Page 878 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,809
6,140
They offer piles of different gaming(tm) laptops aimed at different segments of the market?
I’ll narrow it down. The Framework Strix Halo 385 desktop is cheaper than their FW laptop 13 with a AI 7 350.
Many such cases where mini PCs are much cheaper than laptops.
Reactions: hemedans
poke01
4,809
6,140
all the halo NUCs start like like 1.5 kilobuck.
And halo laptops will be more expensive for less specs than the halo NUCs.
You can already see this with the HP halo laptop. Laptops are higher volume and higher margins for OEMs and AMD, Intel.
adroc_thurston
8,471
11,197
They're more expensive because they're expensive laptops, not because they have halo inside.
Again, barebones NUCs with stxH start at like 1.5 kilobuck.
That's bananas expensive.
ToTTenTranz
935
1,549
Intel released a video yesterday about Panther Lake's iGPU:
They specifically namedrop handhelds. I wonder if we're getting a MSI Claw with Panther Lake as one of the first PTL devices out there.
ToTTenTranz
935
1,549
Does it matter at all whether they're calling it "Arc" or "Arc-B"?
This is probably happening because Xe3 discrete GPUs are still far away and they don't want to Osborne their current and future Battlemage lineup.
Besides, videocardz' table is wrong. Arrow Lake uses an Alchemist Xe LPG GPU, not a Battlemage Xe2 like the one in Lunar Lake. Intel is already mixing up two GPU architectures within mobile processors under the same branding. And yet, performance and capabilities are similar so most people don't care.
CouncilorIrissa
786
2,854
It does, because Xe3 is supposedly a much more capable IP that shouldn't have to carry BMG's baggage (CPU overhead was fixed, but the damage has been done).
poke01
4,809
6,140
50% faster than LNL like i said sadly bottlenecked by memory :(
It’s not bottlenecked by memory. There’s barely any core improvement.
No wonder it’s under Battlemage still.
Edit: maybe I’ll just wait for tests.
DavidC1
2,154
3,295
Who said there were no core improvements on Cougar Cove? I think Adroc was one of them.
The front end has been reworked to deliver a steadier instruction flow, while the scheduler issues work to the execution units with fewer stalls. Internal structures such as the dispatch and allocation queues have been slightly widened to balance throughput and energy use. Together these adjustments yield roughly five to ten percent higher performance per clock at the same frequency.
The earlier leaks saying 5-8% were right.
Darkmont improves:
-Branch prediction
-Dynamic Prefetcher controls
-Bigger Nanocode coverage
-Better memory disambiguation
Pantherlake also finally balances it so more power is given to GPU rather than CPU. This will improve standing compared to competition. Previous architectures would often give too much power to CPU, starving the GPU core.
Reactions: DKR and Elfear
ToTTenTranz
935
1,549
It doesn't because ~99% of the people using Intel graphics aren't using an Intel dGPU.
Heck, the vast majority of people using a modern Intel GPU for gaming aren't using an Intel dGPU, either. They're using a Xe1 140T or a Xe2 140V.
Intel kept the iGPU Xe2's branding under A-series despite being architecturally similar to dGPU B-series, and now they're doing the same with Xe3 under B-series.
There's a whopping 16MB L2 in there meaning they increased the L2 per core by 50%, and then it can access up to 18MB L3 on the Compute Tile.
Plus, the NPU can also access the L3. Although Intel doesn't mention this, it probably means Panther Lake could efficiently offload the upscaler to the NPU, unlike AMD's SoCs.
Reactions: Elfear
