Page 859 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
856
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,352
4,764
Too bad Intel botched ARL the IMC is crazy good in ARL
19,209
Intel did not bribe they simply did the entire stuff on their own why do you think there were so less problems except for few DRM issues I don't think MSFT is even capable of that.
I don't think M$ would let any external party near their source code. It's their proprietary secret sauce.
511
5,352
4,764
Well if they won't allow that with AMD or Intel windows would be in a bad state there are specific work that Intel/AMD do that reaches MSFT
MS_AT
927
1,848
This needs to supported by OS as well knowing windows see you in couple of years on Linux we should be fine.
Out of curiosity in which areas Linux leads Windows support when it comes to Intel CPUs? For Alder Lake it was the other way around iirc, it took months for Linux to treat E cores properly. The one thing I recall was related to improper handling of Lunar Lake, at least Charlie was babbling about this and low CB24 scores.
This is what NDAs are for. In business you build relationships on trust, and I am sure M$ trusts their formidable army of lawyers;)
5,352
4,764
Scheduling in Linux the core handling is a tad bit better also the LNL thingy existed on Windows as well if the power profile was set to battery saver
19,209
Sucks that they couldn't put the new cores in Arrow Refresh. I mean, how hard could it have been? Just search and replace Lion Cove and Skymont with Cougar Cove and Darkmont in the design files, right?
RIGHT?????
511
5,352
4,764
RIGHT?????
You need a new mask new stepping for 8+16 Tile which would still suck due to the horrible uncore of ARL
Reactions: MoistOintment
19,209
PTL-HX was on 18A it doesn't exist anymore
Because 18A wasn't good enough in time for it. They should have put NO egg in the stupid 18A basket and bought more TSMC capacity. Use 18A for test chips and silly stuff like Bartlett Lake 12P shrink and Skymont only N405 netbook chip until yields improved enough to ditch TSMC. Idiots. And they get paid really well for making idiotic decisions.
19,209
By the way, the APX spec doc latest one is over 300 pages. No wonder they gonna rewrite code dynamically and inject into game executables for Nova Lake. It's their only hope of a win, at least in some high profile titles.
Thunder 57
4,249
7,044
Despite what that clown says they are not going to do that. Having different executables floating around out there would be a nightmare. How much could they hope to optimize them anyway?
511
5,352
4,764
Sooner or later everyone has to do this just like we had x86 and x64 binaries but I don't think it will start as soon as NVL Launchea except for few games.
Thunder 57
4,249
7,044
There's a difference between compiling with 32 or 64 bit in mind (or APX someday) and tearing open a compiled file, "optimizing it" and re-compiling it. AV and anti-cheat would be all over it.
511
5,352
4,764
i definitely don't believe the clown for that part but i can believe Intel Forcing some developers to use More Modern Instruction or compiling with APX/AVX10.2
19,209
Unless Intel also inserts some kind of crypto key in it to confirm authenticity and shares that information with AV/anti-cheat software authors. I know, it's a big ask but at this point, Intel may do anything to get back their edge. They went to the trouble of creating APO, remember? Instead of just admitting their stupid mistake that hybrid cores suck.
I bet before every hardware launch, in front of their software people they go, "Your mission, should you choose to accept it, is to cover up our hardware design teams' follies. Failure to do so may result in your jobs self combusting".
MoistOintment
144
221
Shrinking Bartlett Lake to 18A makes no sense. Its whole purpose is to cheaply utilize existing IP and spare Intel 7 production capacity for a NEX/Embedded product line. Shrinking to 18A defeats the entire purpose.
RIGHT?????
The *primary* difference between new cores and LNC is that they're on 18A. Any design changed is largely inconsequential. Porting that back to N3, with all the costs associated with that, makes no sense. Especially not when the final result would've been functionally an identical CPU thats still uncompetitive and low margin.
19,209
The point is to refine and improve 18A until it's ready for HVM (in other words, able to replace Intel 7, 4 and 3). Using a tried and tested older design helps them get there faster. Tick/tock cadence worked for them before because they tried not to chew too much by putting a new untested design on a brand new process. And now they are doing exactly that and the yields are in the gutter.
DrMrLordX
23,180
13,266
Intel doesn't have enough leverage to bully people into doing something like that. The only reason why future developers will consider supporting AVX10 seriously is that both AMD and Intel are adopting it (apparently) as a part of their x86 working group.
Why? They already have Panther Lake as a pipecleaner product. They also have limited EUV capacity which has hampered Intel 4 and 3 volume and which will affect 18A volume in the future.
19,209
When a brand new architecture based test chip comes back, how do they know that the bugs it is experiencing are from the architecture design flaws or the process? Using an older design that they know hasn't got any design flaws helps them weed out the process issues much quicker.
As an analogy, does a person who changes one overclocking parameter at a time, extensively tests that and only moves to changing the next parameter find more success than someone who messes with multiple parameters in a single go? Obviously yes.
