Page 256 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hulk
4,099
It wouldn’t surprise me if the results end up pretty close to RPL-R while using half the power. I don’t think MT scores are that important past a certain point. It will become important to Reddit once Intel loses the pointless CB R23 supremacy. It's going to be so annoying seeing r/buildapc re-orient themselves and move the goal posts.
For what it's worth, a 14900K isn't actually running at 5.7ghz in CB R23 unless it's pulling well over 300W. I also only see a regression of 15% without HT in CB R23 (I go from 40K to 35K when I disable HT).
You make some good points. The one regarding power is critical and one that many people who do not own a 14900K or 13900K haven't experienced. While a 14900K can boost all the way to 5.6 or 5.7GHz all core it takes a lot of power and a 360 AIO or custom loop to actually achieve.
So in reality I am comparing what a 14900K can theoretically do against what hopefully a "15900K" can do with sane power draw and cooling.
Like you I'm also running my 14900K with HT off. The 16E cores are more than enough to handle any "overflow" from the P's and the additional heat/voltage required for the brief moments HT may be in operation aren't worth it. I've been down that rabbit hole and it ain't fun. Also I don't allow my system to single/dual core turbo, only time it every happens is idle when background tasks are going on and the voltage spikes can't be good for the CPU, yeah I know current would be low but still I don't like my CPU going over 1.3V. I'm set for 5.5/4.4 and 200W. It runs cool and stable. My longwinded point is that 5.5/4.4 is really what ARL needs to compete with because that is the "sane" top end of RPL. Anything higher I consider overclocking.
All that being said, 40,000 is what we're used to seeing for the 14900K so that's what most people will compare ARL against. Though I see people over at the Overclockers forum running their rigs with chillers day-to-day who are achieving 46,000 higher, but those people are a different breed...
At the end of the day I think we're going to be seeing ARL besting RPL by 10 to 15% in ST and losing or perhaps breaking even in rendering or other perfectly multithreaded applications/benches. As you noted, probably at much lower power levels and thermals. Meaning a "better" CPU at the end of the day. Also, since many applications today still only rely on <8 cores I think we're going to see a nice uplift from that 10-15% ST improvement in many applications.
If this is the ARL that we see then it will be very competitive with Zen 5 ST but Zen 5 and it's 16 full size cores should be able to beat ARL in MT rendering.
In conclusion, I agree with you in that I think we're looking at ARL having a nice ST bump, say 12%, and perhaps holding the line in MT with much better power draw/temps/heat.
This is why I had been speculating ARL might be 8+24 as that would take care of any CB concerns Intel marketing might have. I am also wondering if we might be surprised and be seeing a 6+24 Intel part eventually?
Hulk
4,099
I have been thinking about the rumored removal of HT from ARL and what impact and why it will have on ST performance?
AFAIK HT was originally implemented on the P4 to "reclaim" lost cycles that occur due to pipeline stalls, which could be especially costly with the P4 since the last incarnation I believe had a 31 stage pipeline. Since Raptor Cove currently is a HT CPU that would seem to indicate that pipeline stalls are still an issue and the front end is not being utilized as effectively as it could be, hence the inclusion of HT? Will Intel have to seriously increase the capacity of the front end, in particular the OoO scheduler and other related logic, to saturate the CPU without employing HT?
A HT CPU could be viewed as a hybrid cpu with the P core being the physical core and the E core the logical one. Intel seems to be simplifying things by designing both P and E cores for ST performance, while aiming the P cores toward maximum performance and the E's at maximum performance for a given area.
I know there are many around here with deep understanding of CPU architecture and I'd appreciate hearing (reading) your thoughts on this?
adroc_thurston
8,551
11,282
newer nodes like N3B/20A can't be expected to clock as well as N4 during the first iteration.
Yes they are it's foundry stuff.
Please consult TSM yield ramp charts.
No they're cutting it off because Apple has no SMT.
It's that simple.
FlameTail
4,384
2,762
Apple M series silicon are high performance parts. LNL doesn't stand a chance against M series cpu performance. It's more of a niche product designed for low-power ultra mobile market.
Weird. An ARM chip like Snapdragon X Plus would better serve that segment.
adroc_thurston
8,551
11,282
