Page 858 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,340
4,754
The clocks are still not final xDd though is it 5.2 oe 5.3 we don't know
511
5,340
4,754
OEM will tease everything but the specs
16inch less than a Kilo Battery Killing OLED Display.
poke01
4,761
6,095
ToTTenTranz
908
1,519
Interesting they don’t mention “faster cpu”.
They're clear about a faster GPU, though.
I do wonder how Panther Lake's Xe3 will behave against Strix Point's 16CU RDNA3.5, as the 140V and 140T are already pretty competitive with that model.
It does look like Intel will have an iGPU performance crown on the 15-35W range, at least until Medusa Premium comes out.
511
5,340
4,754
Medusa Premium has how much CU and which arch? also that would likely compete with NVL iGPU.
ToTTenTranz
908
1,519
Medusa Premium has an AT4, so 12 RDNA5 CUs (supposedly close to 24 RDNA4 CUs in throughput per clock).
I think we only know the specs for N1X so far, which is way too big and will probably be closer to Medusa Halo. There's also a "N1" for laptops and perhaps that one will be competition to Medusa Premium.
Reactions: Tlh97 and 511
511
5,340
4,754
Reactions: DKR
DavidC1
2,106
3,227
If what that reddit guy is saying is true and that Darkmont is quite a bit more efficient ISO-process(~10%) and 18A is better, then it can potentially counterract losses from Lunarlake from a battery life point of view. In Lunarlake, Skymont LPE is half of the reason it gets good battery life. Pantherlake may still lose in light load scenarios, but if Darkmont makes it up in less lighter loads such as Teams then overall they can call it similar.
I know that even for Alderlake laptops you can get great battery life, but you need to go through lot of work to get there. Cut all the services running to a minimum, have Task Manager up frequently to check for mis-behaving applications and find a way to terminate them or make them work properly, have all basic power management settings work such as Drive power savings, plus get drivers of every single component in your laptop updated to the latest. In reality, that is not feasible as vanishingly small amount of people know how to do this. I don't even have more than basic MS antivirus enabled for this very reason, because I know it's much harder to get 3rd party antivirus software working with low demand enough to keep the CPU utilization under 3% for the application.
The other day I was frustrated with my 10th Gen Pentium Desktop struggling with OpenOffice, when computers of 40 years ago could do the same. Some articles were talking about increasing abstraction as a culprit. The whole computer market is a pseudo-ponzi scheme.
Having a dedicated power efficient core offload things so you don't need to to the above improves things for the average scenario, because inevitably the demand rises due to inefficiency in software or whatever other reasons.
Reactions: 511
desrever
335
824
Exactly it means the Effective CPU Performance is unchanged just better Power Efficiency if it can Deliver ARL performing at LNL Power Budget I would still call that good.
It also doesn't claim better battery life. So...
19,209
Geddagod
1,655
1,691
Just a thought, one has to speculate about Intel shortening the pipeline of their P-cores as a pretty good thing. Keeping the same high Fmax, while also having the side effects of slight IPC increases, and lowering the need to spend a bunch of resources on the BPU, since the branch mispredict penalty will also be lower.
511
5,340
4,754
PNC is clustered Decode with shared L2 it's more like Atom in Nova than a P core
Magio
205
242
GB 6.5 is suspiciously close to Panther Lake launch. Could this mean Panther Lake supports APX?
GB 6.5 is equally close to A19 Pro and 8 Elite Gen 2, tho (who knows, maybe they'll finally rebalance the benchmark now that non-Apple chips will benefit from the SME boost). I think up to now rumors were that APX would only be in Nova Lake?
5,340
4,754
Dude!
Both FRED and LKGS deal with minimizing the context switch latency so Intel could gain substantial wins in multicore I/O heavy workloads (think streaming games especially!).
This needs to supported by OS as well knowing windows see you in couple of years on Linux we should be fine.
