beggerking
- Jan 15, 2006
- 1,703
- 0
- 0
Originally posted by: Exsomnis
All the 7950GX2 does is to send two signals at 8x linkspeed through the 16x PCI-E slot, the same thing that the Dual 7800GT did. In that respect, the Dual 7800GT was actually more advanced due to it actually being a single card solution, but it had a limit on how much power could actually be put onto the board.
Since then we've already mastered dual x16 SLi on PCI-E, but because the 7950GX2 is two individual cards slapped together, it has to run both at x8 and have an in-built SLi bridge.
then why does Dual 7800GT require SLI chipset and 7950 GX2 doesn't? 7800 "look" more advanced but 7950 "is" more advanced. IMO, anycard that would fit in any single PCI-E slot board is considered a single card solution..
When they put two G71's on one PCB, and they probably can now that SLi technology has advanced, then they would've regained the single card crown. The 7950GX2 is amazing and unique, it's even decent value for money, but a single card it is not. Just two cards running at half bandwidth, glued together with an SLi bridge.7950GX2 is a single PCI-E mb graphic card. looks to me NV has regained the single card crown here.
Stop kidding yourself, it's nothing but a marketing gimmick. Stick two mobile 512MB Geforce 7900 GO cards together, call it the first 1GB card in the world and the fastest out, and people like you will eat it up without even thinking about what it really is first.
Tell me; If ATi developed a Crossfire setup that allowed the whole signal to go through the dongle instead of the second PCI-E slot, would you call it a single card solution? No, because it wouldn't be one. Just because they're bolted together doesn't make a difference at all, it's two graphics cards.
Next you'll say that two siamese twins who share a heart are one person.
SLI bridge requires SLI controller, this one doesn't! therefore it is a single card solution.
8x vs 16x pci-e don't really affect speed..
ATI dongle. hahaha... but seriously, if ATi would do that and DOES NOT REQUIRE a CrossFire MB, then I'd call that a single card solution (provided the card doesn't run at 200 degrees and sound like 2 jet engines).
your siamese twin analogy is flawed. If you apply that analogy to Intel pentium D, you'd be in a big surprise. Pentium D may "look" like its one chip, but internally its 2 pentium chips glued together each with its seperate cache.
again, your argument is seriously flawed because you only rely on "physical characteristics" rather than the "technical " characteristics.
