Page 432 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
851
801
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Wolverine2349
525
179
86
They’d have to go to a mesh interconnect which has significant power and latency consequences.
If they were all P cores say 12 of them, could Intel reliable get them on a singhle ring bus with no clusters like they did 10 on 10900K/10850K with good stability and latency.
Or is it too hard to get more than 8-10 of any core type on a ring bus with good stability. Thus why the e-cores are in 4 core clusters? Or is it because they are a different core type they need to be in clusters but if they were homogenous core type they could fit 12 or maybe 16 P cores reliably on a ring bus without them being in 4 core clusters?
Hitman928
6,695
12,370
Going from memory, around 10 - 12 nodes seems to be the max Intel can really get on a single ring. Anything more than that will need either a dual ring design or full on mesh if you get to many cores. I'd have to look up past designs and commentary on it to be sure, but I don't really have the time/motivation to do so.
511
4,565
4,189
Certainly not in nT.
13100F(4P+0E, 58W TDP -> 75W in Prime95) managed only 8844 points in CB R23.
i7-1365U(2P+8E, 28W sustained) 9576 points in CB R23.
So higher score at 1/2 TDP or less.
These E-cores despite their disadvantages are not just for show.
I meant for area comparison 4 ecores = 1.2-1.3X P cores but yeah E cores are not meme cores people have been saying Chadmont will just show us the power ⚡
Reactions: TESKATLIPOKA
DavidC1
1,854
2,983
They probably can. The cluster approach saves area, and they can easily port it among different segments such as laptops, servers, and desktops.
Needing only one ring stop would be one reason they use it on the desktop version.
Not having a dedicated high performance version is likely just to prevent cannabilization between segments plus avoiding extra cost on a new SoC.
Desktop vs Laptop CPUs aren't the same though. The few % differences in internal firmware, memory latency, binning, idle power differences will all add up, plus motherboard settings which might increase peak power significantly for few % faster performance.
Wolverine2349
525
179
86
Yeah that makes sense. And 10-12 nodes. Does a 4 e-core cluster count as 1 node? Thus Intel has 16 e-cores on Arrow Lake and Raptor Lake because they have 8 P cores and each e-core is a 4 core cluster as once node so thus 12 total nodes?
Wolverine2349
525
179
86
Yes and I really hope Intel makes 12 Lion Cove cores of Arrow Lake. I would buy ina heartbeat. Could run WIN10 or 11, no Process Lasso, excellent RAM overclocking lower power than rumored 12 + 0 Bartlett Lake and 2 dedicated X4 NVME lanes to CPU.
I am praying and hoping maybe it surprisingly shows up at launch as maybe the Core Ultra 286K or 295K?? or maybe 285KG woith G being for gaming
Probably not but I really hope.
Intel could really put a dent in AMD if they did such a thing especially with Zen 5 underwhelming flop. Lots of people are not fond of dual CCD and especially the worse scheduling issue flop and Big.Little.
Though Intel financial situation would probably make it harder, but Intel is big and mighty Intel and they laid of employees to cut costs so they are still fine. Plus 10nm process node costs more than their 20A and TSMC so they could do 12 P core Arrow Lake die in addition to the 8 +16 hybrid die cheaper than 12 P core plus 8 + 16 Bartlett/Raptor Lake.
dullard
26,017
4,629
The number of commonly used software that uses more than 8 cores, but fewer than 13 cores is what? None? Close to none? Maybe a specialized game if you crank up the complexity just right?
Your hypothetical chip will do very well if you can find software that needs 10 or 12 cores. No less or no more. But it would mostly be a hammer looking for a nail. If it needs 8 or fewer cores, then 8 powerful P cores is better than 12 weaker P cores. If it needs 13 or more cores, then 8+8 or the rumored 8+16 will destroy that 12 P core CPU.
What you fail to think about is how having 12 P cores makes each P core much slower. Much longer latency with such a long ring. An imaginary 12 strong P core chip just doesn't fit with Intel's designs.
Thunder 57
4,035
6,749
Thank you for explaining it better than I could've. There's just no market for something like that.
Wolverine2349
525
179
86
There are lots of software namely games that benefit from more than 8 cores buy fewer than 13.
Cyberpunk TLOU PART 1, Stanfield, star Citizen, Spiderman Resmastered, Dragons Dogma 2.
12 p cores no need for cross latency penalty and no big.little scheduling quirks.
Intel had it with Comet Lake.
I hope they make it with Arrow Lake. But does not appear so at least not initially this Fall.
Thunder 57
4,035
6,749
Aren't you making dullard's point? If it made such a vast difference as you seem to suggest it would, you would probably be running a 10 core Comet Lake. Instead, 8 faster P cores perform better.
AcrosTinus
221
226
AnandTech gaming benchmarks. An absolute bloodbath. At this rate, ARL is gonna run circles around the competition without breaking a sweat.
People are sleeping on ARL. Intel has from my perspective a quite simple task of using less power and delivering maybe 5 to 10% more client performance, meaning general purpose performance.
I don't know how big the tile latency penalty will be on desktop but it will be way lower than Zen due to the active substrate.
My crystal ball is telling me 7% better gaming and unleashed 10%.
DavidC1
1,854
2,983
The "much longer latency" only applied with server chips that needed dual ring stops because it had to hand off data from one side to the other. 12 single ring(or dual bi-directional ones) won't have a big latency hit. The thing is, the single ring only stops at maximum 12 or so.
Lol. Next week you are going to call doom and gloom for Arrowlake aren't you?
You do know Zen 5 has seemingly exactly the same IO die and configuration but increased cross-CCD latencies significantly?
Implementation>>>High level details
Don't judge there will be a tile penalty yet. I think it'll either be very little, or even nonexistent. Meteorlake is a mobile part with significantly higher memory latencies, much conservative clock speed ramp, much slower waking from sleep and other unknowns.
I'll give you another example of implementation being king. Lakefield had a 3D stacked Foveros die meaning it should have been super low latency for high performance, and super low power.
Yet it was slow as molasses in both ST and MT. Jasperlake, the dedicated E core low cost/low power platform using the same Tremont core as the E cores in Lakefield outperformed it in ST, despite LKF having the Sunny Cove P core. And the battery life was no better than previous generation -Y chips.
Reactions: AcrosTinus
Wolverine2349
525
179
86
It makes a difference and it will grow.
10 p core comet lake please. IPC is so far inferior and behind even Zen 3 and stuck at PCIe Gen 3 lol.
But the gaming market unfortunately too small for intel to care or care about those big.little scheduling quirks.
I wish they had a 12 p core ARL coming but doubtful certainly not right away if ever. It is what it is.
DavidC1
1,854
2,983
They are consolidating things that I think they shouldn't consolidate.* You should expect their finances to drastically improve before they even think of what they are doing. They cancelled Innovation event, which in terms of absolute cost is probably minimal. Few million dollars? Really?
New die and stepping will cost few hundred million dollars.
*Falcon Shores hybrid CPU/GPU cancellation was a stupid idea. AMD's MI300 made $1 billion a quarter in it's first year. The single product makes more money than Intel's many previous huge acquisitions did.
DavidC1
1,854
2,983
Rogue River, yes. That's a nice surprise if so. RR should employ Artic Wolf E Cores.
Regarding this, I think Intel regularly flushes "moles" out.
This means Exist50 is wrong on this. I've seen it repeated many times. They get a reliable leaker, and they are:
a) hired
b) discredited
c) wrong significant amount of the time
b) is what's happening now. Ashraf Eassa was another leaker, he was here in AT forums too. And a) was what happened to him. Intel "snapped" him up, that's all we know.
Guys like MLID, RGT, Adored is not reliable enough for people to trust. When you have real sources then you are right 100% of the time. It only takes 1 wrong info to start discrediting them.
Wolverine2349
525
179
86
Which things are they consolidating that they should not in your opinion?
And yeah their financial situation does need to improve for any hope for them to do the product I would like.
511
4,565
4,189
The substrate is passive interposer
511
4,565
4,189
Any idea if Bartlett lake will have avx-512 enabled since its all p cores?
It is for NEX but they should enable it and people will buy it easily that one VP who pushed thed Idea of Disabling AVX-512 needs to get laid off we were fine with Only P core AVX-512 and the decision needs to be reversed
Wolverine2349
525
179
86
ARL's interposer sits on top of a substrate.
ARL is using a newer interconnect fabric that should address the issues (like high latency) with the one in MTL. Btw, ARL is tiles-over-interposer-over-substrate compared to Zen's much older chiplet-over-substrate design. And the interposer is passive in ARL. CWF is the first one to get an active interposer (with adm cache).
After years of lagging behind competition, they now have a good opportunity. Lets hope they don't squander it.
With great power comes great responsibility! :)
I think bartlett lake isn't for general consumers (not sure).
Is 12 p cores on a ring bartlett lake coming or just a rumor? I really want it if true. The new stepping should hopefully fix degradation and stability issues.
Even 2025 release it should age well given Zen 5 underwhelming uplift and Arrow Lake better but still clock regressed design.
And it's more than 8 cores modern IPC on a single node. Yes I want it if true!
Henry swagger
512
313
Arrow lake performance will be very big.. intel has veen good at hiding its true performance
