS region first(with UEFITool) and modded whatever you want and them compressed back into the *.CAP
Try this BIOS
Use USB BIOS Flashback
X99A2.CAP
drive.google.com
MSR Unlock + Native NVRAM + Removed 306F2 mCode + Turbo Unlock via S3TurboTool DXE
drive.google.com
If the bios is clean then I can inject with Clover Bootloader the EFI file for turbo so the system can be stable.
For the life of me this crappy laptop wont open the bios file with uefitool
Thanks and Best regardsX99-A-II-ASUS-2101.CAP.patched
drive.google.com
drive.google.com
Thank you very much I hope this time will work !!!!!
Here is the mod
Z10PE-D8-WS-ASUS-4101.CAP : Original
Z10PE-D8-WS-ASUS-4101.rom : Modded
Z10PE-D8 WS BIOS : https://drive.google.com/file/d/1fhsn5LkJiyZbw9ibqc_h0AxhNbP7Qt4Y/
I AM NOT RESPONSABLE IN ANYWAY IF THIS DAMAGES YOUR MOTHERBOARD
Here is the mod.
Use M-FLASH in BIOS
Undervolt and All Core Turbo Unlock via S3TurboTool (-50/-50/-50) + 306F2 mCode removed + Disabled C6 State(in IntelRCSetup)
X99A GODLIKE GAMING : https://drive.google.com/file/d/1oUN84aef7CFu4cu-EOYXfop6ANfg8pfB/
X99A GODLIKE GAMING CARBON : https://drive.google.com/file/d/1GIkwuZ-HVIZwgGiMpgd5gGKCaWkjdqQG/
If System hang in Boot screen, You must be disabled C6 State in BIOS
Is it possible that there's a hidden ECC Memory support in this BIOS? I can't get it to post with ECC, but non-ECC works fine. I see alot of other X99A boards that support ECC.
Really interested in a quick writeupI have gotten the unlock to work on the HP z440. If anyone wants to know how let me know here and I will explain how I did.
*IMPORTANT* I AM NOT RESPONSABLE IN ANYWAY IF THIS DAMAGES YOUR MOTHERBOARD
Here is the mod
*IMPORTANT* [Win-Raid Forum] How to flash a modded AMI UEFI BIOS : https://www.win-raid.com/t455f16-Guide-How-to-flash-a-modded-AMI-UEFI-BIOS.html
- Check Guide for ASUS mainboards "B. Methods for ASUS mainboards without USB Flashback support, Using the AMI tool AFUWIN "
306F2 mCode removed + Disabled C6 State(in IntelRCSetup) + S3TurboTool DXE (-50/-50/-50) EFI Driver inject.
Z10PE-D8-WS-ASUS-4301.CAP : Original
Z10PE-D8-WS-ASUS-4301.rom : Modded
Z10PE-D8 WS BIOS : https://drive.google.com/file/d/1YbKaBE2V7PLjYJ5oeoN2IFQMBBi8l_ck/
Here is the mod
Does someone still have the modded bios files as the file is unfortunately not more available? :-/traderjay,
Here are the modded BIOS file to unlock the turbo. I tested it on my X10SRL-f motherboard last night and it worked fine.
mod_X10SRL-f.zip
I included EFI files also. So you should load one of them before getting into OS.
Before and After
Cinebench R15 score: Before: 1500, After: 1725.
CPU-Z (v1.79) multi-score: Before: 3934, After 4552.
Again, I am currently using E5-2658 v3 QS chip on this motherboard so there is no different on single core performance, but multi-threads performance is improved from 2.5Ghz all cores to 2.9 all cores after mod.
And, here is my BIOS settings. You may tweak them if it is needed.
CPU Configuration
Hyper-Threading (ALL) - [Enable]
Cores Enabled - [0]
CPU Configuration -> Advanced
Power Technology - [Custom]
Energy Performance Tuning - [Disable]
Energy Performance BIAS setting - [Performance]
Energy Efficient Turbo - [Disable]
Advanced -> CPU P State Control
EIST (P-States) - [Enable]
Turbo Mode - [Enable]
P-State Coordination - [HW_ALL]
Advanced -> CPU C State Control
Package C State Limit - [C0/C1 state]
CPU C3 Report - [Disable]
CPU C6 Report - [Enable]
Enhanced Halt State (C1E) - [Disable]
CPU T State Control
ACPI T-States - [Enable]
Last, Windows OS Power Options - High Performance
Let me know if you need anything.
My domain is expired but you can still get those file, just replace "masterofphoton.com" to "https://s3.eu-central-1.amazonaws.com/masterofphoton.com"
like that
disable c-state?I have a supermicro X10DRI with dual e5 2680 v3. But I can't boot windows server with microcode removed (tried mmtool, ubu and winhex way). If I have v3x2.efi added, there will be messages indicating all cores are boosted, but windows still stuck at boot logo ( tried windows server 2019 and 2012 r2 ). By the way, I cant boot debian either. What could be the cause?
@MOF@Everyone!!
Do i remove microcode, flash bios, then boot a freedos, and load/copy the .efi from USB drive, then copy onto nvme? Like the old days?? I see your .efi is 40k... i have the feeling im missing something. It's been awhile..(years)
what does "vcc" stand for? v3x2_20-50-50_vcc.efi, Please would someone fill me in on what im missing???
-Thanks in Advance!!!
