Page 818 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Let's not be hyperbolic here. Crestmont isn't at least 5%. That imples potentially much as 10%. No, we're going to get 3-4%, which is almost margin of error difference since we have crappy reviewers, and no desktop parts meaning nothing ISO-comparisons which is the cardinal rule for benchmarking.
Also, we got 5% in Raptorlake so that's not zero. Arrowlake got 10% too, despite the shoddy uncore.
The disappointment is that Pantherlake isn't getting anything, because Novalake, the successor after that might also end up <10%. If Novalake is 6.2GHz+ then I guess he will be right in the long run with a N2 2027 core getting 0%*, so what am I doing typing this lol?
*So I guess getting 50% margin on a future product means investing zero in uarch and just clocks?
So single core isn’t everything
It's basically the sole reason why we care about CPUs. And time after time it's demonstrated a wider, lower clocked core is better in just about every aspects, which is entirely single core domain.
It's also because we implicitly known that single thread advancements are the hardest to advance, thus is rewarded most handsomely.
FP, AI, multi cores, they are in the accelerator domain, where just adding more generally helps a ton.
Everyone is shipping 5G+ next year.
You constantly prove my point about x86 vendors being retarded, and why they need a complete rethink.
What happens when a 10-11 wide core with M4 like IPC, reaches 5GHz or even 5.5GHz for the laptop variants?
A blood bath for Intel client laptop.
Ah, finally someone that understands.
Not only that, they already outclass desktop parts that should have much, much less thermal density with heatsinks that weigh more than some laptops.
Most importantly, 10-11 pipeline stages.
Means we need to get to 6.5.
You say clocks bad, yet everyone is cranking them higher and higher.
Where's the magic IPC juice? Why is no one shipping Royal Cores at 3.5GHz?
A follow up to the IGPU case, after buying a 285K and trying the encoder with handbrake it shows the same speeds, not comparable to the Raptor Lake IGPU. Slowly I am believing that Intel nerfed the decoder/encoder for increased 3D performance...
Can anyone validate with handbrake using anything from AlderLake++ IGPU vs. Intel Graphics on 200S ?
i have MTL CPU with the same Encoder/Decoder can you tell me what to test?
Thank you 🙂, I would use any generic phone video with 6 to 20K bitrate then try using H.265 or H.264 at file framerate and the quality preset from handbrake, the UHD770 at ICQ 19 would still deliver 180 frames with the Quick Sync encodes. The Intel Graphics on the other hand 20 to 45.
specific Handbrake version?
Right now, increasing the clock is the quickest way to improve performance.
First of all, it would be better to receive the reality that the ARMs are also increasing the clock frequency.
That means that my whole setup is borked, MTL has exactly the same IGPU as 200S, it isn't a version with more slices, right ?
UHD 770 doesn't support AV1
@adroc_thurston is right Apple has achieving majority of ST Improvements from clocks the IPC hasn't improved much compared to Intel/AMD IPC improvements
Wonderful
And this person a fool who previously wanted a Nova Lake made with TSMC N2 on X.
No matter how much it's true that Panther Lake hasn't changed, it's ridiculous to say such a remark.😅 It's ridiculous🤪
Just using the TSMC N2 will get better That's the kind of magic that is said in this tweet that doesn't have a sense of reality.
I have a feeling that MSI's 200S boost BIOS might be the issue here, I will try reverting and encoding a video (H.265) later, currently the IGPU in 200S is slower than the UHD770 in my 13700K and even G7 from 11th gen...
lol btw the Xe core slice doesn't matter cause the encoder and decoder are on N6 SoC tile which is shared between ARL/MTL
Wonderful
After all, this person is ridiculous
He's a painful person who is just self-conceived as a smart person who can see things.
A truly clever person can't expect it even if Intel uses N2.
well Nova Lake has another improvements that simply can't be seen with ST/MT improvements also whoever is spreading rumor about N2X next year ain't gonna happen
