RampantAndroid
Wait, it's a $300,000 DAC...that doesn't even have gold plated RCA contacts? 😵
It saddens me that there are still people gullible enough to believe in this stuff...a cable doesn't make a difference. Power conditioning, sure. Proper filtering, yes...but cables?!
Hell, people still but $150 HDMI cables...when there is ZERO reason to.
Then you're ill informed. A lot of places get noise on their AC power, and a power conditioner is designed to clean that up.
Then you have a ground issue, plain and simple. Sorry, filtering on the AC side is more bull from people who want to sell you expensive boxes that do nothing.
So you're telling me there's zero fluctuations in AC power? It never has a peak below or above +/-169V? That there's no ripple that needs to be controlled? No need to control the RMS voltage? No need for surge protection? Wow, you're ignorant. They can be crucial to use with tube amps, for example.
There are fluctuations, but there is no "need" to clean them up. It's a good idea to have a surge protector but that's it. A modern power supply will handle the incoming AC power just fine. One thing for sure, a power conditioner may give you a cleaner looking AC signal going into your audio gear but it's NOT going to make your gear sound better or worst. Filter circuits inside your gear's power supply are there for this purpose.
It's a $300,000 modification with crystals. The DAC comes for free, and all the contacts on it are gold plated.Wait, it's a $300,000 DAC...that doesn't even have gold plated RCA contacts? 😵
B-? Woahhhh... that sounds pretty good coming from you. I thought I was gonna get an F or D-? Woahhhh 😱B- work at best Cheez. The Truth has raised the bar so you're going to need to up your game.
Audio is not either "on or off". Human ears are not computers that can read 0's and 1's. With this kind of thinking, there are no differences between audio gear at all, because the data is the same.There are fluctuations, but there is no "need" to clean them up. It's a good idea to have a surge protector but that's it. A modern power supply will handle the incoming AC power just fine. One thing for sure, a power conditioner may give you a cleaner looking AC signal going into your audio gear but it's NOT going to make your gear sound better or worst. Filter circuits inside your gear's power supply are there for this purpose.
Video cables make a difference also.It saddens me that there are still people gullible enough to believe in this stuff...a cable doesn't make a difference. Power conditioning, sure. Proper filtering, yes...but cables?!
Gold doesn't conduct electricity all that well. Usually the cheap equipment has that. Just because they look like gold color doesn't mean they are better. 😀Wait, it's a $300,000 DAC...that doesn't even have gold plated RCA contacts? 😵
If there are differences between audio gear, then there are also differences between cables and tweaks. One reason why audio gear sound different, is from the resonant properties of the materials within. Even screws make a difference to the sound.
Fiber optic cables carry electrical noise too. 1's and 0's mean squat. All digital music get affected by electrical noise and jitter affect timing. I was getting terrible SQ off the generic toslink cable. The $200 Sydney cable (analog) beat the pants off.Fiber optic cables too, can't have that digital colouration turning 0's into 1's.
Gold plated contacts are bad for AC cables, I never use gold for AC. Gold plated for USB cable is ok, but it's too warm so I prefer nickel plated USB plugs.Gold doesn't conduct electricity all that well. Usually the cheap equipment has that. Just because they look like gold color doesn't mean they are better. 😀
The outer layers (not the conductor) of the cable carrys electical noise and adds to the signal. And yes, the cheap cable termination certainly hurts signal transfer too.Glass is an insulator. So no, it doesn't carry electrical noise. At all. Better yet: the cables are terminated using plastic which is....gasp, an insulator!
Styrofoam is bad for the health. Crystals are good for the health. I only use the safest materials.By crystals, you mean you took styrofoam and shoved a bunch of stuff into it, yes?
The EMU 0404 PCI is completely different from the USB version. 0404 PCI was the worst, Benchmark DAC1 was better, Cary Audio 303/300 CD player was worse than Benchmark, dCS Elgar Plus DAC + dCS Verdi Encore SACD transport ($31,000) was worse than Benchmark also, I found others who agreed. Then I switched to EMU 0404 USB, and got the best sound ever! Others agree the EMU 0404 USB is better than Benchmark DAC1 as well. I have highly modified the Benchmark DAC1 to get more microdetail, the stock EMU 0404 USB was still better, for only $200.The EMU404 is by no means a great DAC, I've built a better DAC for something like $250.
They are gold plated. It says so in the product description: "delivering unmatched USB audio fidelity, enhanced by gold-plated connectors for pristine audio quality".And no, they're not gold plated - not in your stupid little video which you filmed on a toaster.
I spend the money to design better tweaks, instead of buy an expensive camera that doesn't do anything to improve the sound.If you're making audio equipment worth this much, why are you living in such a crappy place? Why can't you afford a proper DSLR to make your videos?
No, not a troll.Oh, right...because you're a troll.
Good to hear you like the Benchmark DAC-1. 🙂 And it's impressive how it equals or outperforms the other high-end DAC's on the market. This is the DAC I am planning to get, along with Audioquest Niagara XLR cables ($1800). Hmm... I better check out the EM 0404 USB that you speak of. Sounds intriguing! 🙂The EMU 0404 PCI is completely different from the USB version. 0404 PCI was the worst, Benchmark DAC1 was better, Cary Audio 303/300 CD player was worse than Benchmark, dCS Elgar Plus DAC + dCS Verdi Encore SACD transport ($31,000) was worse than Benchmark also, I found others who agreed. Then I switched to EMU 0404 USB, and got the best sound ever! Others agree the EMU 0404 USB is better than Benchmark DAC1 as well. I have highly modified the Benchmark DAC1 to get more microdetail, the stock EMU 0404 USB was still better, for only $200.
Benchmark DAC1 is very good. But the internal toroidal transformer needs to be placed outside the chassis to get a new layer of microdetail. See on the picture, I put the toroid on the right side of the Benchmark DAC1.Good to hear you like the Benchmark DAC-1. 🙂 And it's impressive how it equals or outperforms the other high-end DAC's on the market. This is the DAC I am planning to get, along with Audioquest Niagara XLR cables ($1800). Hmm... I better check out the EM 0404 USB that you speak of. Sounds intriguing! 🙂
