Page 825 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,218
how much slower will NVL be than ARL ;).
If they actually manage that (NVL slower than even ARL), LBT should just resign now (he has the tape-out results). I hope he sells his shares as soon as he sniffs something burning and gets the hell out of there.
511
5,454
4,879
Bruh NVL preliminary data has already leaked also NVL is pat product so you can blame it on him that should be easy peasy for you 🤣
19,218
I'm tired of blaming him. I'm suffering from a chronic case of "Blame Pat" syndrome. I want this to be over. LBT, sell the fabs or fire half the company. Do it. NOW!
Reactions: 511
511
5,454
4,879
NVL is good not half baked like ARL tbh. It will make Desktop great again.
19,218
Even after this reply I would gauge the probability of you buying NVL-S at 50%, going up to 80% if Intel delivers a proper big cache.
Nah. I'm done. Seeing current limits of silicon and the slow (lazy?) state of incremental improvements, I will skip NVL and maybe upgrade to Zen 6 when it crashes in price due to Zen 7 ample availability.
I'm actually more interested in seeing some cooling innovation that gives plebs the same cooling capacity as custom cooled rigs.
AcrosTinus
221
226
*was too negative*
I am also on the hold once the Ultra 7 is stabilized, will take a look once 2nd Gen DDR6 systems are out.
poke01
4,872
6,202
Most of the CPU innovation will come from RISC-V and ARM and co.
As for DIY you will be stuck with AMD for a long while
19,218
Oh hell no, Intel is a labyrinthine structure.
A curse for anyone and everyone heralding it.
Yeah, only I can succeed because I don't mind getting to the bottom of things, especially when I'm passionate about it. If there are things I don't understand (like process related limits), I'll just use TSMC as an excuse (they did it, are you admitting that you guys are inferior than TSMC?). But yeah, for me to succeed and remembered as the best CEO Intel ever had, they need to give me complete control, right down to firing someone on the spot if I think they are being a detriment to my goal.
19,218
*was too negative*
What workloads does your 265K usually crash in? I haven't faced a serious crash on my 245KF yet during normal use but then I haven't used it for 24 hours straight yet. In your case, it seems like possibly a bad sample (could be one reason why they are having a firesale on 265K) or the mobo needs the latest BIOS and try running with only Intel base profile or 200S Boost profile and see if the crashes persist. If they still do, either bad mobo, some other finicky hardware causing the crashes (process of elimination to identify) or finally bad CPU sample.
OneEng2
1,011
1,211
I suspect that NVL will be to ARL as Zen 3 was to Zen 2. In other words, I am thinking it is going to be a pretty good product.
I do wonder about the big cache implementation. In AMD's X3D it is great for workloads that thrive on low latency memory access (like games).
I suspect even a poor implementation of Intel big cache would greatly improve the overall memory access latency. Maybe not as well as AMD's X3D implementation, but it might not matter overall.
511
5,454
4,879
Intel's version the cache is on the same die as the cores no HB a normal compute tile with extra cache
Geddagod
1,681
1,720
Hence it likely being a worse implementation, from the perf side.
According to AMD you can't achieve the very low 4 cycles latency hit that adding all that extra capacity without 3D stacking it.
Reactions: Joe NYC
coercitiv
7,485
17,891
It does not have to be as fast, it's still a big chunk of cache that is significantly faster the RAM pool. I'm just cautious because it's Intel, they seem to introduce unexpected flaws in many of their recent products.
Are we sure about this? They'll have two 8+16 compute die designs?
5,454
4,879
Bruh what? There ain't no way HB is superior to monolithic in performance unless you are talking about very large big dies where you can't fab it. Please get your facts checked.
Yes the bLLC and the normal cache version
coercitiv
7,485
17,891
Monolithic can end up paying a bigger latency cost due to higher signaling distance. Vertical stacking keeps max distance under control. My understanding is that, as far as latency is concerned, there's an area threshold where stacking pulls ahead in terms of performance.
511
5,454
4,879
But it is dependent on the distance as well and how their L3 is architected for this it all comes down to how they are doing it
dr1337
547
834
Why isn't it a problem for Apple and their LLCs?
Idk how much AMD marketing is really applicable to reality/Intel, none of these companies really want to give all the details. Its easy to say signaling distance without giving any numbers.
