Page 857 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
LightningZ71
2,666
3,362
Which was my point.
AMD took a more performance base core with HT for their dense product. Even if the HT core only averages a 20+% MT uplift for the core, it's still giving you a ton more active threads. While individual VMs may only be provisioned with a few threads, they won't keep those threads fully populated with work either. In practice, those extra threads allow more active VMs without significantly degrading the performance of the others per rack unit (assuming no over provisioning is in use, but that also has some advantages for AMD as well).
The e cores for Intel should have had HT. Yes, cache per thread would have been an issue. There was an easy solution to that, dumping two of the P cores and doubling the L2 for the e cores. If the P cores had been bespoke for desktop and designed for maximum ST performance, those 6 cores would have given them all the ST performance they could have needed. Spreading the core out to 2+8+2+8+2 when viewed left to right would help isolate all the P cores hot spots better in low thread ST scenarios. You'd then have a 22/38 thread product competing against AMD's 16/32 product, likely absolutely pantsing them in MT performance while doing even better in ST as well.
It would have hurt their forest server products though, but they could have retained the smaller cache there and allowed the customer to decide on HT.
Reactions: Tlh97
511
5,340
4,754
You need 2X the thread to gain 20% more Performance. I agree with the VM part though
LightningZ71
2,666
3,362
192x1.2= ~238 core equivalents. How much faster is that C core than the competing Intel e core? We also have to take cache structure and performance into account too. All of this is excluding the full width AVX-512 in the V cores as well for those loads.
I don't doubt that, for a load that specifically is 288 threads, that doesn't use AVX-512, that the Intel E cores product will be faster. It's when you get to general compute where I have my doubts about the efficacy of the e core approach...
TheJudgeSarov
511
5,340
4,754
General purpose compute is not AVX-512
LightningZ71
2,666
3,362
When you are hosting VMs for external customers, they can run anything on it, including AVX512 loads. That's what I mean by general purpose.
Reactions: 511
Covfefe
90
154
66
Hybrid Cores is coming
Fwiw, Ian Cutress says this is nothing.
https://old.reddit.com/r/intel/comments/1n33e3u/intel_patent_software_defined_super_cores/nbhybr7/
Intel acquired Soft Machines in 2016, who pioneered the concept of VISC which people called 'reverse hyperthreading'. Some idiots threw speculation that SkyLake would have it, but idiots being idiots. It's since been a quiet research project and/or mothballed internally.
Reactions: Thunder 57
OneEng2
971
1,183
for highly treaded DC usage (CWF's main usage), SMT gives much more like 1.4x-1.5x in general. At 1.4x using a 256c/512t Zen6c Venice D as competition, Venice D would be the equivalent of 358 CWF cores.... if it was AVX512 enhanced code, then more than that.
My point is that CWF (by the latest rumor) will launch in 2026 .... as will Venice D. I suppose months matter, but Intel leaving out SMT from the design is going to cripple them IMO.
Additionally, Venice D will have more bandwidth (1.6Tb/sec vs 1.3Tb/sec).
I do think that Intel will release CWF prior to AMD releasing Venice D, but I am wondering how much volume they will be able to produce before they face the Venice D competition?
Reactions: Tlh97
LightningZ71
2,666
3,362
Their largest customers will have samples of both vendor's parts long before release day...
OneEng2
971
1,183
And I am thinking that leaks should be a prelude to any release because of that 😁.
So far there has been nothing of consequence leaked on Intel or AMD.
Joe NYC
4,126
5,673
Yeah it will be 100% eaten by zen6. Time would be their advantage
When leaks for ptl and zen6? Hmm
In mobile too? We don't know anything about the first mobile Zen 6 products to be launched and when. Only about RDNA5 based Zen 6 that will be probably 1 year behind PTL to market.
There should be the Gorgon Point CPUs in the meantime, which will initially be the competition for PTL from AMD side, and these are still Zen 5.
LightningZ71
2,666
3,362
I think we'll all be surprised if Gorgon Point is anything more involved than the Phoenix Point to Hawk Point transition.
511
5,340
4,754
He is dreaming PTL is scheduled to launch before Zen 6 and by Zen 6 Launch it will be in High Volume and Zen6 will barely have any volume.
Reactions: DKR
adroc_thurston
8,249
11,000
It's even more PITA for cooling 🤣
Cooling is fine, hybrid bonded stacks are fine thermals-wise (see MI300X/A/yaddayadda. Or fat full-frame tri-stack sensors from Sony).
Yields, OTOH, are hard.
Frankly, they should've kept BSPDN as optionality for 18A.
