Page 827 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
If I am less pessimistic, I would call the reintroduction of SMT a positive thing, but somehow my gut tells me, this will be at the cost of ST performance gains because time has to be invested into resurrection and hardening to prevent a SpectreV-X. Time that could have gone into the 1T performance. A super wide P-Core or the so called rumored RU is officially a bed time story.
It's majorly in DC though
For some reason, AMD gets a much bigger boost from SMT than Intel .... which is ironic since Intel introduced it to x86 far before AMD got it.
SMT4 for Intel anyone?
I was honestly going to suggest the same thing. If you're going to do it, go all the way with it and support SMT4 or even SMT8 like IBM. The additional cost to "go bigger" is less than the cost to do it at all.
I hate on Intel's product segmentation all the time, but it wouldn't make me sad at all if only Xeon and Core i9 type stuff supported SMT, and it was disabled on everything else.
Just learned few days ago from someone that out of three samples of Alder Lake CPUs with functioning AVX-512 (with mobos that have patched BIOS and microcode), none had issue-free AVX-512 execution. Some cores always error out on some instructions while others work fine. So my speculation is that (like everything else), Intel LIED about hybrid cores as the reason why AVX-512 was disabled in their consumer CPUs. They probably found or were notified of errors too close to launch and then a decision was made to axe AVX-512. Pat was the CEO. Makes me wonder how many other lies he was responsible for.
That's kind of what you would expect to happen if an thread just magically moved from a P Core to an E core and tried to do an AVX-512 instruction.
Nope. Even patched BIOS/microcode do not allow enabling AVX-512 with E-cores. The E-cores need to be explicitly disabled for the AVX-512 option to appear in BIOS settings. So the errors are happening with only P-cores enabled. May not matter for something like a PS3 emulator but for anyone actually doing serious work, the errors would've been frustrating. Rather than risk admitting that they messed up, Pat decided to let Intel cover it up.
That was the original intention, yes. It's possible that a patch would mess things up, esp if it didn't do things like do the proper voltage adjustments to handle AVX-512.
It was a punchline but as an ISA's typical workload becomes more and more enterprise-y it seems they trend toward more SMT, not less.
As stated, the only one I can remember doing this was IBM IIRC. I am thinking that you don't get near the boost from SMT4 as you get from nothing to SMT2. ... and you really have to add some serious execution units across the board to do it.
I just wonder if it isn't a better PPA to just add another entire SMT core?
Well since it's a Lion Cove refresh even 5% would be good but he will say they failed
That's the MLID way, set high expectations for minor refreshes and then slam the refresh for not meeting them.
Tho of course in this case, Intel's P core is and has been a disappointment (in PPA, PPW, ...) for some years now. Just no one paying attention should expect Cougar Cove to fix that.
Hopefully 18A is a meaningfully better node than N3B and there'll still be improvements to performance that way.
What an absolute cluster f of product offerings. No wonder Intel are failing, they seem to have no clear direction, rhyme, or reason to their designs and production lithography choices. Its all over the place.
It's not cluster F if you think how they have planned this all of this done with like 5-6 Tiles 3 are common btw.
I see no problem with Intels client roadmap, to be honest it’s better than AMDs especially
for laptop.
Server is a sour pudding though, that’s beyond fixing this decade
I see Panther lake being even better than ARL-h for battery related tasks. Can’t wait, not every thing is about IPC.
The fact that PTL doesn’t use Arrow lakes awful uncore and is similar to lunar lake is a massive plus.
