Page 259 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
adroc_thurston
8,541
11,279
There is no architecture-specific restriction on the size of the L2 in this approach.
Yes there are, only so many ways/sets possible until power goes boom.
Zen5 may take the overall performance crown, but not by much I guess. The difference should be in single digit. I'm thinking like 5% maximum.
You're funny I'll give you that.
RTX2080
348
551
Lion Cove IPC and general architecture testing completed
Hmm... It's a long story
It is a tock.
But like Meteor Lake
I think these two core are more inclined to power
Instead of peak performance
It is also necessary to carry the latency penalty of chiplet D2D FDI.
It means that the score running, especially the desktop end, may not be obvious.
However, the overall experience (heat dissipation, noise, responsiveness, weight) of the mobile terminal will be significantly improved due to the increase in perf/w.
Even the endurance may need to be added with some oil....
I think MTL/ARL will be very good lesson
So LionCove would have major archtecture changes which would be enough to make ARL being a "tock" and more IPC but still heavily inclined to efficiency. Sounds like clock regression is inevitable. Would MLID's "25%-35% more perf on same core count" being true?
coercitiv
7,484
17,882
If only Intel told us that Lion Cove would be optimized for power efficiency, then we would not have to do all this guessing games based on MLID beads and tarot cards. Like, they could have mentioned it casually somewhere, even in a leaked slide for some other product. /s
19,217
Just poach some dang good engineers and let them take the lead instead of wasting time learning expensive lessons.
(in an exasperated Napoleon Dynamite tone) Intel, gosh you suck!
Reactions: Elfear
tamz_msc
3,865
3,730
So if you're going for a fatter -mont core without being as fat as -Cove, then just readjust the core count accordingly while increasing L2$, within bounds of course.
That is what the Hot Chips slide is essentially saying.
19,217
My curiosity remains as to how Intel accomplishes the magic act of surpassing the raw performance of that CPU?
I would think Intel would only be concerned about surpassing 14900KS performance with the 15900KS. So they've got until March-April 2025 for that. Plenty of time. It also lets them sell more of their 14900KS stock for those who already have a Z690/790 mobo and it just makes more sense for them to upgrade rather than change the entire platform for almost no gain in 2024.
Reactions: Hulk
maddie
5,204
5,613
Just went thru more RU stuff. It actually appears to be on track. Attached a RU patent filed in 2020. If RU appears in Nova Lake, and if it works as advertised, it might be huge. They casually claim an increase of 3X to 4X ST perf!
Link: https://file.io/yaUy4MhWhJJR
Work started on this in 2008. We should also remember that quite a few of the majors were invested in SoftMachines before Intel bought them outright. I would also think that if the tech is feasible, we will see it in some form in other company designs.
If I remember correctly, Intel was not one of the early investors.
Hulk
4,095
True. But the 13900K was more performant than the 12900KS and the 14900K was more performant than the 13900KS (same ST frequency, faster MT).
I will be of the opinion that if the "15900K" is less performant than the 14900KS then ARL was a step back in terms of performance.
Reactions: Tlh97 and Elfear
Joe NYC
4,215
5,818
Just great. Olrak put out a public Google Doc where everyone and their mothers can put in their guesses. There’s even a familiar person(s) whom we have in these forums. Now, all the Youtube “leakers” are going to be running around claiming “exclusive “ sources with this info…
From the spreadsheet:
RPC - I am assuming Raptor Cove - from Raptor Lake Refresh
LNC - I am assuming Lion Cove - which is expected to be the P-core of Lunar Lake
What is the name of the P-Core in Arrow Lake? I am assuming it is not LNC. I was assuming it is is a derivative of Redwood Cove...
But then, the name of the spreadsheet tab is: "Arrow Lake-S Speculation"
I am a little bit confused here...
FlameTail
4,384
2,762
LNC - I am assuming is the Lion Cove - which is expected to be the P-core of Lunar Lake
Arrow Lake P-core is Lion Cove aka LNC
Reactions: Tlh97 and Joe NYC
FlameTail
4,384
2,762
They should also add a tab for upcoming ARM cores (Cortex X5, Apple A18, Oryon Pegasus etc...)
mikk
4,333
2,413
Lenovo Yoga Pro 7 14 with Core Ultra 7 155H tested from Notebookcheck: https://www.notebookcheck.net/Lenov...Intel-Arc-confronts-Radeon-780M.810926.0.html
This is the fastest Meteor Lake so far on Notebookcheck. Battery life WiFi Websurfing is quite good as well, there is clearly a trend that Meteor Lake has a superior battery life over Phoenix in most of the typical laptop workloads like office, internet, video playback. This is where Raptor Lake suffered.
naukkis
1,030
854
I speculated in risc-v threads that cpu designs should go towards split register file designs. VISC is nothing more than split register file core with software abstraction layer - which isn't way I see split register cpu should be made but instead it should rely on ISA that allows using split register files efficiently. CPU front-end have to see which instruction paths share which parts of registers. I really don't see that Intel could make that happening efficiently on x86 without ISA changes.
dullard
26,196
4,868
MLID viewers must be having extreme chronic high blood blood pressure due to all the salt they take...
If only someone made a thread that shows whether or not his claims were accurate. Instead, we have a thread listing that his claims aren't leaks. Oh well.
Reactions: Thibsie
Hitman928
6,754
12,500
It's performance is literally within +- 1% of the average of all of the 155Hs they've tested, so it's not the fastest. . .
For battery life they only tested Wi-fi and it's good but nothing special. Not sure how you are getting the conclusion you did.
Reactions: Tlh97 and Thibsie
Philste
308
486
Gaming is 23% above their current MTL iGPU average, beating most of the tested 780Ms. CPU is normal tho.
