Page 909 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Covfefe
107
194
I have a theory that if you add everything needed to bring the performance of an E Core up to the level of a P core (or a Zen 6 core) you pretty much end up with a P core don't you?
No, not if the new CPU design is better than the old one. Your whole argument seems to hinge on the idea that all CPU cores are the same, and it's impossible to create a good one or a bad one.
Lion Cove is terrible. It has much worse PPA than Zen5. I don't know why you lump the p-core and Zen6 together. If a Skymont successor took over and simply matched the competing AMD CPU core, that would be a huge step up from the current situation.
Reactions: DavidC1 and poke01
OneEng2
1,011
1,211
It's an interesting concept I suppose.
I guess I believe that in this day and age, there aren't any mysterious CPU architectures that magically work better than everything that came before it.
I believe that Apple, Intel, and AMD all have equivalent engineering teams and tools. The difference is what you target your architecture to do and what things you decide to prioritize and what things you decide to give up.
I believe you can't say I want it all and actually get it all. If you say I want a core that is very power efficient, you can't also say I want a core that clocks higher than the competition.
You can't say I want the core to be very small AND I want 4 way SMT, AVX512, etc, etc.
I do agree that Lion Cove appears to have lower PPA than Zen 5, although I think ARL in general gets a pretty bad rap on the basis of its poor showing in latency sensitive applications (which is mostly a ring bus issue IMO vs a core problem).
I think it is a pretty tall order to take ANY derivative of Skymont and make it compete with Zen 5 across the board. I think you can make it do some things better, but at the expense of doing other things worse.
I just don't see getting something for nothing in engineering.
dullard
26,196
4,868
5.1GHz for unobtainium SKUs only? 18A not looking great boys.
Lets put both important pieces in the picture: turbo frequency AND turbo power levels used to reach that frequency (PL2).
So, roughly the same top turbo speed with much lower power (other than lunar lake which fewer cores). What would a top frequency oriented chip get at 115 W?
dullard
26,196
4,868
And you think a clock speed regression is unworthy of criticism? Or that it simply isn't real?
How long is it realistically at the top speed (tau)? What power is used for 1 core vs all core top speed? What performance do we get at that top speed (that is clock speed without IPC is useless)? None of those pieces of information are known. So, how can anyone honestly criticize? Panther Lake may be total crap--but you don't know yet. Somehow you think it is worthy of criticism though.
As for is it real or not, the only Intel mobile chip with higher clock speed requires 2x more power for 300 MHz more. And that is only a couple of Intel mobile chips that do it. Most top out at the exact same 5.1 GHz.
Reactions: Doug S
gdansk
4,778
8,071
I didn't say it was crap. Simply that it is open to criticism because fmax dropped and it is shipping (i.e. that's where the specs come from now).
Reactions: techjunkie123
dullard
26,196
4,868
Criticism without full information is ignorance at best. Whether you call it crap or not, any criticism is invalid at this point. Even with shipped chips, the final BIOS hasn't shipped. GPU performance went up almost 10% last week alone.
gdansk
4,778
8,071
No, it's objectively correct at worst. Fmax dropped relative to previous products. Some here have been in denial about it. But it's happening. You can say the product is better overall. That's a separate issue. It is a questionable showing for 18A.
Reactions: Josh128
dullard
26,196
4,868
No, it's objectively correct at worst. Fmax dropped relative to previous products. Some here have been in denial about it. But it's...it's over
Saved for posterity. And to show your unobjective colors. Frequency without IPC is a useless statistic. Frequency and IPC without consideration for power is ignorance (especially for mobile). All three without final BIOS and drivers shows nothing about technology.
gdansk
4,778
8,071
All I said is fmax dropped and you can criticize that. You know that IPC would be better applied if PTL could clock higher but alas... 18A can't yet. Sad.
And it's totally okay to say that sucks. It's a possibly good product being turned far less impressive because it couldn't reach a high enough clock rate.
dullard
26,196
4,868
What is 18A's Fmax at 115 W?
Meteor Late
347
382
That's completely irrelevant, because those power levels are only reached in multithreaded apps, none of these are going to consume 45W or more in 1T scenarios, which is where those frequencies happen. that is to say, Panther Lake doesn't have lower fmax just because it has a lower PL2, that's not how it works.
511
5,457
4,888
Intel is not getting massive IPC increases to justify the stagnant clock speeds, it's as simple as that.
There is no justification for having the same clock speeds as Intel 4's Meteor Lake, none.
Why not .... It's not the same uArch as MTL it's bit down than my expectations though but Still fine.
511
5,457
4,888
You are forgetting 30-40% reduction in power for the same ST which is pretty big this means you can have LNL st from like 15W to 9W that's big1762363639125.jpeg
