Page 900 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Thibsie
1,164
1,368
Apple just puts their logo on their badge, next too the SKU name (that's very concise) and that's it. AMD should also just keep the Arrow logo, "R" (for Ryzen) and a single 3-4 digit product number. Ryzen + the product name is the only thing people will remember or verbally express anyway.
Imagine a PC shop talking about these over a phone. What do you think would say? 99% it would be either a "I have a shipment of Ryzen 395 incoming" or even "Strix Halo". Nobody is gonna pronounce the "AI MAX+++++ PRO" BS!
Ridiculous indeed though Apple has its own problem : e.g. M1 with how many cores ? Stupid IMO.
Less stupid than in the PC world but still stupid.
Reactions: Elfear and Gideon
Gideon
2,043
5,096
“M1 with X CPU cores and Y GPU cores”. As far as I’m aware that’s what Apple does right now: just spell it out.
I agree. And I would personally prefer 3-4 digit product numbers. Worked great on cars since time immemorial (until marketing butchered them there too) as well as old CPUs / GPUs. That's why I mentioned "Ryzen 395". That's not the part i have a problem with.
FlameTail
4,384
2,762
It works fine for Apple because they don't bin by frequency, and even when they do core binning, there is usually only 2 SKUs (binned and unbinned).
poke01
4,651
5,988
I just want idle power usage to be low, Stand by will anyway suck cause of Windows. Especially for the lower tier Halo SKUs which will go into tablets and 14” laptops.
19,204
It’s a mobile part, what do you guys expect?
Also, it's AMD's first attempt. Assuming they don't give up on this sort of SoC in the future, every subsequent iteration of it will be better and better. AMD is moving things forward in stark contrast to Intel who only plan and then cancel (320EU iGPU anyone?).
fastandfurious6
852
1,009
fastandfurious6
852
1,009
thermals/pwm probably similar as strix point
my guess on midtier Halo 385 (8 core 32 CU) vs HX 370:
ST: Halo 385 >
MT: probably similar
iGPU: Halo 385 almost x2
there's probably no point in Strix Point anymore lol
and what will be the point in Fire Range at all other than X3D??
Josh128
1,505
2,256
Price, price, price. Production cost of Halo should be way more than Strix Point due to advanced packaging, 4nm compute + 3nm large GPIO vs 4nm monolithic.
SteinFG
738
873
That would be 20 Xe cores, right? bonkers, considering that B580 has 20 Xe cores.
Josh128
1,505
2,256
Kind of sane. Though I wonder why they didn't go higher. Probably to reduce power consumption.
Thermals 100%. Even Strix Point is limited to 5.1GHz and often doesnt even reach that due to thermal throttling. This thing is larger and not monolithic, thermals will be even harder to constrain.
SteinFG
738
873
Fire range + RTX 5090/5080/5070 would still have a niche.
Strix point is a lot cheaper than Strix halo. Strix halo laptops are probably 1.5-2x the price of Strix point
GTracing
478
1,114
I agree with the post that we'll see more and more big SOCs with larger memory buses and larger iGPUs, but I don't think that they're for gaming (at least not strix halo). They make the most sense for premium mobile workstations.
The RX 7600m and RTX 4060 mobile each have 256GB/s of memory bandwidth. A 256bit LPDDR5X bus (like Strix Halo or the M4 pro) has about 250GB/s. But in gaming the iGPU will have less bandwidth to work with since it's sharing with the CPU.
I'm not sure if LPDDR will ever have enough bandwidth for big iGPUs to be cost competitive with mid range dedicated GPUs in gaming.
19,204
Despite less bandwidth it has one huge advantage, elimination of PCIe bus transfers from system RAM to VRAM. It's just a single large pool of high speed system RAM so results in a huge reduction of latency over discrete solutions like how great the consoles perform despite having older GPU tech. Based on performance per square mm, consoles are king due to unified memory pool.
fastandfurious6
852
1,009
dang 3k for a halo laptop with 4060 perf? nobody will buy that
STX will be price reduced and Halo will sit around $2k laptops, has to...
Yes Halo is way more expensive to produce but in the market there will be a lot of overlap
Josh128
1,505
2,256
Its purpose is more for enterprise/engineering AI and GPU workloads then gaming. Those same people will pay 3k+ for it.
Glo.
5,930
4,991
Expect that in the long run, BGA based stuff like this will also be developed for desktop.
Mobo's with soldered in SOCs, but with possibility of adding your own RAM, SSD, and holes for your own cooling systems.
Timmah!
1,572
935
Appears to be one of the main ones, at least.
Then the question should be, why thats the case, if some other apps, that utilize 4090, can overflow to system RAM, once the VRAM is filled. Naturally this tanks performance, but maybe thats still better than no performance at all?
Are LLMs latency-sensitive like games?
