Page 963 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,154
3,293
Halo is N4P + tech from 2022/2023 (by 90%, the rest is LP, unified memory etc)
And what's your point? Intel in 2019 vs Zen 3: "Intel has an outdated core from 2015 with 14nm process versus AMD's 2019 core and 7nm process". Were you defending Bulldozer in 2010?
AMD chose not to implement the latest tech in their consumer lineup.
Battery life might be pretty good on Panther Lake. That's about it. Intel shouldn't be charging THAT MUCH just for some extra battery life though.
They are not though. Pantherlake is only 30 Euros(1770) versus more than AMD's Gorgon Point(1740). If Pantherlake goes up in price compared to predecessor, so does AMD's Gorgon Point over Strix Point.
@Hulk Integer differences can't be explained by memory system differences. It's mostly uarch. SpecFP at some point is basically a memory benchmark. Also Geekerwan shows different results for E vs LPE.
It's because Zen 5C is clocked lower, and ipc generally decreases as clock speed increases, esp if u are memory bound.
Ding Ding Ding! Likely in that review they just took the score and divided by the GHz numbers. In Geekerwan's review, it looks like they actually took the liberty of lowering the P core clocks.
DavidC1
2,154
3,293
The 4 Xe core version doing that well reminds me when they introed Celeron D based on the Prescott core and that chip beat the Northwood based Celeron by 25%+. The uarch gains are having oversized gains in lower end where it's artificially segmented, thus crippled. It only has 4MB cache, meaning it's uarch doing all the work.
Also, this is actually proof that it can't be memory bandwidth bound. Actually there's two proofs. One is that with 1.5x compute it gets 1.7-1.8x gains. And the other is the 4 Xe core version with only 4MB cache is doing this well.
Wildcatlake's 2 Xe can probably beat 96 EU in Iris Xe of pre-Meteorlake processors. That means ~4x faster than predecessor, allowing low setting gaming for modern titles.
Reactions: sgs_x86
fastandfurious6
931
1,070
One big difference among many:
In 2019, Intel didn't have any better tech to implement 😉 they waited for Alderlake which saved them.
AMD does have plenty: Vcache, RDNA4... isn't 2nm Zen6 also almost ready?
DavidC1
2,154
3,293
It makes no difference. It's all a black box. None of what we argue here makes an ounce of difference. AMD chose not to implement them. Right now Intel is the more consumer friendly vendor. They actually talked decently about PCs, versus AIMD and NVAIDIA.
It seems you always need to feed people a slice of humble pie once in a while at least.
Hulk
4,056
Looking back the ST IPC equivalence of new/old cpu's is astounding.
Cinebench accelerators/E core spam used to be our top dog Skylake
Then the spam morphed into Golden/Raptor Cove!
Are they still spam I wonder?
Skylake~Gracemont~Zen 3
Raptor/Golden Cove~Skymont~Zen 4
Lion Cove~Zen 5
Reactions: Joe NYC
511
5,408
4,819
I wouldn't count Multiple Cores with Int/FP of Golden Cove Spam cores.
Lion Cove~Zen 5
Zen 3 is a decent bit better than Skylake gracemont it's in the same class as sunny cove iirc
Hulk
4,056
I don't think they are spam either. But some in here do.
For ST, Gracemont and Skylake are pretty even, but not core-for-core.
Reactions: 511
DavidC1
2,154
3,293
It seems Gracemont has the capability to do it, but in actual implementations held back by the shared L2 cache and generally slower uncore.
But Skymont shows that it was close enough that you can substitute instead of the P core in even gaming scenarios. Remember the Arrowlake test where 1+16 is faster than 8+16? Or how in Pantherlake they are prioritizing E instead of P?
Jim Keller said Skymont was made to directly compete with Zen 5. With Gracemont it was architecturally a slower core than Zen 4C. It no longer is the case.
DrMrLordX
23,201
13,289
Wasn’t that intended/expected and 18AP and 14A will be for higher clocking CPUs?
Diamond Rapids-SP was supposed to be 18a. Diamond Rapids-AP may wind up being on 18AP.
Was there time and effort for 18a that can’t be used for upcoming nodes and products?
Sorry, but what?
Where are the sub-$1000 Pantherlakes? This is supposed to be a low-power SoC that doesn't even operate above 25W. It's like Lunar Lake all over again. Also how is Gorgon Point relevant when Pantherlake is competing with the now-quite-old Strix Point?
