Page 753 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ondma
3,319
1,708
I am waiting for Igor to leak NVL Performance Projection like they did with arrow lake.
Since the core count is 16P+32E I bet the 32E alone would have greater Multi than ARL-S and 2X over ARL is possible 100K R23?
I hope they don't use DLVR on Desktop there is no need for it on Desktop.
Any guesstimate for ST Performance?
I was at first really excited about this rumor. However, I wonder how they will be able to control temperatures and power consumption. ARL cut power somewhat, but they still approach 250 or 300 watts maxed out with 8p 16e. If there is a 16P Nova Lake, it might not be that great for gaming--- not sure what kind of 1T performance they can get out of that.
19,210
I think their chances are great if they put a low latency (<50 ns) 128MB cache in the SoC tile for 16P Nova Lake. For gaming workloads, the CPU shouldn't consume more than 125W overall. If they can manage at least 15% IPC increase over Lion Cove with guaranteed 5.5 GHz clocks, they may manage to be competitive with Zen 6.
511
5,386
4,812
The IPC Estimate should be 20% or more considering we are getting both a Tick (Cougar) and Tock(Panther Cove) and fixing lost IPC From ARL
Thunder 57
4,250
7,048
I think the days of 20% IPC increases are over inluess it is being compared to a previous architecture that is broken in some way..
511
5,386
4,812
Well the ARL architecture was borked so... Also E core team is going to deliver 25% IPC over skymont lol
Thunder 57
4,250
7,048
Panther Lake. It's just not coming to desktop.
Fair enough.
And SkMT saw a greater than 20% IPC increase...
I suggest you read the C&C articles on Skymont and you will realize why it was so successful. It might also make you rethink your position that another huge IPC increase can be done as readily. I'm all for it if they can but I'm not expecting it.
511
5,386
4,812
20% sounds believable, I just don't believe they can do Skymont 2.0
20% over darkmont which is 4-5% over skymont so 25% over SKT but another skymont seems impossible if they do it though I wouldn't be shocked
OneEng2
981
1,192
Even if so, it will still be behind current X3D and most certainly behind Zen 6 X3D. I think Intel needs an answer to X3D technology that drastically lowers memory latency. The current ARL design already has huge issues in latency. I think they will be doing good just to free up the current design, rather on starting with expectations of Zen 5 and expecting latency improvements so drastic in Nova Lake that it surpasses X3D.
Keep in mind, moving from N3B to 18A is not going to give Intel much additional transistor budget to work with (unlike the move to N3B did).
... and this is how people got so disappointed by ARL. You take all the little leaks, add up the IPC improvements you see in each change, then sum them all up to get a really big number ..... and then are very disappointed when the product comes out as all these theoretical improvements don't translate into real world performance.
As I stated above, the additional transistor budget expected by 18A over N3B shouldn't be expected to gain much IPC as cache, logic buffers, TLA, front end, execution units, etc, etc, wont likely be afforded much growth.
I expect some good improvements in some applications if Intel can just get their latency under control. Others (that are already doing well on ARL) wont gain much at all.
I agree, because the days of getting 50% higher transistor budget are ALSO over ;).
OneEng2
981
1,192
If Intel spent 20Bn on GAA with BSPDN, how much do you think it will cost to do CFET with buried power via? It is my understanding that the CFET process will add as many process steps over GAA as GAA did beyond FinFET. Another 20Bn?
The alure of 2x density is a powerful draw though. From what I can read now, it looks like 2030+ for this technology.
511
5,386
4,812
It is 2032 from Imec and 20 Billion is the cost of a single fab the R&D is less the main cost are the Fab and first time ramp cost and stuff
Reactions: OneEng2
Raqia
125
Nova Lake won't have a mont anymore. It will be an Arctic Wolf. The codename change may indicate an entirely different beast.
So of the 3-tiered cores, we have Coyote Cove for P-Cores, Arctic Wolf for E-Cores, and there are also the LP-Cores... Are these rumored to also be Arctic wolf derived and sit separately on the SoC tile as with Lunar and Arrow Lake?
