Page 556 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,805
6,131
Wow, this is a total skip generation. Mainly because of the underwhelming P core. If that P core got the 30% IPC boost instead then Intel would have been king till 2026.
19,210
If you are a Raptor Lake user and you prefer stability and lower power, you WILL buy Arrow Lake. Plus, you get Aye Aye as bonus. So I don't see a lot of people skipping this if they can easily afford it. The specint performance is decent I guess. If only AMD had worked a little harder on that...
I do find it funny that ARL is doing its best in CBR24 and POV-RAY. Abwx will have quite a few things to say :D
Reactions: lightmanek
Saylick
4,116
9,626
Yikes, I think the lower peak clocks and the latency regression vs Raptorlake is what’s holding Arrowlake back in gaming. Basically not worth the upgrade over Raptorlake if gaming is your primary purpose. The 9800X3D will likely claim the gaming crown.
coercitiv
7,470
17,851
If you are a Raptor Lake user and you prefer stability and lower power, you WILL buy Arrow Lake.:D
If you are a Raptor Lake user then lower power is not a priority. People who needed stability above all else have already moved to Alder Lake or Ryzen by now, the rest were waiting for more performance... which is barely there. (the numbers are higher but they won't translate in a meaningful uplift)
Therefore anyone who's already on RPL has very little incentives to upgrade. I expect the prices won't help either.
511
5,395
4,817
AVX-512? For the 1-2%. Anyway meh the only good thing is power consumption i guess
511
5,395
4,817
I don't think Jim keller having or not would have made a difference it's the SOC/IMC killing the performance
Jayzen
35
89
51
I was right. Despite the vitriol and censorship that has been directed my way over the past year, I have been right about everything.
Zen 5 was underwhelming.
Arrow Lake was underwhelming.
Snapdragon X was underwhelming.
M4 looks to be pretty underwhelming too.
Kepler_L2
1,076
4,640
AcrosTinus
221
226
The worst ending for Intel has happened, the reviewer mob has forced them to pre nerf their chips. Add to it the fiasco with Raptor Lake and the enforced power limits on a overclocker + unlocked chip and we get this bad ending.... pathetic.
A K unlocked chip that will be reviewed as if it has no overclocking and the "K" is just a marketing artifact. It is sadly over....
If there is some OC potential to exceed the 14900K, how many of these AMD curve optimizer tuning, command line running and windows reinstalling folks will do the same for Intel, the marketing machine has worked, I'm saddened to know that a focused and timed mob can indeed push a company towards the wrong path.
A core i9 should be the most unleashed chip, with the highest power consumption and performance, the lower SKUs are for everything else. It should be a halo product like the RTX4090, no one complains about the power consumption under load, the same will be the case for the 5090.
The only way for Intel to survive now is to embrace the power consumption, I don't care about that on a high performance desktop BUT they also must deliver a multi generational leap in ST and MT performance to warrant that power draw, in essence they need a RTX-X090 class product with performance so high, no serious person will talk about the power draw.
Like this though, I'm just disappointed and will return in maybe 4 years to see if there is any positive movement.
Conclusion: Stagnation since Alder Lake
