Page 925 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
mikk
4,333
2,414
This looks like 10% better IPC from the Cove which is surprisingly good for a shrink generation. Maybe the improved fabric also helps.
Reactions: Tlh97 and Joe NYC
dullard
26,196
4,869
Geekbench values are strongly impacted by memory speed. The faster DDR5 could account for a lot of the improvement. Unfortunately, neither memory speed nor power consumption are not listed in the link.
jdubs03
1,508
1,096
Indeed, but it might be the case that the comparison is apples to apples.
This would be on the high side favoring ARL:
511
5,545
4,943
so roughly 5-6% higher perf/clock for PTL
mikk
4,333
2,414
MT sure, ST not so much.
mikk
4,333
2,414
This is a cherry picked best score of 100 entries, I'm not sure if this a good comparison since we only have on entry from 388H. Most better scoring 285H devices are between 2800-2900 on Geekbench.
jdubs03
1,508
1,096
I did caveat my comment that it’s on the high side.
dullard
26,196
4,869
Geekbench 6 also lists the average score: 2604 ST and 14796 MT for the 285H. So, compared to the average 285H score, this 388H test is 17% (ST) to 19% (MT) faster. But, we have no idea if this is a good performing 388H or a bad performing one.
Reactions: Tlh97 and DKR
Magio
209
251
Average score isn't a good indicator because plenty of results are from people running the benchmark on power save mode (or on battery on laptops that throttle when unplugged).
So the average ends up being made up not just of silicon lottery variations but also just un representative results. Whereas this is may not be a prime 388h but it's still a representative score.
I do have to say, I hope Coyote Cove + N2(P) make for a return to form in ST, this is an OK score and probably an efficiency improvement but the gap to ARM cores is growing larger and larger.
regen1
365
456
WCL should be a very good chip overall esp. for internal cost-structure but it likely won't go for ultra-cheap price brackets ADL-N/Twin Lake were.
WCL-Refresh(4P+0E+4LPE) should be even better for performance. Even the cost-structures of MTL-U and ARL-U(aka MTL-U refreshed with Intel 3) with more tiles and advanced packaging aren't that great.
511
5,545
4,943
Depends on the die size of WCL tbh but 2+4 should be better than 2+8 we are getting with RPL-U in PPA like lot better 3 Node Improvements.
DavidC1
2,192
3,343
Only peak scores without overclocking are relevant because that's the nature of user submitted benchmarks. That's why being able to easily arrange scores is so important.
Of course for Pantherlake it's early release, all the caveats apply, but since we don't know the extent of how far from a good configuration is, we can only do a general comparison. Sometimes we don't get full picture on the release date. I don't know why we are expecting anything near it now.
This is pretty realistic and in line with their slides. Better than a Tick but not their generational 15-20% gain.
I think only Arctic Wolf will show whether it can do this.
Just like Meteor/Arrow would show how Gelsinger's management would result in, and Clearwater Forest and Pantherlake would be the full culmination of it, Lip Bu Tan's equivalent would be starting with Novalake generation, and it would also show whether the E core team can keep up the impressive gains to actually have a chance to be a top industry core rather than just a blip on the radar for x86's excruciating slow decline.
DavidC1
2,192
3,343
Is there really a new category of "fans" of ARM vs x86? They are serving different markets ATM. They have went with different design choices.
Only because the bribery system(translation: lobbying in America) allowed laywers to protect x86 rather than blowing it wide open during AMD vs Intel lawsuits something like 40 years ago. Then we would have had x86 die long time ago replaced with ARM or everyone else would be on x86 including phones. Regardless there would be true competition rather than the moat they have created. Without that, Qualcomm for example would be a real threat as Intel/AMD would have to compete on performance and battery life alone. I don't believe what Intel/AMD is achieving with their cores is all that's possible with x86. They don't have true competition so we don't know the extent.
regen1
365
456
Better than RPL-U in those aspects, yes. WCL should be small(small 18A and N6 dies) and doesn't use advanced packaging. ADL-N and Twin Lake are pretty cheap as well and had the advantage of supporting DDR4 and DDR5. The ultra-cheap price points of ADL-N/Twin Lake SFF devices/Mini-PCS with memory and storage included might not be happen with WCL at its launch though eventually with time it can.
CWF and PTL won't really be the end of it. First Tock-level Core u-arch under Gelsinger was Coyote Cove(NVL)/PantherCove-X(DMR). Unified Core started at least in 2024(if not earlier), this could be the first core-design to be majorly under Lip-Bu Tan's leadership.
Product execution wise(from core-concept/RTL to SoC implementation) there has been some or more level of overlap of tenures(GLC started under BK but by the time it got released in products(ADL and SPR) it was under Pat. Similarly LNC started under Swan).
DavidC1
2,192
3,343
Transmeta achieved 45nm Atom levels of perf/watt using a 90nm chip and needing a translation layer. I can't imagine what potentials the x86 world would have seen with true competition. I think the problem extends down to rest of the ecosystem, including companies like Dell, HP, and Lenovo, component vendors like Acer, Asus, and even ones like Foxconn.
Apple's iPhone basically forced the ecosystem to haul their bums or risk falling into irrelevancy.
He got in at early 2021. You can't say it isn't mostly under his leadership. Design by itself takes a year. Rest are basically making it physical and implementation plus testing. Raptorlake they claimed 3 years from design to availability on shelves.
CEOs aren't responsible for low level decisions. You can't anyway, there's just not enough time. If he was a chief architect it would be different. Making sure the company runs smoothly so products are made smoothly, those are his responsibilities.
eek2121
3,491
5,190
You misunderstand and don’t give AMD and Intel enough credit as a result.
Current AMD/Intel chips are designed for scalable, high performance compute. ARM chips were designed for low power, mobile computing. Are there segments where they overlap? Sure, things like the Apple M series can reach desktop levels of performance. However, as they do that, efficiency begins to suffer and eventually the chip consumes just as much power as an Intel/AMD chip.
To put more simply: Every chip design has tradeoffs. AMD/Intel have chosen the things that matter to them the most, and ARM/Apple, Qualcomm have chosen the things that matter to them the most. For everyone, that is some combination of die size/efficiency/performance. It has little to do with the underlying architecture.
Reactions: booklib28
DavidC1
2,192
3,343
Single thread the M5 beats the 285K and 9950X not by a small margin while achieving far lower power. I don't give them credit because it's not worthy of deserving it. It's way bigger of a difference than Netburst to Core 2 or Bulldozer to Ryzen. It's equal to multiple generations of that.
I can't emphasize how big of a difference it is. My system after enabling all the P and C-states the system was noticeably less responsive. Also desktop equivalents are ~5% faster than laptop variants, at the same rated clock. 3.5GHz Lion Cove on desktop is 5% faster than 3.5GHz on mobile, with the exact same dies. Yet the M5 is still faster. So the M5 scales just as well as AMD/Intel chips do. Because it can go from phones to high end laptops.
Can you imagine if the world was really one ISA? All x86 or all ARM? And why can't AMD make a platform competitive with Lunarlake? Or why can't both get their P cores to fit on Smartphones? Is it that it's impossible, or they aren't doing it? Do you know how much the pro-AMD or pro-Intel folks would shout if their chip had M5 levels of perf/watt? Then I will praise them.
5,545
4,943
N3P vs N4P comparison really ? It's not bigger cause validation and backwards compatibility takes resourcing Apple doesn't give a damn about that AMD/Intel spent a lots of xtor on
SIMD no one seems to give a damm about it.
For example on N3E AMD Vector Units are like 0.78mm2 this is a very large area price to pay that people just ignore and move on.
Run SIMD code on Apple vs AMD and you will find it gets beaten in both power and perf/wattthe gap is not that big it's like 50% IPC in SPEC Int difference I remember Netburst vs Conroe being nearly double.
Simple answer design target's AMD is optimizing for DC Intel (IDK about P cores) but E cores are focused on perf/area and perf/watt Apple is ST perf and perf/watt.
Covfefe
125
229
"Scalable high performance compute" is what eek said. Apple CPUs only have up to 32 cores. So no, Apple CPUs do not scale up as well as Intel's and AMD's.
Reactions: Tlh97 and 511
Geddagod
1,684
1,720
Is it foveros still of emib? Higher bump pitch foveros?
2.5 years. ADL was 3 years. RKL, IIRC, was 2 years? Could also have been 2.5.
Problem is that they don't.
But Apple is lowkey also just better.
Things are so bad in x86 land that you can account for the FPU differences and still get really sad results.
Zen 5C in particular is a bad example of this. You can completely remove the FPU, getting an area of ~2.2mm2, which is only marginally smaller in area vs the Xiaomi X925 (2.56mm2), and is way larger than stuff like the mediatek x4 (1.5mm2).
ARM stuff would be better.
adroc_thurston
8,705
11,444
it's basic organtic laminate.
A very traditional CPU + PCH just with UCIe instead of OPIO.
dayum son x925 will never clock 3.7 in a DC env at 2W.
in DC?
hahahahha hahahahahah hahahhahahaha hot damn this is funny.
