Page 260 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,754
12,500
Gaming is 23% above their current MTL iGPU average, beating most of the tested 780Ms. CPU is normal tho.
Gaming with the iGPU is indeed higher. Wouldn't surprise me as Intel has been improving their drivers quite a bit. Still have some ways to go but reports are that it's much better than it was.
mikk
4,333
2,413
It's performance is literally within +- 1% of the average of all of the 155Hs they've tested, so it's not the fastest. . .
It's 8% faster than the second fastest 155H in the CPU performance ranking and 16% faster than the second fastest in the gaming ranking.
For battery life they only tested Wi-fi and it's good but nothing special. Not sure how you are getting the conclusion you did.
This is a conclusion from all Meteor Lake battery life tests. There is a clear pattern that Meteor Lake has a superior battery life over Phoenix.
Hitman928
6,754
12,500
Eh?
This isn't all of the 155Hs they've tested though. It's just a small sample included in the list which is why they show the average of all their tests, which like I said, shows this MTL sample being right in line with the average 155H performance. You can easily add additional samples to the list to see that there are multiple laptops with the 155H that have higher performance than this sample. It's really just about how much power the chips are allowed to consume when plugged in that determines which model will have higher performance. The Lenovo has average power consumption for 155H laptops and so it gets an average performance rating.
You're going to have to show receipts on this one because I haven't seen such evidence. I'd say they're roughly in line with each other. It's hard to give a more firm conclusion given that battery life is a system level test and a ton of variables come into play.
tamz_msc
3,865
3,730
Actually, it is not completely unrealistic to extrapolate that if Skymont is 20% higher ST perf than Crestmont - which to me is a reasonable assumption - then Lion Cove will have to be roughly 25% higher ST perf than Redwood Cove. If Lunar Lake is indeed 1.5 times faster at CB R23 MT than MTL-U that is.
Reactions: Henry swagger
mikk
4,333
2,413
That's 10K points in CB R23 (MTL-U - assuming Core Ultra 7 165U) -> 15K points in LNL.
If that is indeed true, then it'll be just 1K points shy of the Ryzen 9 7940HS and similar to the Core Ultra 7 165H.
This score is way too high if it runs strictly at 15W without boost. How do you get a 15W score from MTL-U without PL2 boost? Do we have a 15W score from RPL-U? A 50% speedup is quite good however given that LNL won't have SMT which hurts in Cinebench and 2+8 compared to 4+4 isn't much different in multithreaded apps.
Philste
308
486
That LNL result sounds really good. It's 8 vs 12 (or even 14 if LPE-Cores work for Benching in MTL) Threads afterall. My personal guess is that SKT is the bigger IPC jump of the 2.
poke01
4,863
6,193
M3 performs extremely well in the battery test against MTL. Lunar Lake HAS to match or exceed M3. Since both are N3B, if Intel fails then the architecture is 100% at fault this time but I have high hopes they will succeed.
FlameTail
4,384
2,762
There is no way LNL is going to be more efficient than M3.
tamz_msc
3,865
3,730
I think Bionic_squash is comparing the SKU TDP, not the actual power levels at which the benchmark is being run.
Reactions: Tlh97 and Hulk
CouncilorIrissa
788
2,855
Also, now we can use M3 MacBook Air to heat water or coffee, and keep our room warm in winter, and can also use it for some cooking purposes as it runs hotter at 114°C (237°F) compared to raptor lake cpus!
Here' the link.
Looks like LNL may actually easily beat M3 in efficiency after all!
Breaking news: passively-cooled CPU on a much more dense process runs much hotter than an actively-cooled CPU!
FlameTail
4,384
2,762
Here' the link.
What does temperature have to do with efficiency...
19,218
More temperature would reduce the efficiency and waste more power. People were not too happy with Zen 4 bumping up against 95C. Apple engineers must be smoking something to let their CPU go above 100C. Either make a better, heftier thermal solution to sustain such temperatures or clamp down on them before they go out of hand.
Reactions: SiliconFly
