Page 908 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DrMrLordX
23,225
13,304
Beyond it being pretty weird IMO to downplay 18A for "just" being a 3 nm class node. A few years ago Intel barely even had a 7nm "competitor" while TSMC was rolling out N4P, and now Intel shipping a process that's at worst roughly on par with N3P,
Is 18A really on par with N3P? 18AP sure, but 18A?
Magio
207
246
The efficiency figures (if the slides turn out to be accurate, of course) from PTL vs ARL/LNL on N3B make me think it's in the ballpark at least. The peak performance figures are another story but there's a caveat with that IMO: We don't know how much of it is the P-core being a bottleneck. Because Raptor Lake refresh on Intel 7 delivers the same peak perf as LNL/ARL so either Intel 7 = N3B = 18A or Intel's P core is hot garbage and can't scale anymore. And since Intel can't score clients yet sadly that P core is our only measure of peak performance but I don't think it's an accurate one. So pending more data I feel like putting 18A and N3P in the same basket is reasonable if efficiency figures are confirmed.
Of course there are two elephants in the room (which is too many elephants) with that still: Yields and volume, because even if 18A is indeed N3P level or better it's nowhere close to it in either of those aspects. So Intel Foundry has work to do still for sure but my point was that downplaying 18A when it's the closest Intel has been to the leading edge since TSMC shipped N7 in 2018, or downplaying technical wins like BSPDN is just pushing the negativity a bit too far.
(As for Intel product, please let the Unified Core thing turn out to not be hot garbage.)
DrMrLordX
23,225
13,304
Keep in mind that Raptor Lake achieves this performance at generally higher clocks and power than Lunar Lake or Arrow Lake.
No, even Intel 3 is a better overall performer on the v/f curve than Intel 7. Can Intel 3 handle the same max clocks as Intel 7? No idea, and we'll probably never find out. It's safe to say that Intel 4 can't which is a major reason why Intel never bothered using it with anything significant outside of Meteor Lake.
I do think that if Intel had chosen N3P for Panther Lake rather than 18a, we'd see a processor that performed better than Arrow/Lunar across the entire v/f curve AND that reached higher peak performance as well (e.g. that would not be limited to 5.1 GHz or lower), which is the main reason why I would say that 18a still can't equal N3P. Well, the main reason anyway. The differences between Lion and Cougar Cove are not (apparently) so great that Intel would be unable to reach target clocks on N3P Cougar Cove.
511
5,465
4,890
The problem is Intel 7 is a high clocking node... Like very high clocks
511
5,465
4,890
It would be costly and the difference would only be seen at higher end of V/F Curve at lowe end of the V/F curve 18A would be N3P or slightly better than it as you can see at lower end the curve.
poke01
4,880
6,216
Why was N3E used for the GPU then?
Now that I think about, it’s only used for the X SKU. So obviously it’s a premium sku.
Intel was pretty smart with Panther Lake SKUs and will maintain a good margin, they will sell well.
511
5,465
4,890
The Layout is nice in itself if you look closely they can cut 8 Cores from the end and there is your 4+0+4 Tile
DavidC1
2,187
3,340
IIRC Intel said FinFET did more for 22nm than any shrink itself did. It worked well in laptops I believe. And it lowered desktop TDP from 95W to 77W with a small clock increase. I don't see how more dies/wafer that use less power and give a small boost in performance is a "nothingburger".
It is a nothingburger, because it's desktops, and Sandy Bridge could be readily overclocked to beyond 4.5GHz a lot could do easily to 4.8GHz, while Ivy Bridge struggled to do 4.5. That's what a 37% transistor gain brought you. It was a decade of miserable gains since Sandy Bridge. Also a new process node doing 20% reduction is quite bad. My point is that using transistor performance as clock speed metric will get you wrong results.
Laptops weren't anything special either: https://www.notebookcheck.net/In-Review-Intel-Ivy-Bridge-Dual-Core-CPUs.75342.0.html
Clocks went up by a mere 100MHz, just like the desktop counterpart. It fell completely flat on its face compared to the world-changing product marketing it surrounded it. It was less significant than any other node previously, or even after it. It was a + level gain. Ivy Bridge was mostly the graphics brought on by the double density a node typically brings. Even graphics were overhyped. They called it Tick+, because of the graphics, but Clarkdale and Sandy Bridge had much bigger gains. Granted it was because it was starting at a low point, but again considering even Ivy Bridge graphics were shoddy, it was very misleading.
World-changing it was not. It barely even changed Intel. Even Silvermont, the product later explicitly attributed for the 37% gain, was eclipsed by Apple A6 in less than a month. I remember the AT article talking about the same thing, how the win was short lived. It probably killed any chance Intel thought they had of taking long-term mobile share.
Geddagod
1,681
1,720
PTL supposedly has outright better SoC power than LNL, though the video they showed about the same
But N3P or slightly better doesn't really fit in with Intel also then making NVL 4+8 tiles TSMC N2/N2P too instead of 18A/18A-P.
511
5,465
4,890
IDK why they moved tiles to TSMC I didn't make the decision lol but one of the stupidest decision...
Reactions: DKR
Tigerick
942
857
PPA and don't forget NPU6 tile which require more area and power. Do you have any idea which node is being used to make NPU6 tile?
DavidC1
2,187
3,340
If we believe the Intel guy on reddit, Darkmont has 10% power efficiency optimization and the 18A process gives it additional 10%.
It's very possible at idle and mostly idle scenarios(Reading an article, with 1 tab), Lunarlake is still lower power, but if they can optimize the mostly idle to light load state, it'll still result in improvements for lot of cases.
Based on how well SteamOS was doing against Windows in low load battery life, Lunarlake's optimizations might not be as pronounced compared to predecessors, because it indicates that Linux doesn't have as many background applications firing up everything so often. Icelake might actually do quite well, because it had real low idle, it just didn't know how to keep it there.
511
5,465
4,890
NPU6 Tile is on SOC so 18A the only node that is external in NVL IS N2
Take this tile remove the Core+L3 everything SoC is on 18A/AP the core+L3 is on N2/18AP
Reactions: Tigerick
Doug S
3,843
6,796
That seems rather easy to believe given how much more headroom there is for improvement in E cores than P cores. Apple's E core improved IPC by 29% at the same power and only got the modest N3E->N3P bump. Apple's E cores occupy a lower rung on the power and performance spectrum than Intel's E cores so a 29% gain in one generation isn't going to happen for Darkmont, but a 10% gain seems reasonable if not perhaps slightly underwhelming.
Josh128
Banned
Oct 14, 2022
1,542
2,295
Link to this Reddit guy's post please?
DavidC1
2,187
3,340
Their E cores are already better on that aspect, furthering my beliefs that they are the future.
OneEng2
1,011
1,212
Are you then betting that things like SMT and AVX512 never happens in e-Cores?
How about higher clock speeds?
I have a theory that if you add everything needed to bring the performance of an E Core up to the level of a P core (or a Zen 6 core) you pretty much end up with a P core don't you?
Of course, moving forward, we need to start thinking about much more minor process improvements AND much longer times between them.
I am really interested to see how Intel's roadmap evolves now that they have decided that making money is an imperative.
Reactions: S'renne
511
5,465
4,890
They increased L2 by 50% from 4MB to 6MB ...
