Page 835 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Gideon
2,044
5,103
Yeah, the amount of bad press coming in such a short timeframe did look suspicious, grounded or not.
It's been clear since last summer that the contingent within Intel that wants to give up manufacturing has been strategically leaking info to Reuters to drive their narrative. It started out with with the "Broadcom doesn't like 18A" and "Intel missed out on PS6" stories, both of which were dubious in the framing of some of the information presented, that paved the way for Gelsinger's dismissal and has continued since.
Now, just because there seems to be a goal behind that constant stream of stories doesn't mean they're not accurate. But the good thing with this one is that if it's true, PTL cannot and will not launch near its planned window.
jpiniero
17,172
7,550
Well... what matters is what the salvagability is of Panther Lake. In particular the 5 model. If yields were bad, they could just cut the core count of the 5 model and maybe also do a 3 model (or even "Intel Processor")
Although Arrow and Lunar didn't cut the core count. Course that's likely because they were fabbed at TSMC.
DrMrLordX
23,209
13,296
10% PTL yields by the summer sounds so catastrophically low I don't even know how they could launch PTL (even in limited volume) by early 2026 if it's an accurate figure.
10% yields on such small dice would be catastrophically-bad. That's probably worse than the Ice Lake-SP situation. Anything 40% and below means setting wafers on fire just to get product out the door.
Magio
207
246
And hell, back with Ice Lake at least they had DUV capacity to brute force once they really wanted product out the door. They already have limited EUV wafers, there is no way to deliver PTL at any sort of scale with yields like that.
And not delivering PTL means screwing their OEM partners whose 2026 plans all hinge on this, which in turns blows the door wide open for AMD and Qualcomm to take over in that space.
If this is accurate, Intel is several orders of magnitude more screwed than we thought they were.
DavidC1
2,174
3,327
Reuters have been in hype news mode for a while now. While there could be bits of truth, such sensationalist articles all the time loses trust in the overall publication over time.
Only time will tell.
branch_suggestion
893
1,945
18A parametric yield is horrible. This is no secret, many sources have been saying the defect rate is fine, but the clocks are very not fine.
To the guy who ran away from here, your "higher performance than N2" node doesn't get any of the parts that actually clock high.
Those are on N2 Nanoflex, the actual highest performance node on the planet surpassing any Intel node in clocking potential even at lower Vmax.
It is an alright node for lower end mobile parts I guess. Same issues as Ice Lake basically.
DavidC1
2,174
3,327
Not just Icelake, but Cannonlake. That the defect rate was acceptable but parametric yield was bad. If you take a look at the released parts, it had to be downclocked, meaning it couldn't clock as high.
Then there was strange rumors like iGPU needing to be disabled. Since GPUs are more repetitive structures it doesn't point to defect rates.
If true, this would explain why Novalake is using N2 on high end desktop.
The issue with this is even on 18A it sucks more on mobile, so when you are saying mobile you are talking laptops, meaning on tablets/phones it's even worse since they can't meet their own goals.
Short of a huge breakthrough, 14A being cancelled seems like a done deal.
511
5,431
4,855
They did it with Ice Lake
Who is going to subsidize the node though in ice lake era they were in a better position financially and in terms of control.
It's gonna cause them a huge loss also surely the layoffs didn't affect the yield.
branch_suggestion
893
1,945
Oh no Cannonlake was <10% parasitic yield, the only part shipped was ~100k i3 garbo bins to China.
OG 10nm was worse than A0 Fermi.
This isn't remotely that bad, PTL has lots of errata from design issues with the early PDK but those should be resolved by the production stepping.
The clocks are stuck below 5Ghz, that is the big issue.
Reactions: Tlh97 and Joe NYC
DavidC1
2,174
3,327
Was it actually under 10% or hearsay, because I heard both arguments.
No halo products they will sell I5 as long as it's 4.5-4.8ish range there will be no other way.
One one side some are expecting NVL to reach 6.5GHz+ while not answering how it works with the >10% ST gains
While on the other side, we're expecting i5's to be under 5GHz, which would be a record difference in SKUs.
I think a more reasonable explanation is NVL doesn't clock higher than Arrowlake.
511
5,431
4,855
Cause that part is on N2
PTL SKU also i5 have mostly been under 5Ghz on mobile(not counting HX).
This is on N2 so if they doesn't hit 6+ GHz it's a failure in design.
Reactions: Joe NYC
DavidC1
2,174
3,327
No, it's a failure in design if a part that clocks 10% higher performs >10% higher.
Cannon Lake sucked in Both D0 and Parametric it was a disaster of a node.
That does qualify as a disaster, especially when node gains are shrinking.
