Page 876 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
fastandfurious6
922
1,059
Halo is all you need
from 2025 onwards no distinction between desktop/laptop chips, they're the same
efficient interconnect = even handheld can reap big perf of 9950X desktop chip at 30W / ULW
so what's the point about H chips which are nerfed by default? Just get half cores 9700X still better
and yes AMD should make 3Dcache accessible in more models lollll
Reactions: Elfear
poke01
4,806
6,131
Cost?
Reactions: Tlh97 and hemedans
Philste
308
486
Yeah. The top one is a meme of meme volume, mainly for benchmark purposes. Intel's done this before. The lower 7 bin is the one that OEMs will use.
If the clocks stay at least reasonable close, i dont think it's that big of an Issue. For LNL it was -300MHz on CPU and -100MHz on iGPU for 258V and 288V, with the 268V with only -100MHz on the CPU as well. That's a 5% difference in ST at best.
AMD did the same 4 Years ago with Cezanne. The 5980HS/HX were nonexistant. The HS had one Asus Device, the HX was never seen. They had advertised 4.8GHz back then, they ended up with the 5900HX/HS with 4.6GHz as Top End.
Reactions: Tlh97, mikk and 511
Covfefe
101
180
Interesting that from AMD side they chose Zen 2 but for Intel they chose Lunar Lake.
Do they think that Lunar Lake is the first competent Intel architecture since Haswell? Or did Intel give them incentives (like free laptops or goodies etc.) and also to promote their laptop sales?
Which reason could it be I wonder? :rolleyes:
Looks like they picked technically interesting and historically significant architectures. Zen2 and Lunar Lake are some of the most interesting CPU designs in recent years.
Zen2 was AMD's first modern chiplet CPU. They hadn't moved to 8-core CCXs yet, which means two CCXs per CCD. It was their first AVX-512 enabled CPU. AMD primarily uses chiplets for cost savings via better yields, design reuse, and older nodes for less critical chiplets. AMD's chiplet strategy has remained more or less the same since Zen2.
Lunar Lake's chiplets are far more advanced than AMD's. The chiplet interconnect is more advanced. It has more bandwidth, lower power consumption, and uses a base tile. The chiplet architecture is probably cheaper than a monolithic N3B CPU (otherwise, why would they bother with chiplets?), but the cost savings aren't nearly as big as AMD's approach. Lunar Lake also has heterogeneous cores (p-cores and e-cores). It's e-cores are used for low power workloads AND multithreaded performance (I believe it's the first Intel CPU to use e-cores that way). And it has on-package ram, an SLC, and an NPU.
regen1
351
432
Three 4+8+4+12? Why?
That's nothing out of the ordinary, has been the norm for a long time.
The top die config used as:
(i) i9/u9 for the highest bin/max clocks.
(ii)i7/u7 vPro SKU(plus higher clocks than the mainstream i7/u7),
(iii)the more mainstream i7, generally has been the most available in designs
i9 12900Hi9 13900HU9 185HU9 285HTop bin/highest clocks
i7 12800Hi7 13800HU7 165HU7 265HvPro SKUs, higher clocks than mainstream i7/u7, mostly available in business and and some premium designs
i7 12700Hi7 13700HU7 155HU7 255HGenerally have been most mainstream SKUs of this die config
The only major new thing about PTL(-H?) line up is that there are two versions of these chips: one with 12Xe3 tile IGPU and other with 4Xe3 tile IGPU
dullard
26,191
4,856
One thing that I'd add is that the "top bin/highest clocks" category also usually comes with a much higher TDP. Yes, it can clock high, but you better be prepared to have it suck down the battery (or most likely run it while plugged in). These are simply the chips that are binned to be able to take the heat.
Take the 285H, its base power is 45 W vs 28 W for the other Arrow Lake chips in your post. Same type of power difference goes with most of the other generations you listed.
Reactions: DKR
regen1
351
432
Yeah, the flagship has higher power budget for sustaining more clocks for multiple cores(also at various power configs/levels as well).
Reactions: DKR
Fjodor2001
4,584
732
Some more Panther Lake leaks/info from the AMD tech event held on October 2:
”The company conducted hours of technical briefings and factory tours in Arizona for industry analysts last week on the new Panther Lake microarchitecture, including detailed explanations of the graphics and central processor cores and its media engine, according to the sources. Intel revealed a redesigned AI engine and the company's efficiency and performance processor cores, which were redesigned for the 18A manufacturing process.”
”Intel executives have said the Panther Lake chips will be available early in 2026, according to the sources. The new chips use 30% less energy than the prior generation, and its graphics and central processors will receive a 50% boost in their ability to crunch data in some situations, according to a second source briefed on the chips.”
poke01
4,806
6,131
There has to be benchmarks in those slides right
RTX2080
347
551
Reactions: 511
poke01
4,806
6,131
PTL graphics will set a new standard for the whole industry according to Tom Petersen
