Page 88 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
lightisgood
250
121
86
It's not just the chiplet partitioning, though that's not ideal either. The universal consensus seems to be that the SoC die is a mess. They rushed it terribly, and lost a lot of the architects midway through. Maybe Chips and Cheese can tease out some of the details.
There are some good ideas and notable improvements in MTL, but there's a lot of bad mixed in.
Most important things are ramping Intel 4 (+ Foveros etc...) in this year and competing MTL with APU.
Any other things are'nt important at all.
Reactions: SpudLobby
poke01
4,887
6,234
So glad T
Yes they are Jesus Christ what.
Intel failing to make their own IOD work well is a bad-bad precedent.
Yes, I had my doubts whether Intel would regain node leadership but that looks very unlikely.
Good thing future products are dual sourced.
deasd
610
1,045
I've got very good reason to think ARL doesn't have SMT either, take that for what it's worth.
Although admittedly, for the longest time I did just think it was a typo.
Other than copy-pasting what Apple/Qualcomm did, I guess it's due to TSMC process is not performance but high-density optimized, which cause frequency scaling lower than Intel's process? So Intel decide to disable SMT on client just for higher frequency?
TESKATLIPOKA
2,696
3,260
@TESKATLIPOKA, remember how I said there was a detail that would throw off your LNL projections. Well feel like recalculating without SMT :) ?
I thought It was something which would increase performance, disabling HT(SMT) is decreasing MT performance unless the saved power from the missing HT is enough to power additional E-cores, but 4+4 probably won't be very fast in Cinebench R23 MT for example.
I made a new calculation based on my old calculation. I will keep the clocks, but increase IPC by 25% for P-core and 15% for E-core, of course reality will be different, this is just for illustration.
LNL P-core 5.2GHz: 123*1.25=154 points
LNL P-core 3.9GHz: 100*1.25=125 points
LNL E-core 3.9GHz: 70*1.15= 81 points
Alder Lake P-core 5.2GHz: 123 points
Alder Lake P-core 3.9GHz: 100 points
Alder Lake E-core 3.9GHz: 70 points
Alder Lake HT 5.2GHz: 38 points
Alder Lake HT 3.9GHz: 31 points
Threads in use4P+4E Lunar Lake
3.9GHz for both P/E cores
2P+8E Alder Lake
4P+4E Lunar Lake
5.2GHz P-core 3.9GHz E-core
2P+8E Alder Lake
1125 [+25%]100154 [+25%]123
2250 [+25%]200308 [+25%]246
3375 [+39%]270462 [+46%]316
4450 [+32%]340616 [+60%]386
5531 [+30%]410697 [+53%]456
6612 [+28%]480778 [+48%]526
7693 [+26%]550859 [+44%]596
8774 [+25%]620940 [+41%]666
9774 [+12%]690940 [+28%]736
10774 [+2%]760940 [+17%]806
11774791 [+2%]940 [+11%]844
12774822 [+6%]940 [+7%]882
The missing HT could be felt at higher thread count.
eek2121
3,491
5,184
You made me go dig this up 🤣.
Note that this is for HP libraries. HD libraries are higher, but typically not suitable for high performance chips. Numbers are theoretical for both companies. Hopefully I made no errors copy pasting on mobile.
Intel 7 = ~60MTr/mm2
Intel 4 = ~123MTr/mm2
Intel 3 = ~160MTr/mm2
TSMC N7 = ~65MTr/mm2
TSMC N5 = ~95MTr/mm2
TSMC N4 = ~115MTr/mm2
TSMC N3 = ~124MTr/mm2
Note that companies can (and do) customize parameters that change these numbers. AMD does this, for example.
I will try and link the sources later if I remember.
SpudLobby
1,041
702
edit: rereading.
I think he might actually be right though. If Zen 5 for mobile is on N4P and Lunar Lake is on N3, ARL 20A, my thought had been the exact same, they’ll have a mobile process advantage.
Desktops I suspect AMD will go N3 and servers the same of some kind for 5C. But for mobile it’s shaking out to be Intel regaining a process advantage, no? I don’t know how long that will last and frankly it’s not a huge deal seeing as Intel will still have more competition than ever before, but still.
Apple of course will have been on N3 for a while by then and Qualcomm by early to mid 2025 (when I suspect LNL and maybe even ARL are actually available) might have a successor chip as well on N3 at least coming, pending lawsuit. Zen 6 won’t be tooo far off.
SpudLobby
1,041
702
AMD doesn’t use HP libraries to the extent Intel does, who basically scrapped those dense cells entirely with Intel 10/7 and likewise Intel 4 doesn’t even have any.
AMD relaxes the density some definitely and certainly customize the transistor choices so I doubt average density is crazy far off from Intel with HP libraries in Meteor Lake, but this is always such a silly sleight of hand people play when posting Intel’s HP peak density and claiming automatic champion, ignoring the use of HD everywhere other than Intel’s crappy design teams or that Intel’s last HD library straight up failed and they scrapped it.
Here was Zen 2 and I suspect Zen 3 and Zen 4 especially on mobile — followed up with a similar strategy.
I also again want to note yields count — Samsung shows that fairly well in a way beyond immediate catastrophic defects too — and TSMC entered quality HVM in 2020 with N5 and shipped *millions* of A14 SoCs or even M series SoCs.
This stuff is a [redacted] measuring contest on steroids, which is fine for academic purposes until we start getting to “who has the bestest process” with bad entailments and flawed premises along with total apathy towards _shipping_ working product.
SpudLobby
1,041
702
I'm pretty sure that Intel on their backside power delivery article they've already confirmed 20A on Arrow Lake next year, unless they retracted that statement..
I think there’s a rumor about it on N3 but only for desktops which would make sense for frequency purposes since N3 would be matured. I don’t know that’ll happen though seeing as the market is just only so large for desktops and may not justify it.
SpudLobby
1,041
702
There are some good ideas and notable improvements in MTL, but there's a lot of bad mixed in. LNL had the luxury to learn from some of that secondhand, and also much more relaxed requirements (e.g. all-in on TSMC, so no process worries).
Honestly I’d take their chiplet partitioning over AMD’s with the CPU split up, but they could probably do well to merge a few things e.g. maybe IO and SoC or all three and the GPU.
What’s the SoC rumor?
SpudLobby
1,041
702
The core just has no SMT, simple as.
They really-really want to be Apple, yes.
I’m all for it. AVX decision is questionable insofar as they promoted it and then backed out, but doing stuff like no SMT, a separate e core design, Lunar Lake as an ultramobile 4+4 chip, good stuff.
SpudLobby
1,041
702
What’s the main reason though in dropping SMT? I assume
Verification complexity
Design complexity
Security
Would rather save that 5-15% of area, not that it isn’t technically “worth it” for performance but that really varies, can also harm performance in some cases.
SpudLobby
1,041
702
Oh man... The SMT4 guy would've been so sad... 😥
In retrospect (or not for me) I always thought it was hilarious people got so excited about strange BS like SMT4 as opposed to just throwing more e cores at the problem and a bigger ST “big” core to handle beefier out of order code. It’s obvious which way the wind has been blowing and somewhat clear why.
19,219
But but but why can't the E-cores have SMT???? It's only 5% extra die space per E-core. Give them 50% larger cache and let's have DOUBLE the threads!
SpudLobby
1,041
702
But but but why can't the E-cores have SMT???? It's only 5% extra die space per E-core. Give them 50% larger cache and let's have DOUBLE the threads!!
It adds complexity in design and verification and the benefits aren’t invariably crazy at least relative to the die area. Also adds security concerns.
Finally it’s actually possible to hurt performance in some cases. Intel should focus more on great ST with efficient power consumption and strong concurrent performance with additional, area efficient (and/or power efficient) cores. The HT stuff is such a distraction imo.
ondma
3,321
1,714
I remain skeptical, but if ARL does in fact not have hyperthreading, how will that affect gaming? As far as I know games dont really use the e cores, but does gaming us the hyperthreaded "cores" on the P cores? Seems to me that loss of hyperthreading could be a big problem for gaming, and I though ARL was supposed to be a gaming focused architecture. Seems like eventually Intel is going to have to figure out how to offload gaming (at least some tasks of it) to the e cores if they are to remain competitive.
H433x0n
1,224
1,606
Those numbers are a little off, GNR will not be 160Mtr/mm2 when you account for the whole die. Intel 3 would only hit 160Mtr/mm2 on a theoretical smaller compute tile like MTL for example.
The TSMC numbers (per angstronomics)
N5 HP Cell: 92.3 MT/mm²
N4 HP Cell: 97.8 MT/mm²
N3B HP Cell: 124.00 MT/mm² (N3E is slightly less)
This is only comparing HP cells though. The N3 HD cells probably have better density, leakage and yield that could give an advantage to low power devices compared to Intel 3.
H433x0n
1,224
1,606
This is a really good take / counter argument.
I feel like this comes down to design philosophy and company history. Intel is not TSMC. Intel’s fabs never had much of a reason to be concerned with anything other than the HPC segment. They also never had the same incentives to achieve a D0 that would be comparable to a business like TSMC. Their fabs existed to produce Intel products, not necessarily produce industry leading margins or produce wafers to satisfy the requirements of companies like Apple.
I wouldn’t totally discount the the importance of HP libraries either though since it is the most important library for Intel going forward and it is a valid comparison since we’re comparing 3 & 4 fin libraries directly to each other. I also wouldn’t assume that TSMC’s advantage with certain segments of FinFet are eternal. The entire playing field is in the process of being reset with GAA & BPD.
poke01
4,887
6,234
HT does not have an effect on gaming. Apples CPUs do not have them and yet they are very powerful for gaming.
naukkis
1,030
854
HT does have effect on gaming. It makes games slower - some cases by big margin. For gaming HT is best turned off if there's enough cores without.
