Page 555 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,373
4,781
In desktop and mobile laptop space, I think Intel Lunar Lake and Arrow Lake will beat Zen 5. I think Arrow Lake slaughters vanilla Zen 4 and 5 in gaming and trades blows with 7800X3D/9800X3D in lightly threaded games and pulls ahead of the 8 core X3D counterparts in heavily threaded games. And I think Arrow Lake beats 12 and 16 core Zen 4 and 5 X3D parts in heavily threaded games mostly.
I can't say about gaming due to ths tiles will add additional latency to IMC <-> CPU but iy should be on par with 7800X3D will definitely loose to 9800X3D
In the server and enterprise space, I think Zen 5 overall wins over Intel Xeon counterparts.
At least Intel will not bleed money like they used to on server for past few years these are actually good in god knows when wendell called it nehlam amd said they should have done it years ago at least Pat's Plan is working somewhat better than last 3 CEOs gotta give him credit
cannedlake240
247
138
If Turin is 30% faster(clocks+IPC) vs intel instead of 50% faster as in the past, will that really change things for Intel? GNR does have a few advantages but AMD also has Vcache that's very useful for many workloads. Also GNR cost vs EMR is important, GNR uses a lot of euv silicon but emr's 2 750mm2 on Intel 7 tiles are also quite expensive...
9949asd
139
What if 9800x3d only 3% faster than 78x3d. 97x is 3% faster than 77x.
Reactions: Wolverine2349
511
5,373
4,781
It won't be 30% tbf on average it will be lot close than that there is also "AI" which AMD will undoubtedly loose to no matter how much they say AMD will trounce intel in NAMD for sure though we will see on 11 October though
dullard
26,189
4,855
I wonder why Intel won't do 3D vcache they have the tech now with Intel 3T and they are using it in Clearwater Forest
I've been wondering that for years. Intel announced it at CES 2019 (with hints about it throughout 2018), years before AMD had 3D cache. But, Intel never released it. 1728321464595.png
Reactions: Schmide and Elfear
Hulk
4,039
I'm showing static clocks @ 5400mhz (at 250w)
What you see in reviews are autoboosting at 200w (stock PPT limit for the 9950X) --> real clockspeed @ stock is only ~4800mhz in Cinebench R23
And like i have been saying from the start, vanilla Z5 stock V/F curve is pretty bad as it leaves alot on the table
Even leaks are showing the 9950X3D getting higher MT score with same PPT limit as 9950X ((even to a larger degreee then what we saw with Zen4)and now the X3D models scale all the way up the power curve)
Wow. I had no idea Zen 5 was clocked so conservatively out of the box.
Hulk
4,039
I think some of my Zen data might not be accurate. If anybody has Zen<5 and want to test please post scores and average clock during the run. I can't let go of these pet projects until they are finished.
Abwx
11,997
4,954
Zen 4 does 482 pts/GHz/core with SMT, in ST that s 371 pts/GHz
The 7700X run at 5.3 in MT and does 20437 pts in Computerbase review, they measured almost 5.3 in Blender, your scores would imply that it run at roughly 5.65 all cores and that the SMT gain is only 23%, and also that Zen 5 best it by 21.9% better IPC in MT.
About all those CPUs ST and MT scores, excluding Zen5, can be found here, the frequencies measurements are scattered in the respective CPUs reviews.
Det0x
1,484
5,089
wow if true
6200/5700 -> ~9% clockspeed regression
+9% IPC for "Gen15" vs Gen14
End results is that ST performance dont really change that much (?)
Will also be interesting to see how this uncore perform in gaming, so far we have seen not too good latency for Arrow Lake
coercitiv
7,464
17,829
The uncore is probably the culprit for the lower IPC uplift (desktop relative to mobile).
jdubs03
1,466
1,036
Wait there’s more… courtesy of wxnod on Twitter.
Showing a 3% lower result in GB6.3 ST vs. the 9950X.
Looking pretty meh.
