Page 822 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,184
3,331
PMIC/MoP with optimized PHY For Power are the only difference between Lunar and Panther Panther is a derivative of Lunar.
What you said are feature checkboxes. It tells us NOTHING about how it will actually do.
If it was a direct successor to Lunarlake, they would have shouted it. Modern Intel rubs it in your face if they actually have a good product. They were being very coy about Pantherlake and Lunarlake successor, so does their roadmaps.
And even if they were the only difference, the reduced PHY is a BIG deal. It allows 1W savings in certain cases, which is 30% difference on a 50WHr battery and 1080p screen. I'm pretty sure people will notice the difference between 12 hours and 15 hours battery.
Now do I think PTL is as efficient as LNL in every way? No. But do I think the ways it will be more efficient (I believe 18A will be a measurably better node than N3B, arch refinements, media engine refinements, ...) will make it overall as efficient or more? I do actually believe that. But we won't know for sure until it launches of course.
Process does almost nothing for battery life on modern processors. Otherwise you'd see significant battery life advancement with a new process. Only design matters.
And on a laptop you need the whole ecosystem to be focused on it.
poke01
4,872
6,201
not using PMIC for PTL will also decrease battery life
511
5,452
4,879
It's just he only difference I am aware of between LNL/PTL and these affect battery life
Yeah
Reactions: Io Magnesso
Doug S
3,836
6,785
There is a reason why Intel made fun of Qualcomm last time. They are a threat to Intel, not Apple.
Exactly. Apple has done its damage to Intel, and can't hurt them any further. Apple might even help Intel in the future, if they ends up throwing some fab business Intel's way.
Qualcomm hasn't hurt Intel yet but could if Windows/ARM gains enough traction that developers start paying attention. Though I have to wonder if a successful Qualcomm PC wouldn't end up hurting AMD more than Intel, because of their relative positions in the corporate market (which is conservative by nature and is a lot more pro-Intel than people on this forum, and the least likely to adopt ARM PCs)
511
5,452
4,879
Reactions: Tlh97
Magio
207
246
First off, it depends on what sort of battery life you're talking about. Battery life at idle, for sure, has little to nothing to do with process. Battery life at light loads will also only be marginally affected. But once you get to medium and heavy loads, process nodes advancements help make it possible to attain certain levels of performance at lower power, thereby de facto allowing a computer to accomplish the same tasks without expending the same power. If we're talking about efficiency in general, all of these scenarios matter.
Now, again, I do agree PTL won't match LNL in its laser focus on efficiency in every aspect. But it can make up some of what it loses with general technological advancements, and it can absolutely be more efficient in certain scenarios.
coercitiv
7,485
17,891
That's a very long way to say it helps custom configs last longer. For the average user a process bump mostly translates into more performance available for the same battery life.
Io Magnesso
578
165
The x86 platform supports a lot of hardware, has compatibility etc goes out the window with Windows on ARM. As it is now, Qualcomm will release a much better CPU later this year and all those points become invalid.
It's a little naive to think...
I don't understand how difficult it is to overturn the ecosystem…
511
5,452
4,879
also on the new SoC you should buy a Strix Halo instead of that iirc it is a 18C cpu with a beefier GPU with 192 bit Memory Bus but it will fall short of strix halo.
511
5,452
4,879
Well, you may have the option of using or not using PMIC.
I think you can probably choose according to your purpose.
well you can't it has to be during design phase and all of QCOM/Apples chips are designed with PMIC while AMD/intel uses traditional PD except for select few
Io Magnesso
578
165
Well, I think the PTL itself is designed with the assumption that PMIC will be used.
Not to say that the use of PMIC is absolutely necessary. I think that the use of PMIC is also taken into account.
DavidC1
2,184
3,331
But ARL-H is very good already without PMIC.
https://www.notebookcheck.net/MSI-P...ake-CPU-and-impressive-runtimes.958869.0.html
PTL should still have better battery life than ARL-H just not LNL and I think for most thats fine.
Except...
At 99.9 Wh, MSI has installed the largest possible battery in its Prestige 16.
20.5 hours with 55WHr versus 16 hours on 99WHr. Of course it's not an ISO-comparison, but the differences are humongous.
If you want better battery life on load, you just set TDP lower. That's it. That's what handheld gamers do. And ~20% difference with new process isn't much, considering at load you are getting 1-1.5 hours, 2 hours if you are lucky.
Io Magnesso
578
165
Except...
No matter how much the process change is not a big deal, The more it grows, the more, I think it's a good thing
mikk
4,333
2,413
That is probably the Ultra 7 SKU
I don't think so. Ultra 9 and 7 most likely 12 Xe cores and Ultra 5 10 Xe cores. Not sure about all Ultra 5 though. On ARL-H only the lowest Ultra 5 came with a partially disabled iGPU.
PTL-H 45W only has 4 Xe cores also.
Reactions: poke01
511
5,452
4,879
PTl-H is 25W for the base and performance profile
Io Magnesso
578
165
Perhaps the PTL-H Xe 4 core version is for combining with the dgpu.
