Page 978 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hulk
4,154
I’m referring more about the LPE cores. They’re significantly more performant per watt.
The E cores have to get quite a bit more juice just to perform at the same level or slightly better. Which is odd because the LPE cores are just slightly down-clocked Darkmonts. Yet they have a very different profile.
Oh okay. Yes, I noticed that as well.
I can't explain it. Why would Darkmont LPE be significantly more power efficient than Darkmont E?
Hulk
4,154
Cause they are not on Ring so they have different power profile.
I'm not following? What difference specifically make a Darkmont LPE core use about 1 watt less than a Darkmont E core at the same work rate (performance)? A difference like that would seem to indicate a different architecture, node, or both? At first I was thinking super low leakage silicon that doesn't clock high but is very power efficient?
Thing is the LPE's are on the N6 process platform controller tile, which you would think would be less power efficient?
I'm all confused now.
511
5,544
4,942
So here is the brief on MTL/ARL the LP-E is crestmont and are on N6 in SoC without any type of cache to help them.
In LNL/PTL they are in the compute tile on N3B/18A and has special cache Called Memory Side Cache that's for LP-E so they don't starve it's a power optimized cache just to keep power low.
The Darkmont/Skymont are exactly the same cores otherwise like physically the same I have actually matched their dishots.
Reactions: Hulk
poke01
4,911
6,253
XPS as a sub-brand definitely has one of the best track records out there, with well built machines, well-tuned hardware and firmware and offered with enterprise-grade warranties (sometimes at no extra cost)
The last few XPS models have been questionable. Removed the headphone jack, no viable trackpad and capacitive function row and only usb-c with no other ports
They fixed most of these in the 2026 XPS but still offer only usb-C.
LightningZ71
2,712
3,421
Aren't the PTL E cores made on a "fin flex" capable node now? Wouldn't it make sense to flex them to a more efficient configuration with respect to power at the expense of performance?
Reactions: Thibsie
Magio
209
251
Don't get me wrong, I loathe the previous couple XPS iterations, the capacitive function row was on its own was just disqualifying for me. Those boneheaded decisions led me to ditching XPS to go with a Thinkpad X9. But while I disliked those models, they were still well built, well tuned and all that jazz (from what I've heard at least). In the same way, I don't dock points from all Thinkpads until the X9 for their trackpoint and odd trackpads buttons, I personally hate that but it's a debatable design choice rather than an objective flaw.
Anyway, to get back on topic the main thing about XPS is people need to stop bringing up their pricing as if it represents PTL's.
Reactions: 511 and poke01
Hulk
4,154
This is great thanks.
A couple follow up questions if you don't mind?
First, I assume the Vcore VRM telemetry is a measurement of the voltage regulator for the entire core rail and this additional power is included in the E's per core power, thus making it higher than the LPE's? That would make sense.
Second, can Intel optimize the fab cell structure of the LPE's compared to the E's fab process to tune them for lower power operation? Meaning higher threshold voltage, less leaky transistors, easier to "flip on and off" but result in less max frequency?
If this is what is going on then it is very clever. Intel has essentially built a super low power processor within the low power processor.
The LPE island is NOT simply taking some E's and lowering the frequency. It really is a self-sufficient "island of compute."
511
5,544
4,942
Yes
They can but they haven't done it from the die shots I have seen for Lunar Lake it's exactly the same cores aka design someone like Tech Insight can know for sure with teardowns.
Well yeah it's self sufficient compute island.
Reactions: OneEng2 and Hulk
LightningZ71
2,712
3,421
18A doesn't have FinFlex/NanoFlex it's a TSMC Thingy
Intel refers to their RibbonFet tech as a competing solution that supposedly allows variable ribbon configurations on the same die, thick when higher current is needed and thin when better power efficiency is needed. RibbonFet is a feature of 18a.
MerryCherry
38
53
46
RibbonFET is Intel's name for GAAFET, no?
TSMC styles their GAAFET transistors as Nanosheet.
Reactions: Saylick
511
5,544
4,942
That's not part of 18A but 14A
Reactions: jdubs03
