Page 898 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Josh128
1,505
2,256
Question about Dawntrail benchmark. What do the blue and green lines signify? I noticed they are quite separated on my 9900X system, and they are joined or closer on other runs Ive seen, including with the 5900X run I did at the bottom?
fastandfurious6
859
1,017
still no halo leaks?????
is it safe to assume some 10-20% less perf than 9950X or will it be unique because better memory bandwidth etc??
StefanR5R
6,819
10,900
Still no EPYC 8005 leaks????? ;-)
Seriously though, are they going to skip this one = double the cadence for "edge" and telco?
(Edit: More properly expressed: half the cadence.)
poke01
4,677
6,016
The Halo series will stay. The future regarding laptop SoCs is big iGPUs and access to lots of VRAM and loads of bandwidth, which will only get better with LPDDR6.
Strix Halo has some issues that will be rectified with Medusa Halo but over all Intel has nothing to combat it next year.
Thunder 57
4,243
7,038
I think you are right but without Nvidia in the name will they sell? Tom's just did an article about the best card at 1080p, 1440p, and 4k and Nvidia is nowhere to be found though. They say don't get an 8GB card, piss on Nvidia's (lack of) value, and say RT isn't worth it most of the time. Maybe people are starting to see the light?
inquiss
608
874
What issues are they, do you think?
ToTTenTranz
856
1,420
MLID actually "leaked" a supposed Halo Low Power that, to be honest, doesn't make much sense.
Strix Halo LP specs and performance leak. (Image source: Moore's Law Is Dead)
If it's an unheard before monolithic chip then those 105W TDP make no sense. There's no way the extra 4 CUs and 16MB IF would push power consumption that far.
If it's a cut-down Halo IOD + 1x Zen5 CCD then it doesn't make sense either, as they're disabling like half the IOD or more.
The RTX 3050 Max-Q as target also seems like such a low bar. Strix Point already competes with that in many games. Why would they make such a chip with such a modest iGPU performance upgrade over Strix Point but with a giant leap in power consumption?
Reactions: Tlh97
maddie
5,195
5,593
Strix Halo LP specs and performance leak. (Image source: Moore's Law Is Dead)'s Law Is Dead)
Not supporting the "leak", but it could be a trash bin for chips with one or more of several defects. Defective memory controller, GPU, IF cache, etc. Any one of those could prevent it selling as a top 2 SKU. Everything else gets pushed to that 128 bit bus low spec model, which also works with AM5.
HurleyBird
2,818
1,553
The one thing that might make sense is if it were a desktop part.
ToTTenTranz
856
1,420
That's not the segment halo targets.
Which segment, then?
I'd find it hard to believe there's only one segment for Halo.
Just as I think it would be stupid for Asus/Lenovo/Gigabyte/etc. not to come up with a (big and expensive) handheld that claims PS5 performance.
Hans de Vries
347
1,177
www.chip-architect.com
Indeed,
A single mobile LPDDR6 CAMM2 memory module will max out at ~500 MB/s. That's double the Strix HALO bandwidth or halve the RTX 4090 bandwidth.
Expect beefy iGPU's in the not so far away future.
Trinary signaling can transfer 8x32 bit in 7 cycles over a 24 bit bus. At 14.4 GT/s that amounts to 65.8 GB/s. Eight 24 bit busses add up to ~526 GB/s.
Tuna-Fish
1,688
2,581
Indeed,
No. LPDDR6 is NRZ, and transfers 288 bits over 24 cycles per 12-bit subchannel. Of that, 256 is payload, 16 is host-defined metadata and 16 is either link protection RAS or DBI for power reduction.
At 14.4GT/s a single 192bit LPDDR6 module has a total throughput of 14.4*192/8*(256/288) = 307.2GB/s.
