Page 820 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Io Magnesso
578
165
If the feedback on this problem is a problem specific to MSI, It would be a problem if I sent it to Intel Intel has created XMP standards, but it's not making a motherboard. Better to report to the MSI forums.
19,218
Based on this, I have to rescind my praises for Arrow Lake and Z890 and sadly call it instable, I have never seen my event viewer throwing so many criticals and warnings withing an hour.
Arrow Lake gets a 2/10 after retrying the platform and wasting my time.
Have to question your weird conclusion. It's MSI's fault. Intel can't be held responsible for MSI botching their BIOS/mobo validation.
AcrosTinus
221
226
The weird conclusion comes from being mad about the wasted time, In my naive thought MSI and Intel are tight and the Intel SWEs would not letting something this bad pass. Literally crashing the system on a hourly basis. I will admit though that without insight, Intel's fault is minimal but still as a customer it feels bad. My first MSI board, what a let down.
poke01
4,872
6,195
I would not buy MSI again. Thanks for investigating
Reactions: Io Magnesso
19,218
I haven't seriously considered an MSI mobo ever since I saw someone's failed SATA port corrupting HDD data back in the 845 chipset days. That was a brand new mobo not even 6 months old. Since then, I've had an MSI Geforce 1060 3GB which didn't crap out and I also have a MSI Z690 DDR4 mobo that I never found the time to use (idea was to flash modded BIOS to try to enable AVX-512 on my 12700K). My current rating for these Taiwanese manufacturers is ASROCK, Gigabyte, ASUS and MSI, in that order. ASUS is lower mainly because their prices are hardly ever attractive.
DavidC1
2,182
3,329
Why decode width will continue to scale:
When people give the argument that we don't need more decoders, the defense is that ILP is in average no more than 2, or 3.
However, the reason CPUs get wider is not for the average case. In United States, the average lifespan is about 80 years old. But we don't tell 80 year olds that "it's time for you to die", and you get no healthcare or any help. Average means there are cases where it's lower and where it's higher. You try to make the average higher by helping everyone, those that might die much earlier, those that might die at average, and those that are already past average.
Wider decoders exist for the peaks, because there are scenarios where ILP can go into many double digits.
A CPU doesn't only consist of decoders. It consists of many different blocks. Thus, from a power/area perspective, decoders are only a fraction of it. If for example a decoder block only takes 4% of the die, it would be worth doubling the amount if it nets you 4% extra performance.
Architecting a better general purpose CPU is basically finding what is the ideal balance between area and power for commonly used application base at the time.
Say you get 2% gain for each of the 5 basic blocks in the CPU: decoders, reservation stations and buffers, execution units, memory hierarchy, better branch prediction, then you end up with a respectable 10%. If you then only needed 2% area and power increase for each of the 5 basic blocks, then it's worth doing it.
If the supposed one block only took 2% of the area/power, then it's worth doubling that block, because while isolating it sounded like a bad tradeoff with 100% increase for just 2% performance, in the big picture you got 2% for extra 2% power/area.
Reactions: Doug S
Io Magnesso
578
165
By who, and why? Chips and Cheese does good work providing analysis at the microarchitectural and SOC design level.
No, there was a topic that I hated ChipsandCheese before.
I thought it was a bit contradictory
I am entertaining their content
Magio
207
246
It's launching In 2025 in limited quantity there is no doubt about it.
Yeah if I had to guess I'd say late Q4 launch in very few of SKUs from Intel's top partners (Dell, Lenovo, Asus, HP?), followed by more models revealed at CES for release in Q1/Q2 2026.
511
5,449
4,875
Yup also only die config will be available For that launch it should be 4+8+4+12 Xe3 Config
Reactions: DKR and Io Magnesso
Magio
207
246
Which is good because it's the only die config that interests me in PTL. ;)
Just hoping it performs well on the low end of its TDP limits.
511
5,449
4,875
Should 4xe3 cores match lunar lakes 8 xe2 cores?
nope that's too much but maybe they would match 8Xe1 core MTL or slightly less which should be decent imo. btw i am baffled by only 4Xe3 cores should have been 6 Xe3 cores since each render slice is 6 Xe3 cores max.
poke01
4,872
6,195
Than wtf is Intel doing?????!
I ain’t paying for the top sku for the 12 GPU cores that’s gotta cost a lot of $$$. Lunar lake comes with 7-8 on the usable SKUs. 226V is 7 core and 256V is 8 core.
I can tell that 12Xe3 SKU will be low volum just like the 288V..
mikk
4,333
2,413
Your comparison is not good. 288V is just one SKU whereas 12Xe3 will be included in several SKUs of PTL-H. Furthermore PTL-U is a cheaper solution for the mass whereas LNL-M is a more premium focused product. Intel needs something cheaper than LNL-M. PTL-U is not a LNL-M successor.
Io Magnesso
578
165
As expected, the possibility is low, The XE3 4CORE may have the same performance as the Xe2 8-core…
511
5,449
4,875
It's CPU is definitely better than the LNL part the only regressed part is the GPU
