Page 755 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,124
3,255
I would guess that if the e-core only CPU is real, it's a low end model like the i3-N305. Maybe they add 4-lpe cores on top of the 8 e-cores.
Why would it be a low end if it's a Xeon and they are already not bothering to create a separate Skymont successor to N305?
Gracemont: Per clock Integer performance with a P core 2 gen ago
Skymont: Per clock Integer and FP performance with last gen P core
Arctic Wolf: I would not be surprised if it is on par with last gen P core in absolute performance
So am I calculating this correctly? I see the IPC of the P cores (2290/1685)raw score / (5.7/4.6)clockspeed margin or only about 10% IPC margin for the P
cores?
Yes, but didn't we know that already?
Clockspeed scales at ~90% on Cinebench so it's about 12%.
GTracing
478
1,114
The way I read it initially, the e-core part would be consumer; they said it was a nova lake part, and server parts of have different codenames. Though looking at the tweet again, I'm not sure if that's what they meant.
If it is Xeon, then I think you're right that it wouldn't be low end.
LightningZ71
2,673
3,372
They could take an Arrow Lake package and just drop a special core chiplet on it with 32-40 e-cores to maximize MT throughput.
I would Imagine that they would want more PCIe lanes and 2 more DDR channels
511
5,373
4,781
I hope we get a triple channel platform it's time to move on from Dual channel.
it's fine if only some motherboard have it but the CPU supporting it is mandatory
Harry_Wild
860
170
Has Intel released a mobile CPU without a fan inside to compete with Apple's Air and Qualcomm's Windows mobile CPU?
DavidC1
2,124
3,255
LNL is fanless capable but no one did it
Fanless has lots of advantages from my own experience.
-Lower heat, since the system needs to be able to handle not needing a fan
-Battery longevity, because of the lower heat. I bought it used and few years since then but the degradation is still only in the 10-15% range.
-Even lower power because it doesn't need to power the fan.
-No worry about dust because it doesn't have vents.
We already have HEDT and the extra channel is a waste for vast majority of systems, while permanently increasing the cost.
MS_AT
929
1,848
When you are building something general purpose then something will end up unused. The system needing more mem channels might not need so much PCIe, or the system with big PCIe requirements might not need mem channels or the sheer amount of cores hedt brings.
But is the alternative of custom building everything more preferable when you will loose economy of scale? Probably for the hyperscalers as they can make up the neccessary volume on their own, but for small scale deployments you probably get short end of the stick either way :(
511
5,373
4,781
Yes but 1 extra channel will be needed with this ridiculous core count increase
19,210
Maybe with PCIe 6.0, they can create a pluggable DIMM, SODIMM or CAMM2 module that users can just swap in or out based on their needs. Sell mobos cheap without RAM support then user buys the appropriate channel pluggable module based on their needs (single channel for office PCs, dual channel for power users, triple channel for enthusiasts and so on).
LightningZ71
2,673
3,372
DDR6 brings roughly double the data transfer rate of DDR5, which doubled what DDR4 had. The regular dual "channel" AM6 socket should have similar memory bandwidth to the ZEN2 EPYC servers, which topped out at 8 channels of DDR4 (edited: I originally said DDR5) and 32 cores with less L2 cache per core and likely far less L3 cache per core.
I think there is enough memory bandwidth for consumer platforms.
What I personally want more of is PCIe bandwidth. I want 16 lanes of PCIe 6 for the video card, 8 x PCIe 6 lanes for the system IO controller, and a pair of PCIe 5.0 x4 m.2 sets for SSDs or other motherboard needs. This way, creator or semi pro boards can offer three additional full length slots for extra video cards, storage cards, or specialized I/O cards. It's going to be a VERY long time before there are a lot of PCIe 6, or even 5 cards out there, however, there are many 4.0 and 3.0 cards out there that appreciate having all 16 lanes. All that can come from the IO controller if it's fed with 8 x 6.0 lanes.
5,373
4,781
Intel already has a patent like that For GPUs you can upgrade VRAM on GPU
MS_AT
929
1,848
More BW or more lanes? I mean 16 PCIe 5 lanes could be plenty if we had sensible options to bifurcate the lanes. You could put 8 lanes to gpu and use the rest for 4x nvme drives /mix and match with network controllers and have sufficient BW (at PCIe 4.0 rate).
511
5,373
4,781
If I had to pick one more lanes not bandwidth .
There is nothing on consumer side needing that needs that much bandwidth more lanes yes
Reactions: Tlh97 and MangoX
DrMrLordX
23,191
13,275
So am I calculating this correctly? I see the IPC of the P cores (2290/1685)raw score / (5.7/4.6)clockspeed margin or only about 10% IPC margin for the P cores?
Yes, but as we all should know by now, low-clockspeed designs can scale better. Without normalizing for clockspeed, the P core is roughly 35% faster, showing that Atom has a ways to go before it can supplant P cores entirely. Intel would be in a much stronger position if they could replace 5.5-6 GHz Core with ~4.5 GHz Atom.
zir_blazer
1,265
586
You are literally describing CXL when used with RAM.
DavidC1
2,124
3,255
Not really. Performance has been limited by power for over a decade now. They won't get twice the power headroom. If it's 30% faster than it only needs 30% more bandwidth.
LightningZ71
2,673
3,372
Essentially, more lanes = more bandwidth, but, yes, more end user available lanes...
LightningZ71
2,673
3,372
Going from AM5 to AM6, I do want more lanes; 4 of them. I want to double the lane count to the board IO Die to 8, and upgrade it to PCIe 6. That would quadruple the bandwidth to it and allow all sorts of multiplexing of downstream lanes.
MS_AT
929
1,848
Sure, but on consumer platforms, we end up getting more BW, while the lane counts stay the same. Using multiplexing chips in theory you could add cards that would turn 1 PCIe 5.0 x8 to 4 links of PCIe 4.0 x4 but these are rather expensive, so having more lanes from the CPU even if older gen seems like a better deal for the end user if bifurcation options are exposed in bios. Then you could turn 1 PCIe 4.0 x16 into 4 links of PCIe 4.0 x4 with passive add-on card. Or manufacturers could go Samsung way and support PCIe 5.0 x2 and PCIe 4.0 x4 at the same time like in their latest evo drive.
LightningZ71
2,673
3,372
The IOD on the motherboard is already a multiplexer. The USB root hubs, the Ethernet MACs, the serial IO hub, ancillary stuff, it's all internally just PCIe devices. They even expose a few external lanes already. Nothing beyond the primary video card is heavily latency sensitive, they just need bandwidth in the form of PCIe lanes. The more lanes, the better, as lots of older but valuable cards are wide PCIe 3 implementations.
Kepler_L2
1,076
4,617
8x actually, current link is PCIe Gen4
