Page 856 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
939
851
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,752
12,486
This roadmap is plain wrong MTL Launched Q4 23. ARL Launched Q4 24. LNL was Q3 2024 so how can we expect everything else to be right.
Could be OEM roadmap which would mean a delay from CPU launch to actual model availability.
511
5,338
4,753
It would be the lowest Tier OEM tbh if it has to be but I wouldn't put a stock in a roadmap that has past data wrong.
dullard
26,187
4,853
Which OEMs had available models at MTL launch?
1) OEMs don't generally have laptops available at launch. It takes time for them to receive the chips and design thermal systems around them and their particular hot spot locations. Cooling on a thin device takes custom work.
2) OEMS do generally have desktops available at launch. The desktop chips tend to be plug and play, working at least somewhat decently with cooling systems already available.
Guess which category Nova Lake is.
Hitman928
6,752
12,486
So you’re saying that if it is an OEM roadmap, that the timing of the already launched products shown on the road map would make sense. . .
511
5,338
4,753
they have 1-2 models to buy at launch the real volumes come after the product is fully ramped up
NVL covers everything Desktop/Mobile
naukkis
1,030
854
Clearwater Forest clocks slightly higher
59TFlops for 576 cores.
With 64-bit compute, each core can compute 8x Flops per GHz. Let's assume 3GHz.
4x128-bit units x 128/64-bit x 3GHz x 576 cores = 13.8TF
So for the math to make sense, they are using FP16 for "AI". At 3GHz that equals to 55.3TFlops. To reach 59TFlops, it needs to be 3.2GHz, which is 200MHz higher than the peak frequency of Xeon 6780E Sierra Forest. There's potential to reach 3300 in 2P SpecIntRate, which is 2.3x SRF.
Skymont can do 4 128 bit FMAs per cycle. So you need to double your calculated flops - so maybe it achieve those 59Tflops with fp32 instead of fp16.
Reactions: DavidC1
dullard
26,187
4,853
Having every just about every launch be in Q2 of every year regardless of CPU launch date should give you some clues about the roadmap. Also that should give you clues that it has nothing to do with CPU launch dates.
Reactions: MoogleW and 511
Hitman928
6,752
12,486
So again, if it’s an OEM roadmap, it would make sense as they do annual refreshes, typically releasing in Q2 timeframe. . .
ashFTW
328
251
They are only replacing the Compute tiles from Darkmont to Arctic Wolf also the IO tile will be on Intel 4/3 for DMR/RRF.
Clearwater -> IO Die I7(Reused with GNR/SRF) ,Base Die 3T,Compute 18A.
DMR -> IO Die I3/4, Base 3T, Compute(Reuse from Clearwater ?) -18AP
RRF -> IO Die I3/4, Base 3T(Reuse From Clearwater?), Compute - 18AP
No way DMR uses Clearwate Compute tile. All Rapids are P-core, and Forests are E-core
ashFTW
328
251
I made a typo it should be the base die that is shared
I’m thinking DMR could use similar tile architecture as CWF. If it’s being upgraded to DDR6, then the base tiles will update. There could also be fabric/LLC upgrades. The compute tiles will likely be bigger, with a more mature 18A, perhaps one per base tile instead of 4 as in CWF. Is PCIe 6 possible? Then IO tiles will change as well.
Come to think of it, since it’s a new platform and will be around for 2-3 years, all tiles will be newly designed but borrowing heavily from the previous generations.
fastandfurious6
900
1,036
I'm reading on the net
"next-gen Darkmont @ Intel A18 will be very similar to Skymont except node and will have perf less or equal to zen5 compact"
Again the same pattern:
- every new Intel node keeps failing on making high-end cores
- focuses only on mid-end efficiency/mobile cores
- P cores = pumping extreme power to reach parity with AMD
511
5,338
4,753
it will be less than Zen 5 in AVX-512 or SIMD Heavy Workloads for sure
Keep dreaming Fitting 288C in 500W is no small feat AMD Could only do 192C on N3E
Reactions: DKR
