Page 979 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
LightningZ71
2,717
3,421
Thank the deity of your choice that Intel canned Optane then. All those budget books with 4GB ram and a 16GB Optane being pedaled with mechanical HDDs were all horrid.
DavidC1
2,196
3,353
They are there for area efficiency for MT application that can benefit from them. Intel can get you more MT compute for your dollar with the E cores, that is their reasoning.
If cost wasn't a concern they could just make a couple of huge tiles full of P cores and run themselves out of business because manufacturing cost is too high.
E cores are allowing both to happen, optimize for ultra low power or for density. Remember when they had Y class chips with 7W P core chips? It sucked. The N series using E cores outperformed them in MT, because they couldn't scale down low.
It also seems whatever optimization they made to Pantherlake reduced the gap between LPE and E cores significantly, to the point where it's mostly a toss up between the two per clock. I think Geekerwan tests showed ~5% difference? Lunarlake's LPE was substantially slower than Arrowlake's E.
It was a solution in search of a problem. Sad part is, you can buy tiny 16GB generic 3DXP modules for real cheap, but they're almost completely useless.
I still think they could have done it better. Another guy did a test of limiting Windows to 2GB RAM and had Windows on a Optane drive. He said it was usable. I know from experience it's a horrible experience on an SSD. So since it was premium either way they should have marketed as cheap RAM extension. They named it Optane Memory, but treated it as a HDD cache drive. I know partly the reason they did this because they saw only $ signs in front of their eyes charging $500 or something extra for the Optane server "Memory Drive" feature.
RAM isn't just performance, but you need enough for compatibility reasons. Then the future generations could have been literally slow RAM with the DDR versions.
Reactions: Tlh97
DavidC1
2,196
3,353
Pantherlake:
habhbhdbaaalruh-jpg.138429
Lunarlake:
It looks like they made noticeable performance gain, while keeping low power efficiency.
Reactions: Tlh97 and hemedans
DavidC1
2,196
3,353
You can see from the above results that E core is indeed more energy efficient below about 2.8W compared to a P core and scales down much further. It just scales lower as an LPE configuration. In Meteorlake that's true as well. Meteorlake data shows why it didn't do well as Intel hoped - there's no power advantage for LPE at all over regular E cores, I assume likely due to having to power up another tile and external interconnect. AMD results show that there's a crossover point too, but their E core is less power efficient in all other power ranges and is a pure density play.
-At 2W, energy efficiency over Raptorlake E core is 70% per watt, at 3W it's 58%, and maintains 60% advantage all the way. It only requires 2.75W for Pantherlake E to achieve same perf as Raptorlake E at 10W.
-Pantherlake's LPE is 100-120% more performance at same power. Alternatively it takes anywhere from 4x to 5x more power for Raptor E to match Pantherlake LPE. 2W PTL LPE is outperforming 9.5W Arrowlake E
-LPE is ~10-15% over E, or equal to being on a more than half a node when power normalized. Consider a full node is at 15-20%. Power normalized, it's ~50% better.
Pantherlake's LPE is more optimized for higher performance than Lunarlake. The curve is steeper so it's overall superior, but Lunarlake can reach lower absolute levels, combined with memory PHY having 40% lower power. Realistically though their engineering made a good balance. It's unlikely you'll see many cases where either platform is better in battery life. Lunarlake would be better in almost nothing scenarios, Pantherlake would be countering that under anything more than near idle.
DavidC1
2,196
3,353
LPE in Lunarlake is significantly slower compared to LPE in Arrowlake: https://old.chipsandcheese.com/2024/12/20/skymont-in-desktop-form-atom-unleashed/
That seems to be no longer the case in Pantherlake. C&C tested desktop Arrowlake as being 25% faster compared to laptop lunarlake. If you consider ~5% for laptop vs desktop, it means Pantherlake LPE is ~15-20% faster per clock than Lunarlake LPE. Wow, so 3.3GHz LPE in Pantherlake is outperforming 3.7GHz LPE in Lunarlake by 10%.
So here is the brief on MTL/ARL the LP-E is crestmont and are on N6 in SoC without any type of cache to help them.
In LNL/PTL they are in the compute tile on N3B/18A and has special cache Called Memory Side Cache that's for LP-E so they don't starve it's a power optimized cache just to keep power low.
The Darkmont/Skymont are exactly the same cores otherwise like physically the same I have actually matched their dishots.
This is also true for Lunarlake. They "fixed" LPE performance on Pantherlake. Perhaps the MSC is not useless anymore. I gotta say, execution-wise they delivered with Pantherlake.
Reactions: hemedans and 511
