Do you hate the metric system?
blueshoe
414
Originally posted by: GML3G0
Originally posted by: Goosemaster
Originally posted by: Syringer
Originally posted by: compnovice
Originally posted by: joshsquall
Screw the metric system.
Miles > kilometers
Pounds > kilograms
Quarts > liters
English > metric
Are you sure you graduated from high school?
Uh, did you? That's the proper analogy..
But in any case, the OP is an idiot.
no it is not
He mixed derivatives of metric units with single units in the english system...
miles relates to meters
pounds relates to grams
quarts relates to liters....
consistency
ummm, technically, kilograms are the basic unit for mass. ;)
meter-kilogram-second
Actually, pounds aren't even the basic units for mass. Pounds are units of force.
Correct me if I'm wrong, but it should be:
pounds--newtons
slugs-- kilograms
blueshoe
414
Originally posted by: bonkers325
metric conversions are easier
there are also two types of pounds: pound-mass and pound-force. sucks, doesnt it? :p
and pounds doenst compare to kilograms, cuz a kg is a unit of mass. you = noob!
Pounds equate to kg when assuming a constant gravitational force.. which just so happens to exist in every place you've ever been.
What about when you're in an elevator? ;)
There's a constant gravitational force in the elevator, yet your weight changes while your mass remains constant as the elevator accelerates.
DeeKnow
2,470
well, India and China use metric.
you better learn metric if you want to have a job 10 years from now.
mrrman
8,497
its so simple once you get the hang of it...and the Aerosmith song " my big 10" would now be "my small 4.1666 cm" lol
Toonces
1,690
or "my big 25"
I'm sorry for your small 4.1666 (1.6") but switching to metric won't make it bigger ;)
pray4mojo
3,647
Miles > kilometers
Pounds > kilograms
Quarts > liters
English > metric
this may or may not have been said already cause im not going through all the posts but try
slugs and grams
newtons and pounds
GeneValgene
3,884
Originally posted by: edro
In the engineering realm... go metric or go home.
yes...true dat
it is a pain in the a$$ doing calculations in english units, like in thermodynamics or heat transfer
coomar
Banned
Apr 4, 2005
2,431
yes...true dat
try living in a twin city with the US
we have to do both for everything
isn't imperial only used in the UK and the United States?
metric is by far the superior measurement system
dighn
22,820
4
metric makes so much more sense. you were just brought up with the wrong system :D
dighn
22,820
4
Originally posted by: Tom
I do. And if you look at nature hardly anything is 10 based.
so? and what base do you propose to use? a whole collection of bases all over the place that make units difficult to convert like the empirical system is not the answer
what matters is that our number system is 10 based, and unit system is supposed to be used with the number system.
Apr 17, 2005
13,465
Originally posted by: So
Look, it's like the QWERTY keyboard. Yes, it's less efficient than other choices, but we as a people decided 'hey, we don't think that the gain from changing is worth the cost of changing'
and guess what? You're all in a pissing debate over a SYSTEM OF MEASUREMENT! Fer chrissakes, if you're too dim to remember the conversions between a few units (inches to feet) then the metric system isn't going to help you. Yes, the metric system IS slightly more efficient, in that it's quicker, but it really shouldn't be that big of a deal.
You all need to take a step back and look at yourselves.
Text
:roll:
Apr 17, 2005
13,465
Originally posted by: Acanthus
Originally posted by: CadetLee
12 inches = 1 foot
5280 feet = one mile
10mm = 1cm
100cm = 1m
1000m = 1km
Metric FTW.
yeah but go under a millimeter and it goes all apeshit crazy
no it doesnt...what are you talking about? Its goes in thousands then
jonessoda
1,407
Metric is teh win.
I wish I'd been raised on metric, though, because I just can't envision it the same way I can the imperial system. When somebody says 182cm or 32kg, I can't convert that in my head to an understandable measurement, but if they say 16 inches or 40 lbs, that's easily envisionable.
blueshoe
414
12 inches = 1 foot
10mm = 1cm
100cm = 1m
1000m = 1km
Metric FTW.
exactly, its annoying :p
still better than the imperial system :p
dighn
22,820
4
Originally posted by: jonessoda
Metric is teh win.
I have the opposite problem, which is very annoying because the empirical system is so prevalent in everyday usage in north america. whenever I see "pound"/"inch/fahrenheit" I go wtf and have to mentally convert to get a feel for it :| at least celsius is used frequenty in Canada
Acanthus
19,915
ostif.org
12 inches = 1 foot
10mm = 1cm
100cm = 1m
1000m = 1km
Metric FTW.
That, we can agree on! :thumbsup:
