Page 258 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
tamz_msc
3,865
3,730
no.
SNC-ish.
I should have been more clear. Assuming perfect scaling with frequency, Gracemont in Alder Lake already matches the performance performance clock of Rocket Lake. Gracemont in Raptor Lake should be low-single digit percentage higher perf per clock than Gracemont in Alder Lake owing to the doubled L2$ per cluster.
It's not big deal for Skymont to match the perf per clock of Golden Cove.
I'm taking the figures from Andrei's testing of SPECint_rate_2017 1T.
poke01
4,863
6,193
I’m as you guys know am very excited for Arrow lake because Intel is finally will be using leading nodes late this year and early next year.
Bring on the Arrows⬇️⬆️➡️⬅️
naukkis
1,030
854
Except for all those workloads that have high latency but also need lots of brawn like relational DB's or generally anything in the server space that is dealing with I/O.
I cant wait for 1000's of terribly performing kubernetes containers running on 1000's of average performing core. But im cloud scale!!!!! 2024 IT is lit.
Intel big cores are just wasted in their server grade cpu's - they are enormous as they are designed to run 6GHz and they are clocked about 3Ghz in their big configurations. Running them at 3GHz with HT means that their single-thread performance is actually lower than their small-core rivals. Even Intel own E-core based solution might actually have better single-thread performance in high utilization situations than their big-core solutions - Intel is sure doomed if they don't change their mindset of designing cores that their customers actually need. Their big-core with HT solution ain't competitive in most of designs they try to sell.
adroc_thurston
8,551
11,282
No.
They're just not particularly area/power efficient which is an overarching IDC problem and not really unique to server.
Yeah about that.
God no, Atom caches are pretty dog, that L2 in particular is slow and tiny.
Reactions: Tlh97 and Joe NYC
naukkis
1,030
854
That's absolutely not core's fault. Intel does pack them that way for being easily add 4-core complexes to existing ring/mesh networks but nothing is in their way to implement different L2-cache versions. They could for example made 60-core e-core solution which have fast 12MB L2 per core in size of their Golden-cove solutions and after that there probably could be quite different performance profiles - Intel solutions might actually be competitive with other vendors.
adroc_thurston
8,551
11,282
No, Atom cache is just made to be slow and low power (ish).
I don't think we're going back to Penryn but I digress.
You're overthinking Atom capabilities hard.
naukkis
1,030
854
Yeah, Intel should probably just made GoldenCove much bigger and run 40 of them @2Ghz with at least 4-way SMT to be competitive with rival's smaller cores. With such a strategy they are soon out of business. Actually they already are - have to wonder which parties are actually buying their rapid-solutions as they basically aren't competitive in any workloads - either for cost, energy-efficiency or packing density - Intel probably just gives them away to give a appearance that they are still in business.
Joe NYC
4,216
5,818
New performance leaks for arrow lake just drops, MLID as usual:
Arrow lake = Meteor Lake + 25-35% ( performance )
Discuss
ST? MT? If MT, then comparing what to what?
I don't buy ST improvement of 25-35% at all.
On MT, higher number of cores (8+16 or 8+32) combined with higher power limit than MTL will result in higher MT performance. 25%-35% may be within realm of possibilities of trivially parallel workload.
tamz_msc
3,865
3,730
You are underplaying the capabilities that Intel has when it comes to architecture of the building blocks in terms of their granularity.
Intel can decide which core to put in a mesh building block , and route them with their corresponding MCs and other cores at the individual core level.
There is no architecture-specific restriction on the size of the L2 in this approach.
Goop_reformed
316
341
No.
Yeah about that.
Alright, who will win Zen 5 or Arrow Lake?
It's literally what he said in video and in the slides. No infos about st or nt
moinmoin
5,248
8,463
Probably something similar to this. We called it "reverse Hyperthreading".
Oh ok, it's that old stuff we already talked about in like a dozen threads over the decade. Thanks. Would be nice to see it being realized at some point, but seeing how it reliably appears and disappears again and again the chances are slim.
Hulk
4,099
He's just shooting in the dark. He's being purposefully fuzzy just to cover his back if his prediction fails. Even if ARL performance falls out of his predicted range, he'll just introduce new elements like clocks, interconnect, packaging, cache performance, etc, to justify his claims and still say he was right. We just need to take this with a bucket of salt.
Exactly, this is pure BS. The only information provide in this "leak" is 25 to 35% performance uplift over Meteor Lake.
First, he doesn't specify clocks so we have to assume this is Meteor Lake mobile clocks compared to Arrow Lake desktop clocks and mobile memory subsystem to desktop! We know this is HUGE. That could be +20% right there is terms of performance uplift with NO architectural changes, just faster desktop memory and CPU frequency, which of course is normal for even the same generation of CPU.
Second, he's comparing tiled to tiled so no tile penalty in this comparison.
Unfortunately he made a 22 minute video that tells us absolutely nothing.
All of the obstacles I've documented Intel has with besting Raptor Lake performance, tile latency, 6+GHz Intel 7 frequencies, lack of HT for MT performance, are still there with no idea of how they will be mitigated.
At the end of the day you can buy a 14900KS next week and with good cooling get 5.9GHz all-core and 6.2GHz dual core performance right now. My curiosity remains as to how Intel accomplishes the magic act of surpassing the raw performance of that CPU?
If Arrow Lake is actually 8+16 I stand with my prediction that is will have ~15% better IPC for 5 to 10% better overall ST performance and will at best tie Raptor MT performance in well-threaded applications. I will also add that if this is the case and it is more efficient, easier to cool than Raptor Lake then this is a "better" part than Raptor Lake, but the numbers will be less impressive than actual day-to-day use mainly due to the fact that many apps still rely heavily on ST performance, and any decent air cooler will be sufficient.
FlameTail
4,384
2,762
MLID viewers must be having extreme chronic high blood blood pressure due to all the salt they take...
