Page 557 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,370
4,775
The worst ending for Intel has happened, the reviewer mob has forced them to pre nerf their chips. Add to it the fiasco with Raptor Lake and the enforced power limits on a overclocker + unlocked chip and we get this bad ending.... pathetic.
A K unlocked chip that will be reviewed as if it has no overclocking and the "K" is just a marketing artifact. It is sadly over....
If there is some OC potential to exceed the 14900K, how many of these AMD curve optimizer tuning, command line running and windows reinstalling folks will do the same for Intel, the marketing machine has worked, I'm saddened to know that a focused and timed mob can indeed push a company towards the wrong path.
A core i9 should be the most unleashed chip, with the highest power consumption and performance, the lower SKUs are for everything else. It should be a halo product like the RTX4090, no one complains about the power consumption under load, the same will be the case for the 5090.
The only way for Intel to survive now is to embrace the power consumption, I don't care about that on a high performance desktop BUT they also must deliver a multi generational leap in ST and MT performance to warrant that power draw, in essence they need a RTX-X090 class product with performance so high, no serious person will talk about the power draw.
Like this though, I'm just disappointed and will return in maybe 4 years to see if there is any positive movement.
Conclusion: Stagnation since Alder Lake
Stagnation since Raptor Lake*
coercitiv
7,464
17,829
Sorry, what is APO? I am getting lost in all those acronyms...
Software gaming optimization, they're tuning E core utilization (example - in some games disabling a number of E cores allows the rest to make better use of the shared L2, which lowers L3 hits, which allows better L3 utilization for P cores, and you can see where this is going)
Optimizations are "manual" for each title though, so the software has limited real-world support.
AcrosTinus
221
226
Increasing energy efficiency is great, but the performance itself disappointing.
But what if all these performance numbers are for the conservative default power settings??? It could increase considerably with the 250W power setting.
That might be true but it is all about mindshare right now. Intel might have the higher performing chip at 250 to 300W again but who will test this unlocked chip in that conditions.
The likes of hardware unboxed will put it against AMD, leave the locks in place, throw in some in spec RAM and call the 7800X3D a winner, I can see the headline.
Any benefit this chip has, be it in hardware encoding, chipset, tuning will be smoothed over for the gaming folks. The moment Intel does well, it will be countered with "at an increased power draw, at a higher cost, a the cost of a new platform".
Sadly there is no winning, going for power draw even though you had to impress people with performance FIRST, is intel's downfall.
Most people I know game on an i5 or Ryzen 7 the upper chips should be halo products.
This all started with idiots reviewing the 14900K, a huge chip against a 7800x3D a lower tier chip with half its guts missing. They call it faster but forget to add in the constraint of "just in a particular task". Had they used a overclocked i5 14600K for comparison which would be maybe 3 to 5% slower than the i9, the power draw nonsense would not have happened... It would be more fair, the tradeoff between higher MT and gaming performance against cost would be on Intel's side with older Mainboards and even DDR4 but no one bothered to do this but niche channels...
The media machine worked....
AcrosTinus
221
226
RPL Intel 7 making Zen4/Zen5/ARL on N4/N3B look weak in ST how the hell did we get here P core team needs to deliver something big like 30-40% with ARL or it's meh
They have to go big or go home, Arrow Lake might break their arms, the next Alder Lake+++ will break their neck
Reactions: Tlh97 and 511
19,210
Therefore anyone who's already on RPL has very little incentives to upgrade. I expect the prices won't help either.
But if suddenly RPL prices mysteriously start seeing a downward trend, people may panic and jump ship to either Ryzen or ARL. We just need one more security related performance degrading patch or an advisory from Intel saying that HT must be turned off on Raptor Lake to protect your digital life while on internet :p
Reactions: 511
511
5,370
4,775
They will definitely reduce RPL price after Fiasco if RPL hadn't happened it would not have been this good 🤣
19,210
Also, we don't know how well ARL overclocks yet. The lower power should allow eeking out at least 200 MHz extra on good samples. That's not a nothing.
Reactions: Tlh97
Kocicak
1,177
1,232
I expect the reviews to have the new CPUs tested in both default and performance settings.
If intel chose to show just one power setting in their presentation, it should be the default setting.
tsamolotoff
261
512
Considering that they've got rid of HT to eke out more Mhz in ST and MT this is not very likely. Probably the same OC potential as with AMDs offering on TSMC processes
511
5,370
4,775
I don't think N3B can compete with 6Ghz clocking Intel 7 that's something no one can do outside of Intel Fabs Ghz node skymont is the true chad basically more IPC than Zen 5+ Arl combined and still has few percent left
CouncilorIrissa
784
2,848
I've said this before, but this outcome shouldn’t be a surprise. RPL was essentially a swan song of Intel's approach to desktop CPUs: a monolithic chip that does not suffer from penalties typical to disaggregated architectures (higher mem and C2C latencies), setup with no care for power consumption on a node that clocks sky high like no other, pushed to the absolute limits and beyond of its silicon. It’s a perfect setup for gaming.
poke01
4,788
6,111
Its a real funny sort of situation be in, after finally moving to a new node, Intel got stuck with N3B the worst 3nm node from TSMC. If it was N3E, it would allowed them to clock higher.
