Page 433 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
TESKATLIPOKA
2,696
3,260
Arrow lake performance will be very big.. intel has veen good at hiding its true performance
They are masters of hiding the performance. The hid It so good, that they themselves can't find It any longer. :p
Performance wise ST nothing much in my opinion, nT could surprise or not, who knows.
If they can reign in the power consumption, It will be good enough.
TESKATLIPOKA
2,696
3,260
Desktop vs Laptop CPUs aren't the same though. The few % differences in internal firmware, memory latency, binning, idle power differences will all add up, plus motherboard settings which might increase peak power significantly for few % faster performance.
I know, but there was no better comparison available.
TESKATLIPOKA
2,696
3,260
they have to, its on N3B
Not necessarily, If they once more go for max performance, then It doesn't matter If the process is better than what they used with RPL.
Power consumption would be atrocious, just the performance or perf/W will be higher.
Mobile version could be interesting with more limited TDP, although I am not that happy with the old MTL SoC tile.
Then what I see as the biggest problem for Intel is that they plan ARL for both mobile and desktop. At least RPL was made by them. ARL will have only the interposer made by themselves. In 2023 the foundry business made a $7 billion operating loss, then this year and the next It could be only worse.
5,564
4,967
Me neither the Uncore is horrendous Intel 4 CPU themselves are efficient though
Wolverine2349
538
188
86
Rumour has it that bartlett lake is not for regular consumers but for some special vertical like networking or something. So, it may be available only thru some specific oem channels for specific customers. Just guessing.
Also, if it isn’t for the general public, then it may not clock as high as they would want to keep the power usage and heat under control in an industrial setting. Again, just guessing.
Well could buy it 2nd hand from an OEM if they have a 12 p core die on a ring bus.
jpiniero
17,232
7,598
Appears it might be extended to consumers because AI.
IEC
14,608
6,094
12 P-cores necessitates a longer ring bus (if that is what they are using). Which would have a latency impact and make it likely worse for gaming than an 8 P-core part.
511
5,564
4,967
Not really it will be shorter than 13900K die assuming nothing is added cause 4E cores are roughly 1.2-1.3 times P cores so for 4P cores you roughly save an area worth of an additional P cores
jdubs03
1,512
1,098
Looks like we got the full lineup:
Wolverine2349
538
188
86
I have heard Intel 10nm process node is expensive? Is that true or no?
I mean if it is indeed more expensive than TSMC or their 20A node, wouldn't Intel be better off making the 12 P core only model based on Arrow Lake instead of Raptor Cove?
Or is it not true that 20A and TSMC node they are putting Arrow Lake on is less expensive than their 10nm process node?
Or is Intel simply trying to capture the LGA 1700 market and knock out AMD AM4 market segment regardless and they have lots more 10nm capacity so better off to do 12 + 0 on that rather than 20A or TSMC?
DavidC1
2,199
3,358
It would be because it's using DUV but it's a very mature process so switching to a brand new one like 20A or even N3 wouldn't necessarily be cheaper initially. When they mature sure.
It doesn't work like this. The cores are a rectangle. And the whole die needs to be a rectangle. It'll just end up being a slightly smaller die instead. Look at the Raptorlake die.
511
5,564
4,967
Yes it is using SAQP basically to print a pattern they have to go through the process 4 times EUV would have made that 1 times so simplification also 10nm has weird quirk like Cobalt being the
First 20A is a half node like Intel 4 it only contains enough library to make a CPU and minimum IO just like Intel 4 you can't make a Monolithic SOC hencs the derisking of Process basically Intel 4 and 3 are one full node and Intel 20A and 18A are one the later being superset of previous half node also the cost 20A is expensive than Intel 7 but for the PPA it becomes better their foundry cost structure improves why do you think they are raking losses in Foundry it's the hidden truth you need good cost structure if you wanna run foundry they were hiding inefficiency in their foundry for years at least since Brian Kranzich
511
5,564
4,967
It's cheap... but presumably what they mean by expensive is that the yields are still garbage.
The yields are not garbage tbh otherwise we will not see such big dies of EMR even 13900K is a large die i would consider anything above 200mm2 to be large die
Reactions: DavidC1
511
5,564
4,967
Yeah i meant that the die will be smaller cause you saved some area sorry if i sounded confusing 😅
CakeMonster
1,668
845
After the thread priority and core parking drama with AMD, I hope to see some in-depth analysis of the behavior of Arrow Lake when it arrives. Hopefully compared to Z5 somewhat improved/tweaked.
