Page 926 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,911
6,253
Run SIMD code on Apple vs AMD and you will find it gets beaten in both power and perf/wattthe gap is not that big
Not bad for such an INT/FP focused CPU.
IMG_3017.pngMath fun
The 9950X is just better here for peak performance. Now if Apple ever includes proper SVE2.1 then we can talk about DC talk. But have to say not bad especially the M4 Max with NEON it put up a good fight.
poke01
4,911
6,253
View attachment 134985Math fun
Now we stop saying Apple cores are better in everything. They are tailor made for extracting ST perf and for compiling your code but NEON is just too slow for SIMD tasks.
Now unless Apple changes direction or mandated by ARM, you won’t ever see SVE2 in their cores
Reactions: Tlh97 and 511
Thunder 57
4,302
7,113
I'm surprised no one has mentioned the massive L1 caches in particular for the Apple cores. Of course that is excellent for ST performance.
Oh and BTW, there is a thread for x86 vs ARM. Why can't these posts be there instead? Seems OT.
Reactions: Tlh97 and poke01
Magio
209
251
◾ “WilCat Lake” is going to be a ENORMOUS DISAPPOINTMENT in the range of chips under 10W (for possible fanless use).
➖ On the one hand, the “Qualcomm Snapdragon 8 Elite Gen 5” with an estimated TDP of 8W and an NPU with 80 TOPS, ideal for “Windows 11 Copilot Plus.”
➖ On the other hand, the AMD “Krackan Point” with a configurable TDP of 9W and an NPU of 50 TOPS, which exceeds 40 TOPS and is compatible with “Copilot Plus.”
➖ And finally, the “Intel WildCat Lake” with an estimated TDP of “less than 10W” and an NPU of 18 TOPS, INSUFFICIENT for “Copilot Plus.”
➖ I think Intel should implement its latest “NPU 6” design in “WilCat Lake” NOW, so that it can at least compete with an NPU that will be compatible with “Copilot Plus.”
I don't know which part of this I find more comical, using NPU TOPS as the barometer on which to judge a chip, citing the max theoretical TOPS in conjunction with the lowest possible TDPs, acting like anyone in the world cares about "Copilot + PC" branding when everything actual people do with AI relies on cloud compute or suggesting Intel swap NPU6 into WCL now as if that's how chip design works.
... Or maybe it's the idea that the fanless Windows laptop market will be a significant segment within WCL's lifespan.
Reactions: dullard
dullard
26,196
4,869
Please don't repost the same exact block of text in multiple threads. https://forums.anandtech.com/threads/intel’s-unified-core-there-is-hope.2630962/post-41545096
1) You misspelled Wildcat multiple times.
2) Qualcomm products don't really run x86 code well. For example, last I saw was only 90% compatibility in new games--let alone the hundreds of thousands of older games it can't play. https://overclock3d.net/news/gpu-di...ame-compatibility-with-its-new-adreno-x2-gpu/
3) You misspelled Krakan.
4) You don't need to put everything in quotation marks.
5) The rumors for Wildcat Lake is 40 TOPS total which is just enough for Copilot+.
6) Who is exactly going to be disappointed? Wildcat Lake is for the ultra low-end price computer tasks. These people aren't really the ones clamoring for Copilot+.
regen1
365
456
He got in at early 2021. You can't say it isn't mostly under his leadership. Design by itself takes a year. Rest are basically making it physical and implementation plus testing.
Core u-arch design targets would have been over by then. But yeah he still would have decent time on other parts of LNL/ARL, GNR execution to an extent. With NVL he would have had better say in execution(more so if he could've stayed) than say MTL/ADL or ARL.
CEOs aren't responsible for low level decisions. You can't anyway, there's just not enough time. If he was a chief architect it would be different. Making sure the company runs smoothly so products are made smoothly, those are his responsibilities.
Yeah, mostly they aren't but they are involved in some level for setting design/performance targets esp. wrt new u-arch based products, node selections, choosing(and cancelling like Royal Core) between stuff, etc.
Raptorlake they claimed 3 years from design to availability on shelves.
2.5 years. ADL was 3 years. RKL, IIRC, was 2 years? Could also have been 2.5.
The time period(2? 2.5? 3?) referred here are likely a part of it but not the full period from conception of u-arch to product availability.
In last 10 or so years for a Tock-level or new cutting-edge design for Intel(P-core) or AMD, from ZERO to products on sale, it has been 4-5(+) years of time roughly if not more, there has been a lot of times it's been towards 5 or more.
ADL isn't done in 3 years(from GLC conception to ADL availability) when SPR is known to be delayed for so long. RPC(RPL) and RWC(MTL) are small changes over GLC. "Alder Lake" name was known in 2017, so it would have started somewhat earlier.
Cypress Cove(RKL, 14nm family) is a derivative of SNC used in ICL which took quite long to come out(some of it down to 10nm delays). So it isn't just 2 or 2.5 years. Haswell started in 2007, launched in 2013. Mike Clark claimed in 2018 about working on Zen 5 and first Zen 5 based products released in July 2024(Strix Point). I am not completely sure about Lion Cove(might be 2019 or 2020). Zen 8's initial work started quite some time(years) ago but it isn't coming anytime soon.
DavidC1
2,192
3,343
Dead internet theory.
AI promoting AI, because it's only promoting AI related features.
Reactions: Tlh97
Hulk
4,154
Just read at Tom's that the 290K will have boost frequencies of 5.6 for P and 4.8 for E. Thinking about how area performant Skymont is I'm wondering if Intel considered holding the P core count 8 and using the rest of the die space for the E's?
511
5,545
4,943
it's like 6.83mm2 for the Skymont Cluster with 4MB L2 and 4.68mm2 for Lion Cove and 3MB L2 you can see how much area LNC Hogs and Intel only got 12 Stops on the Ring
regen1
365
456
Some specs-preview of some of the upcoming models.
Small addition, U9 290K Plus will have TVB of max 5.8GHz for P cores.
Reactions: Tlh97 and Elfear
Hulk
4,154
Intel has a long way to go. Just a year ago, after 30 years of building Intel only inside computers, I built a 9950X. It has been a flawless computer.
I was an ardent Intel supporter. Now I have kind of written them off and am much more interested in Zen 6 rather than Nova Lake. I don't believe Intel can do it. All of the news about Intel is "plans." No working silicon, no proof of 18A delivering and yielding. Could they do it? Of course. But I won't believe it until I see it.
On the otherhand I'm feeling a quiet confidence from AMD. I'm thinking that AMD will be a solid upgrade from Zen 5 and won't have to fill any massive performance holes (like ARL gaming) from the last generation.
I'm pulling for Intel but am highly suspect of them delivering.
511
5,545
4,943
Not that long to go
Half the media is against Intel tbh at this point as for No working Silicon on 18A they are ramping the node in Arizona and are shipping PTL to their Customers.
Well NVL is something they have thrown the kitchen sink at the problem
Reactions: controlflow and DKR
jdubs03
1,508
1,096
I think sentiment will really driven by how Panther Lake does in the mobile segments compared to Zen 5. If it’s a meaningful improvement, that will inspire confidence for Nova Lake.
But Nova Lake was always* supposed to be a big step. Don’t be surprised when it trades blows with Zen 6 on overall performance and efficiency.
Reactions: Tlh97, Hulk and 511
Khato
1,387
495
Heh, whereas I happily 'downgraded' from an i9-14900k to an Ultra 7 265k and have only noticed performance improvements. Which matches up with my expectations from reviews. I know the narrative of those reviews was 'ARL gaming performance regressions', which is quite true if you're gaming with an RTX 5090 at 720p. In the real world of sub $1k graphics cards running at 1440p or 4k there are only a few games where there's a meaningful performance difference.
Geddagod
1,684
1,720
If half the media is against intel and the other half is for Intel, isn't it balanced?
I honestly don't think mobile has that much of an effect mindshare, maybe with the exception of LNL, and that's strictly against ARM, not gaining mindshare against AMD.
Why shouldn't people be surprised if this is the case?
The current scenario is that AMD has better design teams. If they are trading blows iso node, that means Intel must have at least made some progress in that front. Or maybe they just throw silicon at it to catch up to AMD.
jdubs03
1,508
1,096
Well looking at the 285K vs the 9950X-variants, it’s relatively close. Like I said Nova Lake is supposed to be a big step. I get the pessimism, Intel has disappointed on the design and process side for quite some time. That doesn’t mean it has to continue.
Joe NYC
4,263
5,934
What prompted you to make such a "sideways" move?
They only reason I can think of someone moving from 14900k to 265k is if the 14900k is experiencing silicon degradation, or the performance has been degraded by various mitigation patches Intel released.
My goal, when upgrading is to get 2x performance, or +100% increase. Not +/- 5%
Hulk
4,154
Not that long to go
This is all great news and I truly hope to be proven wrong and would be happy to see a state-of-the-art node from Intel with good yields and solid architecture on display for both Panther and Nova Lake. It would be a great comeback story after quite a few tough years, especially on the fab side of things. I'm not nearly as "in the know" about fabs in particular but I always felt like Intel fabbing at TMSC was a "waving the white" flag moment from them. I still haven't forgotten "Five nodes in four years." Trust has to be earned back and it's gonna take more than PR this time. I'm not "buying it" like I used to.
I should also mention that my move to AMD was complete when I ditched my Surface 2 laptop for a Asus ProArtPX13 with an AMD HX370 CPU. Another amazing piece of engineering from AMD. I remained loyal to Intel until they forced me to AMD.
Eagerly waiting for Panther Lake reviews and the news that "Intel is Back!"
regen1
365
456
So many things can go right and yet very few things that don't go that well could put you behind the competition. Eg. (hypothetical)everything including IPC looks good or better vs competition but chips don't clock high enough bringing overall ST below the competition. Or your line-up is competitive in ST, MT but don't have a proper answer to X3D in gaming.
Even GNR vs Turin, apart from a gen old core(RWC), mesh issues leave out a lot of performance on the table despite being otherwise decent in many areas. Also 2P scaling issues on GNR.
ARL is pretty decent in notebooks(much more volume and design choices vs competition). Even in desktop the main issue is not having an answer for Zen 5 X3D(in gaming hence the mind-share) and some others but it is competitive in ST, MT.
NVL should be decent upgrade over ARL in many areas including performance but where it lands against the competition will be see then. NVL will very likely do really well in notebooks.
Reactions: Hulk
Khato
1,387
495
In terms of performance the 265k has been equal or better since I limited the 14900k to 200w. (Prefer reasonably quiet heatpipe based cooling over liquid.) I'm sure that raises an equally valid question of why I bothered with the 14900k in the first place. Answer there is I've been upgrading every generation and re-selling the used CPU+motherboard on eBay for roughly the original price paid since core 2 duo. Perk of having started my career at Intel and still having friends who work there is access to their employee purchase program. The at-cost pricing is far, far better than the 15-20% reimbursement AMD offers, or the 10% discount with NVIDIA. I had thought about skipping ARL, but the abnormally cheap pricing of the 265k combined with higher end z890 boards being re-sold at 1/2 to 1/3 of original price earlier this year made it a bit too tempting. (Thanks Newegg for your forced bundling of motherboards no one wanted with graphics cards far too many people wanted.)
I'd certainly like it if there were reasonable 2x performance opportunities to be had. It was fun getting those kinds of improvements from graphics cards for a bit without having to pay an obscene amount.
