Page 261 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
19,217
Which law of electronics is this?
The reason why the power-consumption is increasing with temperature has to do entirely with the static leakage power consumption of the CPU (it is independent of clockspeed, solely dependent on temperature and voltage) and a phenomenon known in physics as the Poole-Frenkel effect.
Thank you for asking. So now I know about the physics behind it too.
Reactions: Tlh97 and FlameTail
19,217
By the way, temperature is also the reason extreme overclockers need to use LN2 to hit otherwise impossible frequencies. At subzero temperatures, leakage current is reduced, less power is wasted as heat so more of it can be used to drive higher frequencies.
Reactions: pcp7
mikk
4,333
2,413
Here is a Cinebench R23 result from an Ultra 7 155U, unfortunately they haven't logged the power usage.
Reactions: lightmanek
naukkis
1,030
854
Actually higher leakage in cpu means higher clocking potential. Cpu manufacturers sometimes give golden overclocking samples away that are way too leakage to be sold. Metal resistance will grow with temperature so keeping silicon as cold as possible gives transistors more current to switch - basically rising their max operating speed.
poke01
4,860
6,192
More temperature would reduce the efficiency and waste more power. People were not too happy with Zen 4 bumping up against 95C. Apple engineers must be smoking something to let their CPU go above 100C. Either make a better, heftier thermal solution to sustain such temperatures or clamp down on them before they go out of hand.
I think those sensors are heat spots don’t mean much. Why? Because I had an M3 MacBook Pro machine to test and when it go to 100C, the back of the laptop was still a lot cooler than say a 12th gen Intel U series laptop. I seen Intel laptops that go to 90C that are much hotter on the backside.
The MacBook Air doesn’t go past 45C with regards to the surface temperature. It looks like Apple is making sure that to stay below 45C. I
Hitman928
6,754
12,500
Basic physics. Efficiency = work done/energy spent
Waste heat drastically reduces efficiency. This they usually teach in 8th grade.
Temperature isn’t 1:1 with waste heat though. You can have a super efficient processor that runs at 100 C and a horribly inefficient one that runs at 65 C. You have to take into account the effectiveness of the cooling solution and how much work is being done (i.e., how high of performance is being reached)
Basing a processor’s efficiency on its operating temperature makes no sense.
coercitiv
7,484
17,882
Except you weren't talking about waste heat with your original post, but rather package temperature (or hotspot temp), which is not exactly the same thing. Meanwhile @igor_kavinski was probably talking about the relation between chip temperature and leakage power, which is wasted energy that scales with temperature delta over ambient.
Indeed, modern laptops use external sensors in combination with package readings. Allowing the chip to reach very high temps has the disadvantage of increasing waste heat (see above) but the major advantage of increasing heat transfer. One could call it "cooling overclocking" as the cooling solution will dissipate more heat when the chip is hot, therefore allowing for longer burst performance while the chassis isn't warm enough to trigger throttling.
As an interesting finding, I noticed my Lenovo laptop become noticeably more aggressive in ramping the fans after installing their power management app (or updating the UEFI, not sure). At first I was annoyed, it seemed like such a random thing to do, even when CPU temps were very low. After more observations through trial and error, I noticed the fan was more likely to ramp up when battery temp was high, the app even has color coding for a battery temp sensor. It turns out they might be trying to keep the battery at low temps to prolong it's life. Interesting if true, though I never found out if this is the only reason for the change in cooling behavior.
Doug S
3,832
6,766
The only useful measure of waste heat in a laptop is its power draw, because every watt the laptop (CPU, GPU, DRAM, NAND, display, etc) draws is emitted as heat.
A laptop drawing 5 watts could have a CPU hitting 110C if all that power is going into a single core, while a laptop drawing 50 watts might never exceed 50C depending on sensor placement and how much of the chip (other stuff like DRAM & NAND) is drawing lots of power.
Ideally you'd design it to disperse the heat evenly. That's not practical to do (i.e. having the display surface emit equal heat to the bottom of the laptop) but if you did you'd be able to draw more power without it seeming uncomfortably warm to the touch. Or warm at all, since basically anything under body temperature will be removing heat from your body not adding to it.
Hitman928
6,754
12,500
It's very simple. As temperature increases, a processor's efficiency decreases. Cos' some of the power thats consumed by the cpu is converted into waste heat instead of getting work done.
In simple words, let us say a cpu is running at 40°C. When the cpu has more work to do, it speeds up which in turn draws more power. If the temperature increases to 100°C, some of the power that is drawn by the cpu is actually converted to waste heat (60°C in this case) instead of getting useful work done. This reduces efficiency.
In other words, for every watt the processor consumes, it's expected to get certain amount of work done. When the cpu is running slower, most of the energy consumed is actually used to get useful work done and very less energy is converted to waste heat. When it's running very fast, a lot more energy is converted to waste heat compared to the amount of energy used to get useful work done. More the heat, less efficiency.
No, you don’t understand how it works. You have several replies after your original post about the M3 temperature that explain it, I suggest you re read those replies.
Hint: two CPUs that consume the same amount of power are producing the same amount of waste heat, the amount of work they are doing makes no difference to how much waste heat is being produced.
DavidC1
2,181
3,328
Actually, it is not completely unrealistic to extrapolate that if Skymont is 20% higher ST perf than Crestmont - which to me is a reasonable assumption - then Lion Cove will have to be roughly 25% higher ST perf than Redwood Cove. If Lunar Lake is indeed 1.5 times faster at CB R23 MT than MTL-U that is.
Lunarlake's Lion Cove P core does not have Hyperthreading.
Plus it says on the leaked slides that the "E cores are prioritized for lower priority tasks", and doesn't even share the L3 cache with the P cores so the P might have to do extra work.
One thing is they can improve greatly at the 15-20W mark where Meteorlake severely underperforms.
It doesn't have to be all about the architecture.
-Next gen process + TSMC's process more suited for lower power
-Delays on Meteorlake and sub-par tile implementation
-Improved uarch
Complex silicon chips have variability beyond the silicon itself. The unknown variable that we cannot calculate for exists in the capability of the team and it's management to carry out the goals of the project.
poke01
4,860
6,192
All this cos I posted a link saying a M3 MacBook Air runs hotter (at 114°C) compared to competition! 🤔
You seem to confusing CPU hotspots with the surface temps of a laptop. The M3 Macbook Air will be much cooler than any MTL laptop when resting on a lap/holding it, despite the "higher" CPU temps.
You can have a CPU that goes to 100C(in this case 114C) and uses only 22watts and on the other hand have an Intel CPU got to 90C but it will be hotter to handle because of more energy/watts it uses. I think MTL chips can go up to 65 watts and be under 100C. You cannot determine efficiency from temperature but from energy used.
We had the same song and dance with the M2 Airs and frankly Apple's throtting will kick in before any real damage happens. I have seen no reports of anyone getting burnt from a M chip.
Hitman928
6,754
12,500
Actually you don't. Where do you think the heat is coming from?
You’ve already got this information if you’d read through all the replies, but here’s a link to a free MIT lesson on the subject:
Efficiency does not decrease all that significantly with increased temperature and there is no correlation between operating temperature and efficiency between different chips.
maddie
5,204
5,613
You always have wasted energy but the % increases as the temps increase. It's not simply that you waste more as more work is done, which by itself does not lead to less efficiency. Electron mobility and such.
DavidC1
2,181
3,328
We would still have to account for the OS.
The performance/watt doesn't matter as much as the battery life.
In the Kabylake generation, ARM platforms were roughly 50% ahead in battery life per WHr. This is the critical part they need to improve. They fell in efficiency with the post-Tigerlake parts.
They may never be able to reach MacOS levels of battery, but reaching WoA levels for browsing/video playback would be an important step, dispelling the widespread erroneous notion that ISA is somehow responsible for battery life differences(yet again).
What are you talking about? Processors are by definition 100% "waste heat". They are same as electrical heaters. The definition of "efficiency" for a CPU is performance per watt, or how well it performs per watt.
The M3 Pro absolutely KILLS it in that regard. It uses power like a "U" while performing like an H in both single and multi-thread. The gap is akin to Prescott Pentium 4 versus Pentium M,
-Except in this case the "Pentium M" also takes the performance lead.
-Except that the "Pentium M" is also beating the second best(AMD) in perf/watt by a huge margin too. Third obviously being Intel.
Reactions: majord
FlameTail
4,384
2,762
I know that. No, my question was- what is reason efficiency decreases with increasing temperature. Igor Kavinski gave the answer.
DavidC1
2,181
3,328
FinFET CMOS has lot less leakage than in previous generations.
For a simple example my R9 290 mining system I could reduce power consumption down by 30W when decreasing the temperature from 95C to 70C.
On the "Polaris" RX 4xx/5xx GPUs, decreasing the temperature by 20C reduced power by less than 5W.
Intel results show that by 90nm, gate leakage was already becoming a significant factor, hence the introduction of High-K dielectric at 45nm which reduced gate leakage to almost nothing.
The SOI process in AMD processors brought benefits, but FD-SOI was the real kicker. But instead of FD-SOI, the industry went FinFET, which allowed most of the depleted channel benefits of FD-SOI while improving characteristics + performance vastly in other metrics while being easier to implement.
The final play in this journey is the Gate-All-Around, which encapsulates the channel on all four sides, versus FinFET, which does it for three, hence the "most of the benefits".
What I was referring to but as pointed out in previous replies, the increased temp might be just at the particular hotspot being measured so maybe the entire chip isn't getting that hot.
If people think the MBA reaching 115C is a problem with such an efficient CPU, I'd love to see how it performs if we replace it with an AMD one, or worse Intel H!
Apple may have screwed up on the laptop part, but the CPU is top notch.
coercitiv
7,484
17,882
Your 1st statement & 2nd statement contradict, but I think I understand what you're trying to say.
They don't contradict. Leakage power is always there, but increases as chip temperature increases (even hot spots matter). More work does not directly imply more leakage power (waste), it can only lead to higher leakage if the cooling is not good enough. It's also the reason why leakage power matters little when a CPU is under very high load since dynamic power is usually overwhelmingly higher, whereas it may arguably be somewhat of a problem if the chip is under low load and running on battery. (though usually this is followed by a rapid drop in temps, and thus drop in leakage as well). This is why we have variable cooling in consumer products, we aim for a certain chip temperature and the cooling system (hardware and software) does it's best to stay within spec.
I really think you should stop lecturing folks about these things, and start reading. The Wikipedia page on processor power dissipation does a great job of presenting the important facts in a condensed format.
coercitiv
7,484
17,882
I'm not. You're the one lecturing now. I've done a fair bit of reading myself. Claiming high temperature doesn't affect performance is outright silly (just cos it's a Mac!). Some want to believe that even when the MacBook Air is running at 114°C, it's still efficient. And let them believe what they want, it's their choice. But I don't.
Several people in this thread have already tried to help you, yet you insist with the same misconceptions. Good luck digging yourself out of this.
