Page 975 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Thunder 57
4,294
7,099
Keep in mind the bench on 7-Zip varies among versions. I just tested the latest against 18.03 Beta and the newer one produces much higher scores. I don't know if the algorithms are better, the compression index is less, or a combination of both, but something is different.
Based on what they say it sounds very version dependant:
The LZMA benchmark shows a rating in MIPS (million instructions per second). The rating value is calculated from the measured speed, and it is normalized with results of Intel Core 2 CPU with multi-threading option switched off, and measured with old version of 7-Zip.
Abwx
12,024
4,986
its not that big of a difference between versions on the same OS. Its Linux that produces a higher score likely due to better complier and optimisation.
v25.01 is 8708 MIPS in my testing on Windows 11
v18.03 is 8484 according to NBC on windows 11
You have likely faster RAM than NBC s stock 5600, there s only 2.6% difference though.
Abwx
12,024
4,986
I tested with the 9.2 version wich is very old and the 18.03 one doesnt make a big difference, what is sure is that with 7-Zip all those IPC improvements claimed for the last 15 years fall litteraly flat, as i pointed it Haswell has 65% better IPC than C2D in Cinebench but in 7-zip it s barely 13%, the same for AMD with only 25% better IPC for Zen vs FX8350 despite 60% in CB.
No wonder that 10-15 years old PCs still work relatively well nowadays for basic usages despite quite slower RAM, best progress here was mainly brought by higher CPUs frequencies.
DavidC1
2,184
3,331
Where is Haswell 60% faster than Core 2 in Cinebench? You are including Hyperthreading in there. Haswell is 25-30% better. 7-zip is also underestimating Haswell gain, and likely Zen as well. 7-zip itself is too memory bandwidth bound, also not a realistic benchmark.
Cinebench is BETTER overall. It's barely affected by memory which is true for vast majority of lightly threaded applications, you can't boost significantly by bigger caches despite that, and it really doesn't care about anything other than basic FP, meaning SSE/AVX is useless. This is for ST by the way. In MT it has bigger flaws, but still better than vast majority of other tests. THE single most important metric today is still the scalar integer performance. Both Cinebench and Spec does pretty good job at it. Now I said it's not perfect. It comes close enough to the overall average.
Abwx
12,024
4,986
Cinebench is not better, tell me wich are the consumers apps that rely on FP rather than on INT, you wont find a single one.
As for comparison of HW and C2D in ST here its is, beside there s Fritzchess in the comparison wich is also INT and is heavy for branching, if you take account of the frequency difference between the G1820 and the C2D you end with quite low numbers for the INT apps.
  • Screenshot 2026-02-08 at 14-55-00 vs Core 2 Duo E6600 et Core 2 Quad Q6600 - x86 basse consomm...png
